Bad direct drivers.
Hi guys.
i cant play music files on any media player.
i keep getting a message saying,
bad direct sound driver please install proper drivers or select another device in configuration,
error code 8878000a.
i dont get it, please help.
  • Anonymous Jul 25, 2008
    bad sound driver
  • karthikasri Dec 13, 2008
    hi unable to play my music files nor listen to any videos on system ..i get the error as bad direct driver.please install a prper drive or proper configuration ..error code 88780078 ..pls help me
Hi guys. i cant play music files on any media player. i keep getting a message saying, bad direct sound driver please install proper drivers or select another device in configuration, error code 8878000a. i dont get it, please help.
Posted on Nov 02, 2008
Dear sir,
I ahve problem like My laptop is C700 series of compaq(C772TU) I ahve changed it OS from vista to XP and now there is no audio output whenever I try to play a song it gives msg like " Please installproper device or select another device in configuration Error code: 88780078"
please suggest me proper solution
Posted on Jul 22, 2008
    Welcome Back:
    Visited the website for 2 consecutive days.
  • 34 Answers
Found this info for this error, may help you.
as soon as you try to play an MP3 or other audio file you get the following message: "Bad DirectSound Driver. Please install proper drivers or select another device in configuration. Error code: 88780078 or 8878000A"
The Solution The way that we were able to fix the problem was by rolling our sound card driver back to the previous version and then we installed the latest driver for the sound card. Here are some detailed steps you can follow:
  • Roll the driver back to it's previous version (only tested with Windows XP)
    • Right-click on 'My Computer' and choose 'Properties'
    • Click the 'Hardware' tab
    • Click on 'Device Manager'
    • Find 'Sound, video and game controllers' and click the plus sign next to it to expand it
    • Find your sound card and double-click it, this will bring up it's Properties
    • Click the 'Driver' tab
    • Click on the 'Roll Back Driver' button. If there is a driver backed up for your device it will roll back to that driver, otherwise a message tells you that 'No driver files have been backed up for this device'.
      • If there is not a backed up driver for your sound card you may want to just click the 'Uninstall' button to completely remove the current driver that is giving you problems.
  • Install the latest driver from your sound card manufacturer's website
    • Find the manufacturers website and look for a drivers/downloads area
    • Download the most recent driver available for your sound card
    • Follow the instructions from your manufacturer as to how to install the new driver
  • Reboot your computer to make sure it loads the new driver
  • Try to play your MP3 or other audio file in Winamp
If these steps do not fix your problem then there are some additional steps you can take. Some computers have more than one sound card in them. If this is the case then it is possible that the default sound card has somehow been changed. To make sure windows is using the right sound card go to the 'Control Panel' and double-click the 'Sounds and Audio Devices' entry. Click on the 'Audio' tab and in the Sound playback area make sure the Default device is set to your preferred sound card. You could also try using a different sound card in your system if all else fails.
If you are still having trouble with this error you can press 'Ctrl+P' while in Winamp to bring up the Winamp preferences. Go to the 'Plug-ins' section and click on 'Output'. Trying changing the output from DirectSound output to WaveOut output and then close the preferences and close Winamp. Open Winamp again and see if it works now.
Posted on Mar 22, 2008
SOURCE:
Dst short test 1000-0146
Go to the Dell site and download the latest drivers.
Mar 23, 2010 | Dell Latitude C610 Notebook
No sound on Dell OptiPlex Gx110.
you can get your sound card driver from the link below
http://support.dell.com/support/downloads/driverslist.aspx?c=us&l=en&s=gen&ServiceTag=&SystemID=PLX_PNT_P03_GX110&os=WW1&osl=en&catid=&impid
Jan 23, 2010 | Dell OptiPlex GX110 PC Desktop
Music wont play through media player due to installing web cam
Hello my friend, i had encounter same problem as you have when i on one of my client's computer. You can reinstall the driver of your sound card. When you installed the program driver of your cam the sound card is affected due to some factor either the sound card is currupted. So my solution are the following: 1. Go to my computer icon then right click it the click properties. Then go to Tab name Hardware then click device manger then check if the sound driver is not installed or it is being corrupt. Then proceed to the reinstallation of your sound card driver. But if the sound card driver is installed then reinstall you windows media player. If you don't have installer then try this link: http://www.microsoft.com/windows/windowsmedia/player/10/default.aspx 2. Donwload Windows media player codec and update the codec of your Windows Media Player. try this link: http://www.microsoft.com/downloads/details.aspx?familyid=06fcaab7-dcc9-466b-b0c4-04db144bb601&displaylang=en
Hope this help fix your problem. If you need more help just contact me or reply to this post. Thanks
Jun 25, 2009 | Logitech QuickCam Pro 5000 Webcam
Windows Media Player cannot play the file because there is a prob
If this is the promblem with any music player in your computer than their is no sound driver installed or some sound files are missing to check if the sound driver is installed you can open the control panel---->sounds and check if the driver is installed if it is not you must install it using the motherboard CD that came along with your Pc
May 28, 2009 | Acer Veriton 7600G PC Desktop
No audio file will play on WMP, no dvd or audio disk will play...
Windows Media Player cannot play several files in the playlist. This might be caused by one or more problems.
To find information about the specific problems, click the Now Playing tab, and then click the blue or red icon next to each file in the List pane.
In some cases, you might encounter this error message if there is a problem with your sound device, such as a sound card or sound controller. For example:
  • Your sound device requires an updated driver. To determine if an updated driver is available, see Windows Update or see the sound device manufacturer's Web site.
  • Your sound device is not functioning properly. To troubleshoot the problem, see Windows Help and Support or refer to your sound device's documentation.
  • You do not have a sound device installed on your computer. Install a sound device, and then try to play the file again
Mar 31, 2009 | HP Pavilion dv6000z Notebook
Cannot play audio sounds
Hi
Its simple my friend...Try boot your computer in safe mode by tapping F8 repeatedly at start up... and then re install your sound driver which your were provided with. Use your driver recovery CD
Good Luck
Genius Guy
Oct 17, 2008 | HP Compaq Business Desktop dx2200 - P4 524...
Need help for sound card driver!!!
Try reinstalling both winamp & direct x.
Does this fix the problem?
Aug 02, 2008 | EliteGroup P4VMM2 Motherboard
NO Sound at all
hi u r audio drivers are not installed
so plz follow insructions
mycomputers - rihtclik n u get manage
device manager
find audio drivers n update it
i think it's will be ???(question mark) symbol
update it frm cd rom,
put mother board cd into cd rom.
ur's kishore chowdary.
+919441133420
May 04, 2008 | Intel Premier Resources 4-Channel 32-Bit...
Sound card wont play root media files
Hi Hughdog
well, Biostar mobos are know for a lot issues, but depending too, on the OS, windows XP I presume, go on safe mode, and uninstall all audio drivers, and disable on the BIOS audio. then start the PC, and install the audio card. or if is a internal audio reenable again, redetec the drivers, and install them according to the CD and drivers. you should see the play device now and play music correctly.
good luck
Nov 19, 2007 | Computers & Internet
Open Questions:
Xerox Printer CUSTOMER service pHoNe:~{-1^85526O{0O64}-}nUmBeR USA Wngiary Xerox Printer CUSTOMER service Number +126O{0O64}}WngLogin Repair service center to resolve all Xerox Printer tEcH SupPoRt pHoNe nUmBeR products. Xerox Printer ROUTER is an American multinational company which was founded by Michael Xerox Printer ROUTER using its company headquarters in Round Rock, United States of America. It deals with the repair, growth, Xerox Printer ROUTER support number, and selling of computer-related services and products. Xerox Printer ROUTER Tech Support Phone Number Recently, Xerox Printer ROUTER has been named the number Xerox Printer ROUTER technical support advice you not to perform any troubleshooting method if you are not confident of your skills. In such cases, Xerox Printer ROUTER customer care number can be dialed to contact the certified technicians Contact Technical Support Use one of the below methods to identify your product and see the available contact options, including Service Requests, Chat, and Phone . Enter a Xerox Printer ROUTER Service Tag or a Xerox Printer ROUTER Get Xerox Printer ROUTER Technical Support Phone Number and Customer Services. Xerox Printer ROUTER is a US-based multinational tech organization having its headquarters located in Round Rock, Texas. This tech organization supports, repairs, sells, and develops technology products. Basically, the company offers computer related products and services.
Oct 19, 2019 | Xerox Computers & Internet
Xerox Printer tEcH SupPoRt pHoNe nUmBeR:~{-126O{0O64}^-} Wngsary Xerox Printer tech Support Number +1{26O{0O64}}WngLogin Repair service center to resolve all Xerox Printer customer service phone Number products. Xerox Printer ROUTER is an American multinational company which was founded by Michael Xerox Printer ROUTER using its company headquarters in Round Rock, United States of America. It deals with the repair, growth, Xerox Printer ROUTER support number, and selling of computer-related services and products. Xerox Printer ROUTER Tech Support Phone Number Recently, Xerox Printer ROUTER has been named the number Xerox Printer ROUTER technical support advice you not to perform any troubleshooting method if you are not confident of your skills. In such cases, Xerox Printer ROUTER customer care number can be dialed to contact the certified technicians Contact Technical Support Use one of the below methods to identify your product and see the available contact options, including Service Requests, Chat, and Phone . Enter a Xerox Printer ROUTER Service Tag or a Xerox Printer ROUTER Get Xerox Printer ROUTER Technical Support Phone Number and Customer Services. Xerox Printer ROUTER is a US-based multinational tech organization having its headquarters located in Round Rock, Texas. This tech organization supports, repairs, sells, and develops technology products. Basically, the company offers computer related products and services.
Computers & Internet Logo
1,037 people viewed this question
Ekse
Alun Cox
