Question about Kenmore 22422 Top Load Washer
Removing top cover to access switch
Can someone tell me ho wthe top cover cmes off so that Imay access the lid switch, My model is a wisr309dtaww.
Thnaks
john
    Guru:
  • 93 Answers
You have to pretty much use a putty knife to remove the front panel. Insert the putty knife into the edge of the front panel where it meets the top lid panel about and inch or two from the sides. One clip on each side. Push in the putty knife and give a little pull on the front panel repeat step for other side. That should get you into where you need to be.
Hope this helps you out. Feel free to ask any more questions about this if you run into anymore issues.
Posted on Mar 26, 2008
Model # lat8826aae my washer doesnt work when i close the top load cover
open timer console and replace fuse can get from any hardware store
Jan 27, 2011 | Maytag Washing Machines
How do I replace the lid switch?
This is completely dependent on what make and model washer you have. Some washers have a detachable top that is hinged at back and can be released at the front seam with two retaining clips that are gently pried up, or the front panel is removable to gain access to retaining screws at front of machine top. However, many other makes have screwed down tops that are accessible only from the inside of the body, these types generally have bodies that come off the machine in one piece, where they can be turned upside down to access the lid switches. It is very important to know what type you have, so the machine body isn't damaged while trying to access the part. If you have specific make and model number I can tell you exactly how to get to the switch.
Hope this helps
kcomp1863
Jan 01, 2011 | Roper RAS6233KQ Top Load Washer
Won't start when cover closed
your lid safety switch is shot,you need to remove 2 side control panel covers that pop off,then remove 2 screws that are under here, then control panel will separate from top to let you unplug lid switch connection to the control panel,then open the top cover by popping clips inward on the 2 front corners with a putty knife or something flat like this between the top and front covers,then raise top up and lean back against the wall there you can access this switch to replace it,this switch is designed to shut off unit if lid is raised during spin cycle for your safety
Dec 11, 2010 | Kenmore Elite Oasis 27052 Top Load Washer
How to remove washer top for broken lid switch access
if it is a top loader,,,remove the screws in each end of the control panel,,,some units you have to remove the end caps to access the screws,,,then pull slightly forward on the panel and flip it back it is on hinges,,,,then remove the 2 clips that hold the back to the base,,,unplug the lid switch,,then open the lid and grab the inner lid section and pull the rear of the base towards you slightly and lift off the base,,,, then you can access the lid switch and replace it ,,,,
Apr 29, 2010 | Washing Machines
Won't agitate on any cycle
under the top cover but mounted to top cover find your two leads and trace back to control panel and jumper the leads to bypass switch and this will tell you either switch is good or bad!
Sep 13, 2009 | Kenmore 24032\24036 Top Load Washer
Ho do you access lid switch
This assumes that you have a basic Kenmore / Whirlpool top load, direct drive, neutral drain (it doesn't spin until the pump removes most of the water) machine.
First, see the Sears parts site for your washer:
http://www.searspartsdirect.com/partsdirect/index.action
Enter your model number and you'll see a list of major sub-components with diagrams and parts.
To get to the lid switch on a Kenmore Top Load, you have to remove the cabinet.
See GURU JSROCK516 Description of how to remove cabinet and access the transmission. http://www.fixya.com/support/r699497-replacing_gearcase
Basically, you will remove two covers if your model has them, two screws, unolug the lid switch from the console and pull the cabinet forward.
Sep 05, 2009 | Kenmore Washing Machines
The washer does not drain the water or spin. Does the drain work when the spin cycle starts?
pull end caps from both ends of back splash remove 2 screws flip control panel back...remove 2 clips(use screw driver to pry up)...disconnect wire plug lift lid put hands in opening pull the case to you and up to remove entire case...remove 2 screws that hold lid switch install new switch...(don't forget to plug the wire plug back in...ho ho
Aug 26, 2009 | Kenmore 23822 Top Load Washer
No Spin No Drain
Lid switch is most likely the problem, if lid switch is visible under lid on right side then this is older design and common problem switch.
if you have console frame covers on front sides, snap off from top, a screw is at bottom front corners of console, remove and pull console forward and fold back. If lid swich is hidden then you will see it at left on top of cabinet with console folded back. a 5/16 screw holds a green ground wire to cab. remove and switch will unclip with lid up. If lid switch was visible under lid then you need to remove 2 brass clips holding cabinet on top of base to back, pry with screwdriver to unclip. undo harness connection on cabinet top, this is your lid switch connection. sw body is held by 2 phillips screws, harness tube held by clips on underside of cabinet top. ground wire with 5/16 screw present at sw body. New versions of this switch have metel shield attached.
Apr 25, 2009 | Kenmore 22642 Top Load Washer
Whirlpool Thin Twin Lid Switch and Return Pump access
where the washer and dryer attach just above washer lid there should be screws to rmove cover between units yours may have clips instead of screws that need to be removed to remove lid and top on rear edge of top there is a plug that hooks lid switch just watch when reinstalling top to be sure it reconnects..sorry for mix up those units had 2 different layouts over the years and without an image hard to tell which one you had
Jun 12, 2008 | Washing Machines
I have a Whirlpool Thin Twin model LT7000XTNO and the water will not drain after the wash or rinse cycles. I have tried it in each of the different settings (normal, permanent press etc.) Could it be the...
on most of those remove 2 screws in cover under console /timer on back edge of top will be 2 screws remove screws slide top forward switch connection is on front edge to acess pump 2 screws 1 on each side just below top on in side of panel remove and lift panel up
Jun 10, 2008 | Whirlpool Washing Machines
Kenmore 22422 Top Load Washer Logo
46 people viewed this question
Sal De GO PATS
fordexpert
Ed Mac
