Question about Uniden BC72XLT Handheld Scanner
Uniden sc230 scanner
Scan mode lock out .
    Scholar:
  • 66 Answers
The lock out function is a common problem in scanners, to override the lockout command, you can press and hold the lock out button, or punch in the frequency that you locked out and unlock it by pressing the appropriate buttons depending on the model of your scanner. Here is a suggestion, for easy scanning I recommend a Regency Touch K500 Scanner. It may be hard to find one though, Regency went out of business a while back, but I had the K500 and it was the best scanner I ever had.
Posted on Jul 04, 2008
Reset programmed
If you refer this inquiry directly to Uniden support, you will get a solution
May 07, 2013 | Uniden SC230 Handheld Racing, Nascar...
Sc 230 scanner shuts down immediately after power is turned on
have you ruled out the battery pack it should have--total dead?
Nov 03, 2012 | Uniden SC230 Handheld Scanner
While listening to my scanner every so often, does not seems to be a specific interval, maybe 3 or 4 seconds usually, I get a silent pause missing conversation. For instance the ambulance dispatcher might...
sounds like you have another channel set for priority and it is scanning back to check that channel. In the manual mode scroll thru channel's until you find one set with a "p" or "pri" on the screen. Hit the priority button and this should resolve the problem.
Sep 09, 2011 | Uniden SC230 Handheld Scanner
My old scanner had 20 banks of 10 freq. each, am having trouble understanding the instructions for the SC230. Is there a site or booklet that has the instructions spelled out simplier.? thanks Ed...
Wow, Uniden did their best to make the SC230 manual confusing, didn't they? Here's a link to a much easier to read/use manual that was put together by an SC230 owner who couldn't figure out the factory document. I hope it helps.
http://marksscanners.com/230/230.shtml
Bill B.
Listening in since the 60's
Mar 29, 2011 | Uniden SC230 Handheld Scanner
How to program a bc855xlt uniden bearcat scanning radio
Major Functions of Uniden BC 855 XLT Desktop Scanner
RANGES AND MODES:
29-54 MHz; 137-174 MHz; 406-512 MHz; and 806-956 MHz NFM; 118-136 MHz AM
MEMORIES & MEMORY SCANNING:
• The 855 receives mainly via frequencies programmed into its 50 memory channels. It does not have a VFO or dial mode as such, but can scan within two frequencies.
• To scan memory channels, press SCAN. To hold a channel, press MANUAL.
• The 50 channels are divided into 5 banks (Bank 1: Channels 1-10, Bank 2: 11-20, etc.).
• Any of the 5 banks can be turned off from scanning. To turn a bank on/off, press its number while in Scan Mode. Active banks are illuminated in the display.
• SPEED toggles between 8 & 16 channels per second in both scan & search modes.
TO ENTER A FREQUENCY IN A MEMORY CHANNEL:
• Press MANUAL.
• Press the channel number you wish to program using keypad.
• Press MANUAL again.
• Enter the desired frequency using the keypad.
• Press E (ENTER). (If you make an ERROR, press CLEAR & re-enter frequency.)
• To set 2-second delay, press DELAY. Confirmed by “DLY” in display. Same deselects.
• To lock out channel from scan, select it & press LOCK OUT. Same deselects.
PRIORITY CHANNEL: Press PRIORITY to scan Ch. 1 every 2 seconds.
TO SELECT CHANNELS MANUALLY:
• Press MANUAL.
• Press desired channel number on keypad.
• Press MANUAL. Press MANUAL repeatedly to step through channels sequentially.
TO SCAN UP/DOWN FROM A CHANNEL: Select channel manually, then press ? or ?.
TO SCAN/SEARCH A GIVEN FREQUENCY RANGE:
• Press MANUAL.
• Enter the lower frequency limit.
• Press LIMIT.
• Enter the upper frequency limit.
• Press LIMIT.
• Press SEARCH.
I couldn't locate the manual for your scanner, but it's basically the same as the BC860XLT, except that the 860 has 100 channels. Other than that, all controls and functions are the same. You can download and print the manual for the 860 here:
http://uniden.com/pdf/BC860XLTom.pdf
For a comprehensive database of active frequencies in your area, and a lot of other useful scanning info, visit:
www.RadioReference.com
BillB
Jan 19, 2010 | Uniden BC895XLT Base Scanner
Cant find codes for my scanner its a uniden handheld but i cant find the codes for my area witch is blair county can you help me
Do a google search for radioreference.com. Choose your state from the data base site then your county.
Aug 03, 2009 | Uniden SC230 Handheld Scanner
BC72XLT program/scanning problems
1. If you mean on "bank" of channels, then you have locked out the others. To unlock them, place the scanner in "scan" mode & press each button that corresponds to each locked out bank until all are "on", as indicated near the top of the LCD. If you can't scan "bands", meaning all frequencies between 25-54, 118-174 & 406-512 Mhz, you may be stuck in the "capture" mode. Let me know if this is the case (not likely) & I'll coach you through it.
2. No.
3. No.
Sep 29, 2008 | Uniden BC72XLT Handheld Scanner
Scanner sc 230 uniden
1. Cellular is blocked out on most scanners. You might find a mod on the internet to unblock it....but
2. Most cellular now a days is digital anyway, so even if you could listen to the frequency, it would just be noise.
Geno
Feb 25, 2008 | Uniden SC230 Handheld Scanner
Uniden BC72XLT Handheld Scanner Logo
239 people viewed this question
Top Uniden Radio Communications Experts
Jason
John
John
AnyMHz.com
AnyMHz.com
Are you an Uniden Radio Communication Expert? Answer questions, earn points and help others
