Question about Sharp 27C-240 27" TV
27"tv sharp analog
Television screen goes white straight line then after 15 minutes picture goes on normally it been happening more frequently. any help please
  • danster Mar 23, 2008
    want to add there is no picture when this happens
  • Walter Coleman May 11, 2010
    Is the white straight you see vertical (from top to bottom of screen or horizonal ( across from side to side)?
    Problem Solver:
  • 16 Answers
If the white line slowly increases in size meaning the picture get larger over time then the problem is capacitors in the vertical circuit are most likely bad. Capacitors will dry out from heat over time and not be effective. These will have to be replaced.
However if the line suddenly disapears and the picture is normal after a period of time then you may have a loose connection on the printed circuit board.
Posted on Mar 24, 2008
  • 129 Answers
Good day.
Refering to to mr walts inquiry and if it is, maybe you are having some issues in your vertical circuitry. It may be loose that it needs to be resoldered and other filter capacitors within the vertical section.
chris
Posted on Mar 23, 2008
SOURCE:
What is wrong with Sharp Aquos LC-40C32U Picture
If you wish to get some details; visit the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Line, faults & possible causes to LCD screen are given with illustrations. You can get an idea about the fault to an extent.
Search the site with the keyword "Line fault"
Jul 01, 2015 | Sharp Televison & Video
How to fix a Sharp Aquos LC-40C32U Picture
Straight line in the middle of monitor. picture srunct
This is called vertical collapse and the most common cause is a failure of the vertical IC. If you can update this with the model number, I should be able to provide the part numbers and costs for the parts required to fix this. Also, if you intend to repair this yourself, please indicate thtat as well. The parts will cost around $20 or so.
Dan
Dec 08, 2009 | Sansui 27" TV
Panasonic CT-27L8SG displays gray screen and white hoizontal line
Is it still under warranty?
If not I would find a good TV Service Shop and have them check out the power supply as there more than likely a 'Capacitor' much like a battery that is going bad.
Blessings,
A/V Media Guy
Nov 22, 2009 | Panasonic CT-27SL14 27" TV
Tv goes to straight line in center of picture then
It happens when Vertical deflection stops as Vertical Out IC becomes hot or does not get vertical signal.
Please check electrolytic capacitors and dry solder joints in vertical out section in TV.
Aug 12, 2009 | Sanyo Televison & Video
Screen goes white
you may have a solder joint or an electronic part that is beginning to fail. have an electronic expert look at it.
Feb 07, 2009 | Sharp 25R-S100 25" TV
WHITE horizontal lines across screen
You need to adjust Screen voltage (decease a bit) to disappear white lines on TV. If you want to do it yourself, let me know to help you further.
Regards,
Aug 13, 2008 | Sony FD Trinitron WEGA KV-27FS120 27" TV
Toshiba 27D46 Black Screen - White Horizontal Line
I fixed the problem by taking it to a repair shop
Apr 24, 2008 | Toshiba 27D46 27" TV
Black and white lines
Good afternoon your tv could have some lose solder have a tech look at it.the problem is in the video circuit and related circuit.checkd should be made in the IF circuit.good luck.
Apr 05, 2007 | RCA 27V530T 27" TV
Sharp 27C-240 27" TV Logo
122 people viewed this question
Top Sharp Televison & Video Experts
Jaime Hernandez
Are you a Sharp Televison and Video Expert? Answer questions, earn points and help others
