Question about LaCie (300728U) 250 GB Hard Drive
LaCie drive dropped my lacie 250 gb. it turms on and sounds fine but doesnt let me see the data
  • 2 more comments
  • Anonymous Jun 05, 2008
    the hard drive isn't recognized in my computer icon, but it is there in the tab to safely stop it on the bottom
  • Jodi Vicknair Dec 10, 2008
    did you find out what to do my orange light stays on but powers up
  • fishbrain99 Jan 11, 2009
    I have a similar problem. Dropped the lacie from 50cm above the carpet and now its not reading the data. It connects to the computer but the computer asks to "reformat" it. Can anyone help please?
  • FckForcedReg
    FckForcedReg May 11, 2010
    > ill email you first thing tomorrow avo when i find out
    It would be helpful to post the solution here too.
I got the same problem mate, im going to a computer store tomorrow and found out what to do , ill email you first thing tomorrow avo when i find out
Posted on May 04, 2008
My Lacie 250Gb ruged HD doesnt appears anymore on finder (LION ). I tried USB CABLE, FIREWIRE 800 but noithing happened. I tried to conect on a PC too lking on the Devices Manager and nothnig showed up....
It sounds like it has failed. If there is anything important on there take it to a data recovery expert who will charge a lot of money to attempt recovery of information. otherwise put a sledgehammer through it and trash it.
Oct 18, 2017 | LaCie (300728U) 250 GB Hard Drive
Hard drive does not always appear (mount?) on my desktop (Mac) I hear humming sound from inside. Has been going on for at least 6 months with increasing frequency. Is happening more than 50% of time now. 2...
Your hard drive is toast. If the computer doesn't recognize the hard drive and/or you hear a constant turning sound then your drive is broken and can't be repaired. You'll have to have it replaced.
Aren't you glad you backed up everything?
Jul 09, 2009 | LaCie (300728U) 250 GB Hard Drive
Lacie HArd drive not accessible
Start > Control Panel > Administrative Tools > Computer Management > Disk Management
Find the drive on the bottom section, right-click it and assign an unused drive letter of your choice. It should then appear in windows explorer.
Jun 30, 2009 | LaCie (300770) 250 GB Hard Drive
FW Lacie Porsche FW ext. HD 250GB light on case blinks and
conect your harddisk to computer whch has windows xp.
Then go to start emnu then type in run 'cmd"
then you can see command propmt.
Then go to your external drive letter like f:
then type 'chkdsk /r"
then pres "y'
then it fix error on hardisk.
Aslo you can format it .
Just take backup of data which you need then right clik on drive licon and format it.then it works fine.
Jun 23, 2009 | LaCie 250GB Ext/Firewire 7200 250 GB Hard...
LaCie external hard drive data lost
Try PandoraRecovery. Free.
www.pandorarecovery.com
Jun 05, 2009 | LaCie (300770) 250 GB Hard Drive
External Hard drive clicking sound and unable to view contents of
First check the LaCie power supply. I have a D2 HARD DISK EXTREME 250GB model 300770 that had this exact problem. I swapped out the power supply for the higher wattage unit from LaCie and presto, the drive functioned properly. Not saying this will fix your problem but I have personally had this exact problem. If not take the drive and mount it in a PC IDE/EIDE disk slot and see if you can mount the drive and recover your data (points to LaCie controller problem). Note opening the drive invalidates your LaCie warranty. Also note the warranty on my drive was one years and had long since passed. If that does not work, your last alternative it to use a disk data recovery service but that is big $$$$s. Bon Chance!
Feb 20, 2009 | LaCie (300770) 250 GB Hard Drive
External hard drive not openning
Good News, Your data is probably still safe. Go to best buy or online and buy a new cheap external usb case for your harddrive. you can find them for about 7-25 bucks. Make sure you get the right one for the hard drive in your lacie. Take the hard drive out of the lacie case and put it in the cheap case and you will have your data back. I had this happen to me before. If you need help just ask me... Hope this helps you
George
Jul 15, 2008 | Computers & Internet
Lacie lost evrything and is now clicking
Not without a clean sterile environment. Exposing the drive to room temperture and environment can damage the internal platters. i am willing to bet it the drive as well, but the clicking sounds like a bad drive arm, and continual attempts to use it may make the drive arm tear into the platters.
www.drivesaver.com
Oct 13, 2007 | LaCie 250GB Ext/Firewire 7200 250 GB Hard...
Lacie 250 GB harddrive
Lacie Porsche drives in my experience or infamous for not having the most durable bridge boards. The bridge board is a chip that has a chipset on it which take the SATA or PATA connection and send it to the USB and or Firewire ports on the enclosure. If the drive is powered up, you should get a small red or orange light on the front. When connected to either mac or pc ( porsches are MS_DOS formatted out the box ), if it does not mount or does not appear in DISK UTILTY, then it is a high probability that the enclosure/bridge board has failed and the drive ( if not making grinding, buzzing, clicking or beeping sounds) will have to be extracted and placed into a more stable enclosure. Hope this helps.
Aug 24, 2007 | LaCie Design by F. A. Porsche 160 GB Hard...
Lacie 250GB Drive
my only option to you is get file recover software for mac an recover data if no luck e-mail me on wareworlf2001@hotmail.com
May 30, 2007 | LaCie d2 Extreme (300790U) 250 GB Hard...
LaCie (300728U) 250 GB Hard Drive Logo
630 people viewed this question
Top LaCie Computers & Internet Experts
Raj Patel
Tony
Are you a LaCie Computer and Internet Expert? Answer questions, earn points and help others
