Question about Mitsubishi WS-48313 48" Rear Projection HDTV-Ready Television
TV-14 V-Chip problem
My T.V. won't let us watch things if the show is a TV-14. It asks for a code. We bought the TV about 3-4 years ago and we never put in a code because we didn't have it connected to cable or satellite--it was just hooked up to a DVD player. We don't know how to unlock it since we never put in a code. Can you help us? Is there a default code that I can put in? Thank you.
Kelly Westlake
(803)-932-0802
[email protected]
  • 2,337 Answers
Check this link to download the user manual and check page # 63 to temporarly unlock the V chip.
Good Luck.
Posted on Mar 22, 2008
SOURCE:
Rca projection tv
The white dots indicate a problem with the optical light engine---Parts for this set are very expensive and my suggestion would be NOT to repair it but replace it.
If you want some more information Google the model with "problems" to see what the common issues are fot this set
Dec 07, 2012 | RCA Televison & Video
My tv is locked and asking for a an unlock code. I have never had a lock code on the tv since i bought it several years ago. How can I reset or bypass this feature. BTW mt TV is a 48-50" projection...
Hello
I thinks that you have its original remote handset with you now, and posts this solution. If you don't have it, either buy a new original remote handset or try to get it from any of your friends and relatives, who owns the same model of Mitsubishi Tv, you have now; only to unlock it. After unlock, you can use any other remote control.
Mitsubishi sets use a four-digit code for a V-Chip locked program, view a locked TV, cancel the lock, or to enter the V-Chip lock menus. You can view the locked shows on the TV set by pressing the number 9 and QV buttons on the remote at the same time, whenever your code is requested. This process temporarily unlocks the TV and asks you to enter a new code.
OK.
Sep 15, 2011 | Mitsubishi WS-55511 55" Rear Projection...
I am able to get in with the 5898 code to unlock the tv, it won't let me put in a new code and I still can't watch r rated movies? and when I get in to the dvd side of things it only want's 3...
Hello
Just unlock it following any one of the methods described below. Then reset it as your desire. One amoung the following methods will surely unlock your RCA and give you option to do others.
Most RCA TV sets use a four digit code to control the v-chip. The code reset is different depending on the model. Try each number until you find the one that works for you.
  1. Hold down the MENU button on the remote and VOLUME DOWN button on the TV it's self at the same time for at least 4 seconds. The set won't say so, but the lock will be unlocked
  2. Hold down the 0 (zero) button on the remote and the VOLUME DOWN button on the TV itself at the same time for at least 4 seconds. The set won
May 17, 2011 | RCA 20F510TD 20 in. TV/DVD Combo
APPROXIMATELY 3" GRAY LINE ACROSS THE TOP OF MY TV
Do you happen to have a cable box? (reset cable box also by unpluging it). is that line also showing on dvd player on different input?
Jul 01, 2008 | Toshiba 50HM67 50" HDTV
Ilo 42" plazma has v-chip lock on
Have you tried calling the manufacture's tech support, or asking the dealer where the set was bought???
Jerry G.
Apr 18, 2008 | Televison & Video
Plasma screen color problems
Hi
I just bought a 42pc5d plasma tv it's an LG I bought it in Sept. 07 it started doing the exact same thing your talking about here the red glow type thing. Luckily for me and I hope in your case that the tv is under warranty, although if you know someone or even a repair place I don't think it would cost much to fix (just a guess but the guy told me that it was an easy fix so don't let them try to screw you). It really is a simple fix according to the tech. You need to adjust the voltage. He took the tv and watched it until he saw the red and adjusted the voltage and I had my tv back the next day. This was about a week ago and I haven't seen it since. I hope this helps and I hope you have a warranty. By the way LG comes with a 2 year manufacturer's warranty standard so if you didn't get an extended warranty from where you bought it if it's less than 2 years old call LG and they will arrange to have it fixed that's what I did. Here's the number 1-888-542-2623. Good luck.
Dec 27, 2007 | LG 42PC5D Television
No code
  1. Turn on your TV. If he TV request your secret code press QV and 9 at the same time.
  2. Press menu to view the main menu.
  3. Use up or down key to select "Chip Parent Lock" and press enter.
  4. The on screen display wil ask for your current passcode. Press QV and 9 at the same time.
  5. The on-screen display will now ask you to enter a new code.
  6. To cancel the passcode permanenly, press menu or home.
  7. To change to a new passcode, use the number buttons to enter a new code, then press enter.
  8. You must use the remote control included with thisTV. You cannot use a universal remote.
Oct 29, 2007 | Mitsubishi VS-50607 50" Rear Projection...
Vchip
If you can get into the menu, and know the proper password, then you can change the parental control setting. If not then the memory chip may have to be replaced. Stargazer
Aug 05, 2007 | Samsung TXN2726 27" TV
Mitsubishi WS-48313 48" Rear Projection HDTV-Ready Television Logo
160 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
