Question about SanDisk Sansa e250 MP3 Player
Sound only coming out of one earpiece. Conection to headphones faulty
  • 1 more comment
  • marky51 Mar 24, 2008
    Quote: "Conection to headphones faulty"
    Phones are ok
  • Anonymous Nov 08, 2008
    Have tried multiple headphones and only right earpiece works. Headphones work fine on any other MP3 player.
  • Anonymous Nov 15, 2008
    1. i can only hear on side like the left side
    2. i just want to know how to fix them
    Problem Solver:
  • 12 Answers
I think your earphones are broken
Posted on Mar 23, 2008
My philips SHE9550 ear phones' right end has stopped giving sound output all of a sudden. Left one is fine. Please suggest some solution to rectify this. Is it possible first of all to resolve this or...
It depends on if the fault is on the wire due to a break or snap or if the fault is in the earphone pin. Now both of the above faults can be rectified as the wire can be joined and the pin can be replaced.
Now if the fault is within the earpiece then it must be checked if the unit is faulty- a open coil - or a wire break to the unit.
Now in all the above cases a multimeter must be used to check the continuity from the headphone pin to the earpiece. An open wire can be rectified by replacing the wire, if the earpiece unit is faulty you need to replace.
Jul 28, 2011 | Philips SHE 9550 schwarz Headphones
Sound problem through headphone
Please give more details. If your laptop sounds fine without the headphones, and is only sounding bad through the headphones, there could be one of two problems. Most likely, your headphones have a faulty wire or wires, and are not transferring the audio signal to the earpieces. The less likely problem is that the headphone connector is faulty, in which case it will have to be replaced by a qualified technician.
Try the laptop with another pair of headphones and see how that works out.
Hope this helps.
May 26, 2011 | HEWLETT-PACKARD Hewlett Packard ProBook...
I have a scratchy sound under the bass in my headphones? Any help is appreciaated.
Two reasons are possible , first it can be from the source , so try the headphone on another device , increase volume and see if the noise persists. if so the headphone has problems.
Now this can be due to faulty earpiece speakers or poor connections within the flexible wires to the jack.
If the noise is evident on only one side then the headpiece must taken out and confirmed.-- a rather tough job to **** open to get access to the earpiece.
The replacement units are available only with Sennheiser but the cost must be taken to consideration.
Apr 23, 2011 | Sennheiser CX 500 Consumer Headphones
My LG KM555E phone is not working well, I can't hear any call any txt without using headset. The speaker is not working.
You will need to open the phone to get access to the board so as to check on the earpiece. Now it is confirmed that the earpiece is faulty and the board is working perfectly as the external headphone is used with good result . So using a multimeter check the continuity of the small speaker, remove and check. If resistance is open then the earpiece has failed. If not the sensitivity has dropped. make sure there are no blocks on the earpiece to prevent sound.
Apr 08, 2011 | LG Cell Phones
My technics headphones have just stopped working, is it probably a faulty chord?
Unusual to fail on both channels at the same time, however the most common cause is a break in the wire just above the 3.5mm plug.
I hope I have been of help but please do not hesitate to ask if you have any further questions.
I appreciate your vote if you appreciate my reply.
Mar 01, 2011 | Technics DJ Headphones
Sound is not coming from one of the speaker.
If you meant that one of the headphones are not working, then it is possible that
1.The earpiece of this side is faulty.
2.The wire from earpiece is open/broken.
3.The wire from the connection jack is open.
4.There is a fault in the connector in the phone or a break in the PCB of the phone.
Oct 07, 2010 | Nokia N79 Cellular Phone
I have AKG 141 studio headphones and the right hand side earpiece wont make any sound, i believe it is faulty wiring because if you move it around you can make it work.
take away the glued brandmark with a sharp tool (knife , little screwdriver) and you will find a screw. loosen it and open it. there you will see some cables witch probably have one loose. fix it by solding it.
Sep 12, 2010 | AKG K 240 Studio Professional Headphones
Left ear bud lost all sound- no cord damage-only 5 months old...is it worth getting fixed by professional or is there something I can do to fix it ? H
The cords are sealed into the earphone. You can take a multimeter and test the continutity of the either earpieces, once you are convinced that the left side is faulty, first of all use a small thin needle as the probe, use your multimeter in the continuity range, holding one end of the meter probe to the jack , inset the pin like an ijection into the wires to obtain the connection, it there is no connection out of the headphone jack, I think you can replace with a new one to be soldered. If not proceed to the earpiece to confirm, then open the sealed unit and be lucky if the earpiece is not damaged but only the wires. Good Day
Jul 07, 2010 | AKG K 321 cloud white Headphones
Help! no bass sound, low volume
You might want to try using a different size of the earpieces that come with it, and make sure they're inserted fully into your ear. They come with three different size earpieces because people's ears are shaped differently, and having the right size can make a HUGE difference in the sound. If it's done right, it should basically feel like you've just inserted an earplug into your ear.
If that doesn't help, and you've tried another pair of headphones to verify that it's not a problem with your sound source, I would guess you were unlucky enough to get a defective pair.
Mar 17, 2009 | Sennheiser CX 300 Consumer Headphones
SanDisk Sansa e250 MP3 Player Logo
43 people viewed this question
Top SanDisk Audio Players & Recorders Experts
Gyula Lacz
Are you a SanDisk Audio Player and Recorder Expert? Answer questions, earn points and help others
