Question about Kenmore 62602 Electric Dryer
MY DRYER DOESN'T GET HOT
My dryer is running, filters are clear but it won't heat up.Whats wrong?
(KEMORE ELITE)
  • NYINGA Mar 22, 2008
    WHAT BURN OUT ELEMENT iNEED TO FIX BECAUSE ITS NOT GETTING HOT AT ALL
    Master:
  • 518 Answers
If it's completely cold, you probably have a burn out heating element. If it gets warm and takes forever to dry, then it's probably the fan wheel.
Hope that helps...
Geno
Posted on Mar 22, 2008
  • Gene Wells Mar 24, 2008
    Hi again,
    Well, the model number you gave isn't complete for a Sears Dryer. It should be something like ###.##### . The heating element on an electric dryer usually is a long coiled spring inside of a blower compartment. You can inspect it and if it's bad it would be very obvious... it would be broken somewhere. If you get the correct Model number, you can go to Sears.com and look it up and see it. But I would take the unit apart and confirm that it's broken. Mine looks like a long spring that zig-zags back and forth inside a air tunnel. When mine failed I could see the spring was broken in one section.
    Please unplug the unit before taking it apart! Safety first!.
    Hope that helps more...
    Geno
2 Suggested Answers
jonniewalker
  • 1031 Answers
SOURCE: MY DRYER DOESN'T GET HOT
There are a few things to check out. 1. This may seem obvious, but make sure your temperature switch is not pointed to "fluff/air dry".
2.Is the motor running? It has to, to dry three. Make sure your door switch is engaging properly.
3. If you are so inclined, unplug the power cord and remove the back lower panel of the dryer.) Remove the vent pipe & allow the unit to run, if you now have the proper heat this means the vent is block, check the outside vent hood, the sometimes have a screen just inside that will block up not allowing for air flow.
Check all wire connections to make sure they are attached properly. If they are burned or worn, they need to be repaired or replaced. Any disruption of the circuit to the dryer element will stop its functioning.
4. Next, look for the thermostat.. which is usually a small circular metal device attached to the dryer element canister. Unscrew it and shake it slightly. You should hear a clicking noise. This should indicate that your thermostat is working (but not always!).
5. Remove the heater element canister cover and check to see that there is continuity of the element wires (no breaks). If there is a break, it needs to be repaired of replaced. You can take the heater element to a repair shop and be tested for current. If you think that you can repair any of this on your own, then go for it. Always think safety first before proceeding
Posted on Feb 21, 2009
Dryer won't continue to heat and doesn't shut off.
The coils on the gas assembly get IFFY with age. They work a little then get hot and quit. My Video
Jul 08, 2012 | Dryers
Where is the fuse located ?
The fuse is located on the blower housing next to the thermister (heat control). You won't see it till you get filter housing off there:
The 3 vid down shows how to get into it HERE on my blog
Jul 07, 2012 | Kenmore Elite HE4 Electric Dryer
Dryer runs for about 5 minutes then shuts off the clothes are hot
Your vent may be obstructed causing the dryer to trip, once it cools down it will reset itself. The way to see if thats the problem is to disconnect the vent and run the machine, if it doesn't shut off, you will need to clear the vent.
May 13, 2011 | Kenmore Elite HE4 Electric Dryer
Kenmore Elite gas dryer 110.74956300 gets warm but not hot. Air vent is clear.
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check out this electric no heat tip...
heatman101
Nov 22, 2010 | Kenmore Elite HE4 Electric Dryer
Dryer does not heat
Check out this tip it will help you with your problem...
http://www.fixya.com/support/r4398592-gas_dryer_not_working_gas_dryer_not
Heatman101
Mar 23, 2010 | Kenmore 72972 Gas Dryer
Kicks relay when hot
Make sure the lint trap is clean,and the exhaust is clear. some models have safety switch to stop fire if unit over heats.
May 30, 2009 | Kenmore 64742 Electric Dryer
Dryer blowing cold air only
Check your heat sensors, one or more must be OPEN.
Mar 26, 2009 | Kenmore 84052 Dryer
Feb 21, 2009 | Kenmore Dryers
Not staying hot-Kemore 80 Series gas
suspect coils bad on burner valve after heating up first time will sometimes fail on following fire ups
Nov 19, 2008 | Kenmore 63942 Dryer
Kemore Elite Dryer Repair
at the bottom of the unit there will be 3 torks screws remove them and the panel will open so you can see the insde and the heating element box...UNPLUG FIRST!!!
Nov 25, 2007 | Kenmore Elite HE4 Electric Dryer
Kenmore 62602 Electric Dryer Logo
1,890 people viewed this question
Top Kenmore Dryers Experts
Dan Webster
Dan Webster
Sal De
Tim Whalen
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
