Question about HP Pavilion ze4300 Notebook
ZE4300 Device lock
Pls help, when I boot up, it turns on, with a black screen, you can see the cursor blinking but that is as far as it goes. If you hit ESC quickly you can read "device lock". I have removed HDD and DVD ROM, still no luck!
Advice
Thanks
Hary
    Guru:
  • 377 Answers
Hp probook wont boot
please select boot device from bios
Sep 16, 2013 | Computers & Internet
Have used dell dimension 2400 hard drive died replaced it now it only goes to boot device menu or black screen with blinking cursor
You will a full blown version of whatever software you want to install. Also try using the F8 key during bootup. See if the computer will boot up into Safe Mode. You should be able to made System restore disks from there if it will get that far.
Jan 21, 2013 | Dell Dimension 2400 PC Desktop
ASUS EeePC 900A- black screen blinking cursor
The hard drive has issues, or the window files are corrupt. I suggest a computer repair store to retrieve files and test hardware.
Aug 05, 2012 | ASUS Eee PC 900 Notebook
Black Screen of DEATH
well try finding someone who repairs coumpters from their home it is alot cheaper. explain your problem they should tell you weather they can fix it
Jun 30, 2012 | IBM NetVista PC Desktop
Gx620 boots up, then screen goes blank, reboot gives blank screen with cursor blinking. will boot with cd but still shuts down after a minute or two.
Remove the battery and open the case. Look inside the computer with a flashlight to see if any of the capacitors are busted or leaking from corrosion. The capacitors look like little battery towers, but they are not as tall as the AA or AAA batteries.
If the capacitors are bad, your computer goes bunkers.
Apr 30, 2012 | Computers & Internet
Tried F6 and F11 to reboot my compaq mini notebook, it's not working. When I turn on the notebook it shows F9 change boot device order and F10 BIOS setup options then it goes to a black screen with...
Hi
it may be worth trying the F12 key at startup it may work for you
good luck
or try the F8 key on start-up and try the back to last known good configuration
Jun 12, 2011 | Compaq Mini 110c-1001NR Notebook
MY COMPUTER BOOTS UP BUT AFTER IT BOOTS UP IT GOES TO A BLACK SCREEN AND A CURSOR KEEPS BLINKING AND IT WONT LET ME TYPE ANYTHING
Press F8 as it boot and when u get to the other screen choose LAST KNOWN GOOD CONFIGURATION hope this helps
Oct 28, 2010 | Computers & Internet
Black screen with blinking cursor after Acer flashes during start up. Loaded recovery disc and all seemed to go well but when I restarted it does the same thing.I can get to Bios from F2 but again that's...
this problem occurs when while booting some USB mass storage device is connected with the laptop so disconnect devices like printers or flash drive while booting and you can also do this by a setting in BIOS to stop booting from flash drive
Oct 17, 2010 | Computers & Internet
Black screen and in the upper left corner there is a cursor theat is blinking ... and teat is all
It sounds like a problem loading the operating system. Try booting from an installation CD to see if anything comes up... if it loads from the CD, there could be a problem with your hard drive.
When it turns on, try entering the BIOS by pressing the correct key (usually DEL, F10, F12, or F2) Make sure that the boot device is set to your hard drive. If you do this and it loads with an error saying 'insert boot media' or 'boot device failed' you'll have to either try fixing your boot sector (which can get tricky, but I'll walk you through it if you really want to attempt it) or a much easier fix, reinstall the operating system.
May 04, 2009 | Computers & Internet
Boot problems
Often, this indicates that the laptop could not find its default boot device which would be your hard drive. Pls enter the BIOS/CMOS setup and determine if your laptop can auto detect the hard disk. If detectable, save and exit, if not the drive may require replacement.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards.
Thank you for using FixYa.
Jul 19, 2008 | Toshiba Satellite A135-S2276 Notebook
HP Pavilion ze4300 Notebook Logo
161 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
