I would like to removed some music from my mp3
Removed some music from my mp3
  • Anonymous Jun 26, 2008
    can not remove music from s2001 mp3 have tried using mp3 and also edit from computer
    Guru:
  • 377 Answers
Hi dear
Depending on how you connect that device, if you plug it through USB, then an icon should come up in "My Computer" as a removable disk, just go in that way and delete the files manually.
If your device comes with software, you could probably use the software to delete the music off of it that way.
Posted on Mar 22, 2008
SOURCE:
Downloading music and removing songs
MP3 players can only play music files in mp3 file format.You can download mp3 music files from the Internet toyour computer and then copy them to your MP3 player.For your CD collection, you need to convert your CDs tomp3 music files onto your computer or download them from the Internet and thencopy them to your MP3 player after you have connected the USB cable tothe MP3 player and the computer.
You can do this using Windows Media player and Rip the CDs - Media Player willcreate a MP3 music file for each music track.Click on this link for instruction on converting musicfiles to mp3 file format :- http://www.fixya.com/support/r5798418-creating_transferring_mp3_music_files
Feb 17, 2012 | SanDisk Audio Players & Recorders
Record music to my voixcom mp3 player
Oct 19, 2011 | iLO (2 GB) MP3 Player
How do i clear music to add new music
Connect the MP3 player to your computer using the USB cable.
The computer will see this as an external drive or removable disk.
Click on this MP3 device and open the folder where the MP3 music files are located, then click to highlight the music files you want to delete and then press the DEL (delete) key to remove them from the MP3 player. This is the same procedure in deleting files from your computer's hard disk.
To add new music files to your MP3 player, please click on this link and follow my instructions :-
Sep 03, 2010 | Philips GOGEAR SA6045 MP3 Player
Loading music
There is an alternative to loading song onto your friends mp3 players like all players.
Many people find it difficult to sync there mp3 with windows media player, because it can be very annoying.
To get around this, First: Connect the mp3 player to your computer.
Next, got to my computer.
You should see the mp3 player in there as a removable disk,
Right-Click on the removable disk and select "explore"
This will open a window showing all unhidden files/folders in the mp3 player.
Leave the window open,... next find the music you want to add to the mp3 on your computer.
Windows Media Player music can be found in the my music folder.
Once you have discovered the music you want to add to the mp3 player, go to the mp3 player folder (removable disk).... there should be a folder in there labeled music.
From here on it's just a simple drag and drop process.
Select all the music file you want on the mp3 player from the my music folder, and move them inside the music folder found on your mp3.
Hope this help <(^_^)> thanxx
Apr 23, 2009 | Audio Players & Recorders
Removing songs
If there isn't a delete option available on your mp3 player, then here's what i suggest.
Connect your mp3 player to your computer.
Once you have been given notification of the connection, got to my computer.
The mp3 player will be shown as a removable disk.
Right-Click on the removable disk and select the "explore" option.
This will open a new window showing the contents of the mp3 player.
There should be a folder inside the mp3 player (removable disk) labeled music, or a large display of multiple music files.
From here, select the music files you want to delete.... but note that *all music you delete from the mp3 player will be removed permanently, and will not be redirected to the recycle bin*...but you can always get it back ;)
Hope this helps <(^_^)>
HOW DO YOU GET THE LIBARAY CHANGE TO DOWNLOAD THE SONG. IT'S ON MY WINDOWNS MEDIA PLAYER AND I CAN'T PUT THIS ON MY MP3 PLAYER.FROM WINDOWS MEDIA PLAYER TO PC LIBARAY ON MY MP3 PLAYER
I to have so many problems with windows media player its a shame... but like all things there is a way around it.
If the music you are trying to put on the mp3 is in windows media player, then you'll need to track it down.. *note- not all removable media comply with windows media player*
If you are using a PC-- desktop, then finding the music should be simple, and found in the folder my music.
Once you have located the music you want to put on your mp3, you'll have to find your mp3 player.
The mp3 player should show up as a removable disk or storage in "my computer".
Once you have found your mp3 as a removable disk, right click it, then go to explore. This should open a folder containing the contents of your mp3 player.
You may see several folders in it, but the one you want to go to is of course music.
From here on its simple... the My Music folder on your computer should still be open.... also the music folder inside your mp3 folder should be open.
Drag and drop the music files from the my music folder to your mp3 folder... a notification and time of the transfer will appear.
When it is done... the music will be added to your mp3 player ..... this process can also be used vice versa, as in getting music from your mp3 to your computer.
Please notify me if there are any problems.. thanxx <(^_^)>
Apr 19, 2009 | RCA OPAL M4001 MP3 Player
Windows media player is deleting all my that has been added
it sounds like media player updates (syncs) your mp3 player when it is connected to the computer. If you had music on the mp3 player that you removed from the computer then it makes sense that when updating the mp3 player it will remove it from there also. Try leaving music on media player that you want to sync with your mp3 player and try resyncing it, hopefully this will help
Dec 30, 2008 | Audio Players & Recorders
Removing music
Plug your mp3 player into the computer using a USB cable. Make sure you only have the one MP3 player plugged in, and no flash drives or cameras, etc.
There may be a button on your MP3 player that sets the mode to MTP or USB or Ready Mode. Make sure the setting is at MTP.
Open My Computer from the start menu. There should be a list of drives and document folders. You should see a drive labeled "removable storage" or "_____-Audio Player", (_____ may be your name or the name of the mp3 player).
Double click that drive. You may now see something to the effect of "SD/MMC Card" and or "Audio Player" or the name of your MP3 Player. You may also see files that say "Music" or even the music files themselves.
Double click on "Audio Player" if you do not have music on your SD/MMC Card (or if you just don't have one in your MP3 player).
If there is no "Audio Player" file, click on "Music" or the next best looking folder (it won't harm your computer or MP3 player if you look in all the folders). This should open up into Music files or a folder labeled Music. Double click this folder. Inside you should see all the music (or videos) that is on the MP3 player. Delete the music folders and files, but be careful not to delete anything else. The folders should be labeled by Artists, then Albums, then finally the actual music files. Delete all the Artists, albums, etc, to remove the music.
If you can't find the music files using my instructions, look in the folders of your MP3 player until you find them. Also, remember to have your MP3 player set to MTP mode if it is available.
Hope this helps.
Jun 07, 2008 | GPX MW3826 MP3 Player
65 people viewed this question
 Grubhead
Grubhead
Marvin
Marvin
