Question about Royal Procision 7050 Bagged Upright Vacuum
Orange light is on
Hi, my vacuum shut off in the middle of vacuuming and the orange light came on. Can you tell me what this might mean? Thanks. Robyn
  • 1,673 Answers
You may have a clog, which over heated the motor and it shut down. Clog could be in the hose, the dirt inlet by the brush roll and bag/filters. Some have a reset on the back, near the bottom. If not, then the over loard protector may have gone bad, could also have a motor problem.
Posted on Mar 22, 2008
What is orange/red flashing when charging
The color flashing tells you how close you are to a full charge. The orange/red flashing should change to yellow and finally green. Sorry I have an original model so your's might be slightly different. Does it never change from orange/red?
Jul 03, 2014 | iRobot Roomba 550 Vacuum
Shutting off green light flashes
It means that the vacuum is too hot or too cold
Feb 02, 2014 | Dyson DC44 Animal Cordless Vacuum
Vacuum shut off in middle of use has overheated because of the jam and might take serveral hours to reset.
Dec 03, 2013 | Bissell Lift-Off(R) Revolution(R) Turbo...
The Orange "ON" indicator light
We need lots more info...oil won't heat ? this a vacuum cleaner ? Pop corn popper ? Oil filled radiator heater ? Company name...model number...anything ?? Help us help you. Thanks.
Nov 06, 2010 | Vacuums
Light goes on my kone but it won't work
Well first of all you may check that the charger (adapter) is working or not, you may use a volt meter to check it out or use another charger to make sure....... further you may follow the step below -
1. Remove the battery pack from Vacuum.
2. Hold down the power button for five seconds.
3. Reinstall the battery to reset the system.
4. Plug the Charger directly into vacuum.
5. Charge the battery untill the power light is solid green again and keep the vacuum on the charger for an additional 72 hours (3 days). Important: Do NOT interrupt this charging cycle.
If further you have the same problem it means it's time to change the old battery with new one.
Good Luck!!
Thanks for using FixYa!!
May 19, 2010 | Dirt Devil KONE Hand Vacuum MO213BLU...
My dirt devil just shut off in the middle of use, the bag was very full but it will not kick back on. Have tried every working plug in the house?
Does your machine have a switch that turns it off when the bag is full? Have you changed the bag?
Please try this solution ...
Thanks for your interest in
May 15, 2010 | Dirt Devil 12 Amp HEPA Filter Vacuum...
My Sharp Vacuum, Model EC-S2365 just stopped working in the middle of vacuuming. I'm not sure what happened and I can't turn it back on. Any suggestions?
Just before it shut down were you pulling on the cord? For it to shut down like that it almost sounds like the electric cord has a break in it-probably at the plug
Jul 14, 2009 | Sharp EC-S2365 Upright Vacuum
Vacuum stopped working
Hi Melisa
Because it has a dirty fan system where dirt is picked up and put through the fan impeller before it goes up the back spine and into the bag, it sounds like stones or hard dust has entered the fan and bounced off into the motor. Sadly this is one of the most common factors like Orecks that have a dirty fan system. It would have to be repaired unless you know how to take it apart and clear it. The green light certainly sounds like something you picked up with the Oreck and it has affected the motor.
Aug 14, 2008 | Oreck XL2600 Vacuum
Temperature light keeps coming on
The whine tells you taht the bearings are bad. Now they may be putting a drag on the armature and causing it to shut down after getting hot. You will have to replace the motor.
Apr 16, 2008 | Electrolux Lux 7000 Bagged Canister Vacuum
Royal Procision 7050 Bagged Upright Vacuum Logo
199 people viewed this question
Top Royal Vacuums Experts
Are you a Royal Vacuum Expert? Answer questions, earn points and help others
