Question about Gigabyte GA-8SR533 Motherboard
Windows booting problem
I have sony vgn-fs840/w laptop every time I turn it on it keeps rebooting again again.
    President:
  • 2,351 Answers
Hi sunnyh, when you start up the PC start pressing the F8 key every 2 seconds. A dos like window will load. At the bottom of the list choose, last known good configuration. (win might load the last good configuration) it's worth the try.
If your PC still does not load windows than repeat the above, this time choose, Disable automatic restart on system failure.
This also might allow windows to load (hopefully).
A system that starts going into this restart loop happens for many different reasons. Most common reason was a program that was last installed just before PC was restarted. Second most common reason for restart loop. Added new hardware, bios changes & windows boot files corrupted. If you did install a program, uninstall it. If you were in your bios & made changes, reset the bios. If you flashed the bios, go back to the old bios version. If you added new hardware replace with older hardware.
To fix Windows you may have to reinstall it. Do not run format or you will loose all your data. Even system restore CD's allow for a win reinstall without a format, however if the cd does not allow you to reinstall win unless you do a format. Than windows startup files are too screwed up & you'll have no choice but to format.
All you can do is try the above & cross your fingers.
Mike
Posted on Mar 22, 2008
Function key doesn`t work with windows 7 installed
My Vaio model is VGN-FS840 and after I formatted by laptop, my function key is not working, what shall I do to make it run? Can I download the driver? is it available in websites?
May 15, 2010 | Sony VAIO VGN-FS840/W Notebook
I have a Sony Vaio VGN-FS840/W and the keyboard will not work until windows boots, but windows is corrupted. I cannot boot from disk to re-install it without the keyboard working. I want to reset the bios...
try using an external keyboard, reboot the computer then pre f10 key repeatedly for 5-7secs to boot to vaio recovery center.. select restore c: drive to format the harddrive to the factory defaults
Feb 27, 2010 | Sony VAIO VGN-FS840/W Notebook
My sony vaio vgn-fs840/w laptop powers on but the screen is blank. I currently replaced the DC jack due to not powering on at all, now it powers on but I lost my screen.Thank you, Ben
turn on with battery if boot there problem is on the jack.
reset the bios battery .
check if u cut the mainboard during changing the jack.
Jun 09, 2009 | Sony VAIO VGN-FS840/W Notebook
Optical drive sony viao vgn fs840/w won't register
try downloading the VIAO update tool
http://esupport.sony.com/US/perl/swu-download.pl?mdl=VGNFS840W&upd_id=2775&os_id=7
this will ensure you have the latest software + drivers for your system.
problems with CD drives tend to be problems with the IDE drivers, so it may be a good idea to download the latest Chipset drivers either directly from sony (or using the tool above)
or downloading from the intel website
May 26, 2009 | Sony VAIO VGN-FS840/W Notebook
Vaio wont start up shuts off
check two things, video (reinstall drivers) and the other may be a heat event, look in the BIOS set up in the event log.
blow dust out with compress gas especially around the heat port and exhaust fans.
May 15, 2009 | Sony VAIO VGN-FS840/W Notebook
Beeping or stuck keys?
turn it upside down and pat it a little or use some air from a canwith it upside down
Dec 23, 2007 | Sony VAIO VGN-FS840/W Notebook
Gigabyte GA-8SR533 Motherboard Logo
137 people viewed this question
Top Gigabyte Computers & Internet Experts
David
David
Alun Cox
Tony
Are you a Gigabyte Computer and Internet Expert? Answer questions, earn points and help others
