Question about Creative Labs Zen Digital Media Player
Radio How do I change and reprogram the radio?
You CAN change the radio.
It took me a while to figure out,
but when you are on one of your
presets, you hold down either
the left or right arrow [depending
on which direction you want to
tune] and then you may tune it
to any radio station.
Posted on Apr 08, 2008
You kind of dont mate sorry. press the option button and hit 'autoscan' it then finds all usable radio signals and presets them. from there you use the normal song controls to switch between presets. also after you have the presets set, you can go to the options manu of a preset again and then name it.
Posted on Apr 03, 2008
6ya staff
SOURCE:
Change the battery in my 2007 Hyundai Sonata and now my radio won't work how do I get a code and put it in?
Hyundai Tiburon Questions - how do i reprogram my lock ...
www.cargurus.com > Questions > Hyundai > Tiburon
CarGurusAug 17, 2009 - how do i reprogram my lock remote to my car? i changed my battery an ... i change my battery an now my lock an un lock buttons dont wor. ... I have aHyundai 2003 Tiburon, and the following worked for me, get in your ... The unlock codeis inside the case. ... Now my radio interior lights and clock wont work.
Hyundai replaced car battery now radio doesn t Cars ... - Fixya
www.fixya.com > ... > Cars & Trucks
Hyundai cars & trucks replaced car battery now radio doesn t questions and answers ... replaced my battery,, now key remote radio & clock does not work.. thank you ... ...car If you didn't do this before you replaced the battery, then there is another code ... I put a new battery in my 2003 sonata and now the radio doesn't work.
Jan 06, 2016 | Hyundai Cars & Trucks
Cp150 frequency change
This is a programmable radio. Using Motorola proprietary software, programming cable and radio interface box (RIB) the radio can be reprogrammed to another frequency/PL Code. This can be done by your Motorola dealer.
Feb 12, 2014 | Motorola Radio Communications
Radio Resets when I PTT
1) You were right to change to new batteries. Yet, the problem you describe is the same problem that would present itself if you had bad or poorly charged batteries. Check your contacts where the batteries touch inside the radio for damage or film/debris. Clean with a pencil eraser.
2) Is it possibly you have changed a setting, or have your radios programmed to a repeater (duplex only) frequency? Reprogram (if possible) your radios to a very basic setting with the code set to zero (off), and all special features turned off. Then using a basic radio-to-radio frequency test the radios again
3) If reprogramming is not possible due to the radio shutting itself down, then you have a battery or charging problem. Be certain the radio is turned off when on the charger and the battery is clean and inserted the right direction. Try charging both radios overnight. Observe your charger, does it seem like it is operating properly?
Basically, problems are either the radio, the battery, or the charger. By process of elimination you should be able to determine which one is the culprit.
Best regards.
Feb 04, 2014 | Motorola Talkabout T9500XLR - two-way...
Channel issues
try reprogramming with latest software
Jan 08, 2014 | Motorola Radius Cp125, 4 Ch, W Chargers,...
FI have a cb radio from Hong how do Ichange frequency to suit Australia. The radio is Qishi fm transceiver, QS-368S.Is it possible to change crystals,if they still use crystals
There are versions of this radio on different bands, some versions will not work on the Australian 477MHz CB channels even if reprogrammed.
Reporgramming the radio requires the software and a programming cable. Ask you radio supplier if the software and a cable is available.
If the radio is a version that will work and you manage to reprogram it it may work but will not be legal to use on the Australian UHF CB system because it is not type approved.
Sep 05, 2010 | Radio Communications
How to reprogram two way radio, its a motorola gp 339 and its set to 5 channels from when i brought it, can i reset it or reprogram it to normal uhf channels?
In order to reprogram this Motorola GP339 you need to have a programming software, radio interface box and programming cable for this radio then you can read and change frequency in it. To reprogram to UHF channels this radio must be in UHF band. Good luck!
radcom907
May 14, 2010 | Motorola GP300 Compatible 2 Way Radio...
How can i change u.s. motorola radio frequency to u.k. frequencie
Sorry, but the freq range of these radios cannot be reprogrammed.
Bill B
Mar 19, 2010 | Motorola Talkabout T5500 (7 Channels)...
Radio and console does not work after replacing battery
Radio may need code, radio should display "code, loc, ..." IF no power at all, check all fuses. Sometimes spark from changing battery can blow radio fuses easily.
Aug 21, 2009 | Volkswagen Touareg Cars & Trucks
Aiwa CR-LD120 AM/FM Radio?i program my radio stations, but when i have to change batteries i lose all the stations and have to reprogram them
This is a common problem when disconnecting power!
Try buying an ac adapter at your local pharmacy or radio shack and plug it in before changing batteries
Feb 08, 2009 | Aiwa CR-LD120 AM/FM Radio
Creative Labs Zen Digital Media Player Logo
Top Creative Labs Audio Players & Recorders Experts
Ekse
Marvin
Marvin
Are you a Creative Labs Audio Player and Recorder Expert? Answer questions, earn points and help others
