Question about Audiovox VE1020 10.2 in. TV/DVD Combo
No sound I turn on on the tv and I have no sound. If you push the TEL button you hear soumd for a second or so, but then it just turns into a low buzzing noise.
    Genius:
  • 1,139 Answers
Hello monlynne,
You may have a loose solder joint or a problem with the audio processor. I would suggest that you take the unit to a TV repair shop because of the testing that needs to be done. If I were to take a guess I would lean towards an actual problem with the audio output stage (processor).
I hope this helps
Thank you,
Shuttle83
Posted on Mar 24, 2008
Was working fine last night ,went to turn it on and you can hear a buzzing by where you plug in your jacks a bee,or high pitch sound.tv has no picture or sound.only sound you hear is this buzzing
Sounds like your power supply is causing the problem. Unplug the TV wait 10 minutes, look in the back for a red button (circuit breaker) push it in. If this does not work you have a low voltage power supply fault.
Mar 04, 2016 | Televison & Video
Picture went out and red light on the front by power button is blinking. When I turn TV on I can hear sound but no picture,, then TV turns off automatically after a few seconds.
It seems problem with low screen voltage to three picture tubes in this rear projection tv.
If standby light blinks 5 times after three seconds long pause then adjust screen volts of each picture tube to solve this issue.
Screen volt adjustment requires expertise and job of professional so please call local tv repairman to help you.
Thanks.
Feb 27, 2011 | Sony KP-46WT510 46" Rear Projection HDTV
My PS3 will not turn on to its main page! I Push the in button, it "beeps" but when my tv is on it proper input channal there is nothing? It won't turn on with any remote unless they are pluged...
Hello, it sounds like you need to reset your video output.With the power already off,press and hold down the power button till you hear the second beep then let go ,your video should rest about 8 seconds later.
Feb 09, 2011 | Sony Playstation 3 (PS3) Console
The playstation is connected to the tv. I can hear the sound but there is no picture.
Have you changed the connection you have the PS3 hooked up to the TV with? If so, instead of pushing the PS button on the controller to turn the console on, push and hold the power button on the console for a few seconds. You should get picture shortly after. This resets the PS3's output settings and makes it detect the type of connection you are using.
Jan 14, 2011 | Sony Playstation 3 (PS3) Console
SHARP LC-C5255U 52 INCH BLINKING POWER BUTTON, NO PICTURE WHEN I PUSH THE POWER BUTTON IT IS ORANGE, I CAN HEAR SOUND FOR 2 SECONDS AND THEN THE POWER BUTTON TURNS GREEN AND BLINKS. I LOSE SOUND AND...
It can be the power supply, backlight inverter board, etc.
First thing to inspect will be the caps in the power supply module, look for caps with leaking/bulging tops, check the DC output voltages, ect.
Learn more about troubleshooting here:
Please see my basic troubleshooting guide here:
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
http://www.fixya.com/support/r6150077-basic_lcd_monitors_troubleshooting
Failed TV and Monitors: http://s807.photobucket.com/albums/yy352/budm
Learn about bad caps: http://en.wikipedia.org/wiki/Capacitor_plague
Parts: www.shopjimmy.com
Capacitors kit: http://lcdalternatives.auctivacommerce.com/Default.aspx he can make you a set of caps.
Or www.digikey.com, just make sure to use caps with low ESR, 105c, high ripple current and long life rating such as PANASONIC FM or FC series.
Please post back what you find.
Dec 11, 2010 | Sharp LC-C5255U 52 in. LCD TV
Tv won't turn on. blinking red light in lower left corner
unplug the television...wait 10 seconds and then plug back in....if you listen carefully after 5-10 seconds you will hear a click sound (the same sound that you hear when you turn on or off) ...once you have heard it, turn the TV on again using the remote. Do not turn on until you hear the click. If this does not work, try again but turn the TV on again before you hear the click. I dont know why it happens but it is as if the TV gets confused as to whether its supposed to be on or off. Most of the time, the solution is to turn it on after the click so I would always try that first.
Feb 14, 2010 | Panasonic TC-32LX700 Television
HELP ME
Reset the TV. Pull the plug, wait a minute, replug it and report back.
Sep 01, 2008 | Philips Magnavox 42MF521D/37 Television
Damn TV....why doesn't it turn on when you push the power button??
Good Day, U-Fix- it;
Try this; CHECK FOR 10 VDC AT PIN 5 OF IC502 OF LOW, CHECK IC503 PART # 270P704010 ON THE MAIN PCB. 2. CHECK R529 .82 OHM 1/2 WATT OFF PIN 4 OF THE FLYBACK. IF OPEN CHECK C411 2200 UFD @ 35V AND IC 451 PART # 270P064020. ON THE MAIN PCB.
CHECK IC700 PIN 4 (AC-OFF) FOR 0 VOLTS DC, IF HIGH, CHECK FOR LEAKY D980 PART # 264P045040 ON THE MAIN PCB. 2. CHECK FOR 4.7 VOLTS DC AT CONNECTOR RF PIN 3 AND 4 ON THE SIGNAL PCB IF LOW SUSPECT PROBLEMS WITH THE SWITCHES/BUTTONS ON THE CONTROL PCB PART # 935D394001.
Good Luck, big IRISH.
Apr 29, 2008 | Mitsubishi VS-50603 50" Rear Projection...
Audiovox VE1020 10.2 in. TV/DVD Combo Logo
129 people viewed this question
Top Audiovox Televison & Video Experts
Jaime Hernandez
Are you an Audiovox Televison and Video Expert? Answer questions, earn points and help others
