Question about Sharp Projector lamp Projector Lamp
Reset Lamp sequence for Sharp XGE-3500U
Hi, Do you know the Reset sequence for my projector? I got a new lamp, need to reset the timer.
Thank you.
    Problem Solver:
  • 3 Answers
Hello everyone,
May you tell me how much it cost to buy Sharp XG3000U?
Thank you for all of your time.
Posted on Apr 12, 2008
  • Preylahong May 01, 2008
    Everyone may you please helpe me how to reset lamp on NEC MT830+ projector thank you for your time.
    Here you go how to reset lamp on XG-E3500U/XG-E3000U
  • 563 Answers
Hi there
I checked out the users manual and according to it you should be able to reset the unit by going into one of the Menu's subfolders.
Posted on Mar 26, 2008
I replaced the lamp on my XGC55X Sharp Projector and it worked great for 2 nights (roughly 6 hours). Now it goes to warm up, with the lamp light blinking, and will power down with the status button showing...
Have reset the lamp hours after installing the new lamp? If, not the projector has treated the new lamp as old lamp & refusing to light further. So, reset the lamp hours to zero. To reset the lamp timer do as follows. Plug the power cord into the AC socket of the projector. Switch ON the power of the socket. (not projector) While pressing simultaneously INPUT, ENTER & UNDO on the projector, press ON on the projector. "LAMP 100%" is displayed, indicating that the lamp timer is reset.
If this does not correct your problem then the problem lies in other area. Let me know so that further I can provide you solution. Above things are preliminary
Aug 06, 2011 | Sharp XG-C55X Multimedia Projector
I replaced the lamp on my sharp dt100 projector and now it will not turn on
Have reset the lamp hours after installing the new lamp? If, not the projector has treated the new lamp as old lamp & refusing to light further. So, reset the lamp hours to zero. To reset the lamp timer do as follows. Plug the power cord into the AC socket of the projector. Switch ON the power of the socket. (not projector) While pressing simultaneously MENU/HELP, ENTER & DOWN (button near MENU/HELP) on the projector, press STANDBY/ON on the projector. "LAMP 000H" is displayed, indicating that the lamp timer is reset. If this does not correct your problem then the problem lies in other area. Let me know so that further I can provide you solution. Above things are preliminary.
Aug 06, 2011 | Sharp Office Equipment & Supplies
I have a sharp xg-c55x. I put a brand new lamp. It worked once for about 20mins. Since then it starts warming up & then it turns off. How do i fix or reset? Thank you
Jul 07, 2011 | Sharp XG-C55X Multimedia Projector
Projector sharp XR-H325SA indicating lamp I replace tha new lamp but still indicating ineed to reset lamp timer but how?
hi,
for resetting the lamp hour do the following
1. Plug the power cord into the AC socket of the projector.
2. While simultaneously holding down MENU/HELP, ENTER and DOWN ARROW button on the projector, press STANDBY/ON on the projector.
3. "LAMP 0000H" is displayed, indicating that the lamp timer is reset.
ok
Jan 24, 2011 | Sharp XR-10X Multimedia Projector
Sharp projector - problem, can't reset lamp timer
You must use the remote as well!
1 Press KEYSTONE ' and
KEYSTONE " on the projector at
the same time.
2 Press INPUT and AUTO SYNC on
the projector at the same time.
3 Press AUTO SYNC and MENU at
the same time until unit comes on
LAMP 0000H is
Aug 20, 2017 | Sharp (BQCPGC20X1) Projector Lamp for...
Checking Sharp LCD Projector replacement bulb XGE 1000 U1
Hi Lynne
Check on the lamp itself for the slightest discolouration or vein like looking marks.
Also check for bubbles on the shaft and that the lamp's fillament is attached to the shaft of the lamp at the top end.
If all looks in order , you could by all means go ahead and buy it.
May 10, 2008 | Office Equipment & Supplies
Tech support for Sharp PG-B10S
Reset The Lamp Timer.
While simultaneously holding down (+ . >) and AUTO SYNC on the projector, Press ( I ) ON and ( - . < ) on the projector.
NOTE..... Make sure only to reset the lamp timer only when replacing the lamp. If you reset the lamp timer and continue to use the same lamp, this may cause the lamp tp become damaged or explode...
Sinista
Apr 15, 2008 | Sharp Notevision PG-B10S Multimedia...
Lamb will not reset
Sinista
Mar 18, 2008 | Sharp Notevision PG-B10S Multimedia...
Blinking bulb light
Hi there
You must always reset the lamp timer when replacing a bulb.
Dec 11, 2007 | Dream Vision CINEXONE Multimedia Projector
Sharp projector XV Z90U
I also had this issue - followed the On, Input, Undo, Left, Enter, Right, On button sequence several times. Then I decided to push them in that sequence very quickly and it worked. The lamp LED on the front changed to green and the projector started up. So the button sequence they provide in the manual works, you just have to push them in rapid succession. Hope that helps.
Oct 31, 2007 | Sharp Projector lamp Projector Lamp
565 people viewed this question
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
jasbo
jasbo
Adorjani Laszlo
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
