Question about Samsung DVD-R135
Menu scrambled Playback still functional but menu functions not usable due scrambling of several languages and screens overlaying one another.
Thanks,
It worked great for me also.
Posted on Jun 21, 2008
Try resetting the unit. On the front panel of the unit (not the remote) hold down the channel up and down buttons for 5-7 seconds without a disc inside. This is a factory reset.
I did this this morning and so far so good.
Posted on Jun 18, 2008
SOURCE:
Tv had thin black line when turned on today whole screen scrambled
need to access the ez menu to reset the parameters u will need a tech to fo this
Jul 19, 2013 | Vizio VF550M 55 in. LCD HDTV
Mitsubibishi wd series 73"..Mitsubishi ws series 73" dlp. Works fine but after several hours of viewing screen scrambles then goes blue and sound goes off. I can switch to another input and watch ama
A couple of suggestions, if only on cable and using a box disconnect the set and box from power and after several minutes repower and see if a reboot helps.
The two models listed here both should also have a soft reset done with the original remote and the set on---Menu,1,2,3, enter.
Dec 20, 2012 | Mitsubishi WD-52525 52" Rear Projection...
At times picture is redish and scrambled
The next time it does that go to the Convergence menu in the main menu and look to see if convergence is bad when it looks scrambled.
let me know what you find.
Mar 15, 2012 | Sony KP-46WT520 46" Rear Projection...
Microwave not heatin up! Russell Hobbs model no: RMH2000
Here is a tip that will help you to figure out what is wrong with yourMicrowave Oven....
Microwave Oven Basic Troubleshooting Tips
heatman101
gkggh
Dec 12, 2009 | Russell Hobbs Cordless Electric Kettle...
HDTV CABLE NOT HOOKED UP/WORKING
COMP 1 and 2 are for 480i/p sources. Hook it to the 1080i capable on the back. Also make sure the HD DVR is outputting 1080i not 720p. The Mits can not disply 720p and will show a scrambled screen if you try to.
Jan 31, 2009 | Mitsubishi WS-65809 65" Rear Projection...
Scrambled screen
well it is a hardware problem, you might change your lcd, or the flex or the display ic
Apr 21, 2008 | Motorola Mobility RAZR V3c Cellular Phone
Buttons losing function
If these phones are still under warranty, take them back. It is a motherboard issue. I hope this helped.
GOOD LUCK!!
Nov 10, 2007 | Sony Ericsson W300 Cellular Phone
Mustek dv3000
Try change the video out setting to "pal",press the menu button and scroll 3rd down which will show "ntsc" or "pal" press "set" to get "pal".
Oct 15, 2007 | Mustek DV-3000 Digital Camera
From chinese to english
Right from Cannon:
Issue:
How do I set the language?
Solution: Procedure for setting the language PowerShot S5 IS.
Setting the Language
The language in which menus and messages are displayed can be selected with this function.
Method 1
  1. Power the camera on in the playbackicon.gif (Playback) mode.
  2. Hold down the <SET> button and at the same time press the <MENU> button.
  3. Use the direction_arrow_up.gif, direction_arrow_down.gif, direction_arrow_lt.gif, or direction_arrow_rt.gif button to select a language and press the <SET> button.
Method 2
  1. In the playbackicon.gif (Playback) mode press the <ON/OFF> button until the power lamp lights.
  2. Press the <MENU.> button to display the Rec. or Play menu.
    - Use the 023.gifbutton to select the setup_icon.gif(Set up) menu.
    - Use the 021.gifor 026.gif button to select LANGUAGE and press the <SET> button.
  3. Use the 021.gif , 026.gif, 023.gifor 028.gifbutton to select a language.
  4. Press the <SET> button.
  5. Press the <MENU> button to redisplay the Rec. or Play screen.
Oct 12, 2007 | Canon PowerShot S5 IS Digital Camera
Mitsubishi WE-52525
. Suspect the FMT PCB part # 930B924002 when set is warm.
Jul 31, 2007 | Mitsubishi WD-52525 52" Rear Projection...
Samsung DVD-R135 Logo
199 people viewed this question
Jerry Greenberg
Jerry Greenberg
Ekse
