Question about Toshiba 50H72 50" Rear Projection Television
Toshiba convergence issue model # 50H72
Tried adjusting the convergence but there is about two inch difference on the right side and cannot move it to try to adust the left side is much better and the middle moves out to the right a little.
What could be the issue it just started this this Am haven't had any other problems?
  • dayo33 Mar 23, 2008
    It is the red that won't move postions 1, 4, &7 are decent looks like maybe a small red issue but it gets larger at 2 and 8 and much larger at 3,6 &9
    here's a picture of it!
Looks like this is your problem http://www.fixya.com/support/t348123-toshiba_50h72
Posted on Mar 25, 2008
My Toshiba 50H72 HDTV has shadows like watching a 3D movie without the glasses. I only have the cablel remote and trying to adjust the convergence through the front of the tv did nothing. I also have...
The tv hyber board also known as the tv convergence board it is dead.Yes,if u have all the tools and also can do ICS chips soldering works?Yes,Tries websites like Tvrepairworld.com,Tvrepairkits.com to buy a whole complete convergence kit belong to ur tv make and model replaces those 2 STK conconvergence ICS and some or all of it resistors too by ur self.Or the shops will cost u like $300-350 for parts and labors.
Jun 17, 2011 | Toshiba 50H82 50" Rear Projection...
I just replaced the blue projector. How do I set
Coarse adjustment is done by adjusting the convergence coil on the neck of the tube, also the skew is adjusted there. The user menu should have a convergence adjustment option.
Jan 07, 2010 | Toshiba 50H72 50" Rear Projection...
Unable to move the blue and red convergence lines to the green
If red or blue will not move this model uses two of the STK-392-110 CONVERGENCE CHIPS.
Both chips along with any of the 8 or 10 protect resistors around need to be replaced--the parts are cheap--you can buy a pair of the chips on Ebay for less than 14 dollars plus shipping and the resistors are easy to test and or replace if gone.
Total parts cost should be under 30 dollars.
The hard part of this repair in your set is getting at the chips to replace them---most of these sets you have to unbolt the entire chassis--you will have to mark and unplug several plugs---so that you end up with the bottom of all the boards facing the back of the set.
Both chips are black in color--2 1/2 inches wide and 1 1/2 inches tall with 18 pins each--you need to be able to get at them, un-solder them and replace them.
They usually are near the middle of the boards and are on two large metal heat sinks with fins side by side and will have the STK-392-110 PRINTED ON THEM IN WHITE.
The resistors are dark gray in color an are usually 1.8 ohm in value---they can be tested with a meter---like checking a fuse--one with no reading is open. They usually do not burn or discolor in this set.
Most of the time just the chips need to be replaced and then the set adjusted--you will get ok results in the customer menu and if you get it working I can give you instructions to get into the TECH menu for fine adjustment all over the screen.
I am willing to step you through this repair if you or someone you know can do it---I will tell you all the things you need and give general instructions depending on where you find the chips are located in your set.
This repair usually takes me less than 1 hour, but I have done hundreds of them---someone else here with a similar set and problem I helped recently was able to do this repair--it took him over 2 or 3 hours since it was his first time.
If you cannot do the repair let me know and I will give you options.
If this information helped you, rate this solution as I DO THIS HERE FOR FREE.
SD TECH
Nov 10, 2009 | Toshiba 50H72 50" Rear Projection...
Blue light (RGB) will not converge (Toshiba 50H72)
Look around the area of the STKs and you should see some low valued resistors. One lead of which will be attached to the STKs. One or more of these is open. Replace it/them and you should be fine. These are current limiting resistors (effectively fuses) for the power to the STKs. One of them is not getting power.
Dan
Jan 23, 2009 | Toshiba 43H70 43" Rear Projection...
TOSHIBA 50H72 50IN. REAR PROJECTION TV BLUE COVERGANCE PROBLEM
you have a convergence ampliphier ic failing that will need to be changed and then adjusted
average repair cost for this are 280.00 to 320.00
Jan 20, 2009 | Toshiba 50H72 50" Rear Projection...
I have a toshiba model 50h72 double vishion
Projection sets have two very common problems.
The first common problem is convergence
These sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the picture to look normal. This is called convergence.
When its out of alignment the video will look 3-D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired. Convergence problems are very common on all Projection TV sets including Sony, Samsung,JVC,Philip Magnavox,Panasonic,Akai,Pioneer, Hitachi,Mitsubishi,Zenith and others.
You can get more information and a DIY convergenece repair kit with instructions from the link below.
Here are some of the most common problems with these sets...
*Screen Looks 3-D
*Colors wont align
*Screen may look distorted or warped
*No Audio/Video - TV Shuts down - May also make a constant chirping sound
Problem #2 - Another common problem is dull or washed out video.
Your set may have one or more of the following symptoms....
*Dull looking picture
*White looking picture
*Halos around objects
*Red/Orange looking picture
bb0cf99.pngYou can see some more examples and find a fix using this link on Fixya http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Nov 12, 2008 | Toshiba 50H72 50" Rear Projection...
Toshiba 50h72 picture and sounds takes 20 min to warm up
Projection TV sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the video to look normal. When its out of alignment the video will look 3D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the TV menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired.
This is a very common failure on these projection sets and a fairly simple DIY fix. All projeciton sets including Samsung, RCA, Sony, Philip Magnavox, Panasonic, Pioneer, Akai, GE, JVC, Toshiba, and others at some point will have the same problem.
Common Symptoms include....
  • Screen looks 3D
  • Colors don't line up
  • One or more colors can't be adjusted when using the convergence menu.
  • Screen is bowed or warped.
  • TV shuts off after powering on. Power light will blink. TV may also make a chirping noise.
Here are some photos of convergence problems.
Here is a quick test....
Using your original remote go-to the settings menu then goto the convergence section.
Try to adjust the red and then the blue convergence.
You should be able to move RED and BLUE in all directions - up, down, left, and right. And you should be able to get the grid straight.
If you can't move them in all directions or cant move them far enough your convergence chips are bad and should be replaced. This is a common problem.
Note: If you TV has as flash focus or magic focus button only try pressing the button. If it fails to fix the convergence your need to fix it. See below for a fix
69189a5.pngCONVERGENCE SOLUTION
You will need to replace the convergence chips and possibly some convergence resistors and pico fuses.
This is a a fairly easy DIY job if you are handy and can follow directions. You can get complete repair kits from TvRepairKits.com or click here. They have put together DIY repair kits that include the OEM parts and step by step photo instructions for each repair. If you are not handy or can't follow directions we would suggest calling a shop.
Sep 09, 2008 | Toshiba 50H72 50" Rear Projection...
CONVERGENCE PROBLEM IN TOSHIBA 43H70
Replace both STK392-110 convergence IC's with Toshiba or Sanyo brand........no cheap junk IC's !!!.................T.
Aug 16, 2008 | Toshiba 43H71 43" Rear Projection...
Picture gone.
You have bad conv. ic's.On these sets when the ic's go bad it will usually pop a fuse or burn up a few safety resistors,causing ith video to go away.
Mar 03, 2008 | Toshiba 50H72 50" Rear Projection...
Red convergence will only move up or down
Stk392-110 red convergence IC is bad...normal procedure===
1) pull chassis   2) replace both Stk's for reliable repair
3)re-assemble  4) re-align convergence
If you hire a technician, 400.00 is ave. price.
Oct 16, 2007 | Toshiba 50H72 50" Rear Projection...
Toshiba 50H72 50" Rear Projection Television Logo
75 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
