Question about Uniden Cordless Phone
G.E. Dect 6.0
Phone display says Handset needs registration Have had phones a little over a year. Registered them when we first got them. Now they will not work at all.
Thanks
  • 4,102 Answers
Hi has the base got a reset button on the bottom please look then let me know ill have a quick look for your phones details and get back to you shortly just check of it has a small hole on bottom that resets the base if not let me know then ill get back to you ok
Posted on Mar 22, 2008
  • paul proctor Mar 22, 2008
    Hi have just been researching your phone and it looks like their is no reset button on bottom so instead follow these instructions for me and then let me know the outcome ok
    1. unplug power adaptor from mains and bottom of base
    2. remove handset battery
    3. wait for more than 30 sec with battery out
    4. plug back into mains and base
    5. insert battery then put on base.
    Let me know what happens after you have done this then i can assist you further ill keep looking for you about your phone as its not a phone ive had to work on before so im just researching whilst i wait for your response ok
DECT 6.0 cordless. Why won't it register the handset when placed on the base?
This could be several things.... the simplest is that a weak
handset battery can interfere with registration. Or,
does the handset display say "Connecting..." or
"Searching...." or "Out of Range / no power at base ..." ??
In these cases the handset is registered to another base and
must be de-registered before it can be registered again.
To deregister the handset:
Press and hold the [END] and [ # ] keys at the same time,
after a few seconds the display will say:
"System Reset, Deregister Handset"
press [SELECT]
scroll to "Base Unavailable"
press [SELECT] (chirps) press [END]
display reads "Place in base..." and it should be ready to
register.
Dec 28, 2015 | Uniden Lands Phones
I have a vetch mod# CS6114 I checked the base unit and it gets power to charge phone but I can't get a dial tone. I even hooked up to another line and still won't work.
This sounds like a registration problem, the
handset must be de-registered from wherever
it thinks it is and then registered to your base.
( I ). First, to de-register a cs6114 handset ---
0. Start by taking off the battery compartment cover.
1. press [menu]
2. scroll up/down to "Settings"
3. enter * 7 8 9 0 #
4. scroll from "Test Base" to "Test Handset", press [select]
4. scroll down to "next page", press [select]
5. scroll down to "Register Clear?", press [select]
6. display asks "Confirm?" or "Register Clear??",
press [select]
7. display reads "Ok" and chirps, press [ off ]
8. UNPLUG THE HANDSET BATTERY
(this is why the cover was off)
9. Wait ~30 seconds, re-connect the battery &
replace the cover
10. display reads "Not Registered"
( III.) To register the cs6114 handset to the base:
1. press [Find Handset] on the base and hold for
~4 sec until the "In Use" lamp lights.
2. press # on the handset and set the handset into
the handset cradle on the base
3. within 30 seconds or so, the handset will either
chirp and display "Handset Registered", then
"Handset #x" or it will say "Registration Failed".
NOTE: the battery must be well charged prior to the
registration process, a weak battery may cause a
"Registration Failed". Charge the battery for a
few hours and try the registration ( III ) again.
NOTE 2: Some cs6114 bases do not have the "In Use"
lamp indicator. To register the handset simply park it
displaying "Not Registered" in the base cradle and wait
for the registration to occur. Pressing # as above may
be required, maybe not.
Good luck !!
Feb 12, 2015 | Vtech DECT 6.0 Cordless Phone with Digital...
My phone display's No link to base. Reconnect main bas AC adapter. It is plugged in what now?
I had this problem, and I fixed it by re-registering the phone to the base. Here are the directions for how to do that from the manual:
Registering a handset to the
base unit
The supplied handset and base unit are
pre-registered. If for some reason the
handset is not registered to the base
unit, re-register the handset.
1 Handset:
{MENU}
2 {V}/{^}: "Initial setting"
{OK}
3 {V}/{^}: "Registration"
{OK}
4 {V}/{^}: "HS registration"
{OK}
5 Base unit:
- KX-TG4011 series:
Press and hold {LOCATOR} for
about 5 seconds. (No registration
tone)
- KX-TG4021/KX-TG4071 series:
about 5 seconds until the
registration tone sounds.
If all registered handsets start
ringing, press the same button to
stop. Then repeat this step.
The next step must be completed
within 90 seconds.
6 Handset:
Press {OK}, then wait until a long
beep sounds.
Note:
While registering, "Base in
registering mode" is displayed on
all registered handsets.
When you purchase an additional
handset, refer to the additional
handset's installation manual for
registration.
See http://service.us.panasonic.com/OPERMANPDF/KXTG4011-MUL.PDF (page 22)
Dec 06, 2011 | Panasonic KX-TG1033S Cordless Phone
On the screen of the phone says not registered and wont allow me to make phone calls or recieve
Please try the following procedure to register the handset:
  1. Place the unregistered handset in the telephone base. If PRESS FIND HS 4 SEC ON BASE does not appear on the handset screen after a few seconds, remove the handset and place it in the telephone base again.
  2. On the telephone base, press and hold FIND HANDSET for about four seconds (until the red IN USE light on the telephone base turns on) and then release the button. The handset shows PLEASE WAIT... and it takes up to 60 seconds to complete the registration. The handset shows HANDSET X REGISTERED (X represents the handset number assigned) and you hear a beep when the registration completes.
When the registration is complete, the newly registered handset is assigned the next available handset registration number. For instance, if you already have HANDSET 1 and HANDSET 2, the next registered handset will be HANDSET 3
Mar 05, 2011 | Vtech DECT 6.0 Digital Cordless Phone
Setting up my outgoing message: just purchased Uniden cordless DECT 1580. Manual says select command 8. How do I find Command 8? thanks, joan
please follow the instruction to register the handset to base
To register a DCX150 accessory handset:
1. Charge the handset completely.
2.Place the handset in the base cradle for about thirty seconds. Handset Registering will appear in the LCD.
3.When the handset has registered to the base, the LCD will display Registration complete then show the handset ID number.
If the display shows Registration failed, repeat the process again.
To register a DCX200 or DCX300 accessory handset:
1.Charge the handset completely.
2.Disconnect the base AC adapter. Then press and hold find while you reconnect the adapter. Keep holding find until the charge LED starts to blink.
3.On the handset, press and hold # until the handset beeps and displays Handset Registering.
4.When the handset has registered to the base, the LCD will display Registration complete then show the handset
ID number.
Thanx
Jul 21, 2010 | Uniden Cordless Phone
My cordless phone says "to register see owners manual for help" How do I get the phone working, it is a uniden DECT 6.0 Model DECT 1588-2
With the phone in standby, press MENU/SELECT on the base.
Move the cursor to select the Register Handset menu, and then press MENU/SELECT. Handset Registering will appear.
When the handset has registered to the base, the LCD will display Registration Complete then show the handset ID number.
Note: If a handset has ever been registered to a base, reset the handset before you register it to a new base
Dec 21, 2009 | Uniden DECT 6.0 Cordless Telephone...
Not registered
hello there i think this is because you need to register the second handset with the base here are the instructions
REGISTRATION
Registration links the base to a cordless handset. Once a handset is
registered it can use the base’s phone connection. A cordless handset will
not operate until it is registered to the base. During the registration
process, keep the handset near the base.
1. Press the flash/program button on the base until LINK HANDSET shows
in the display. 2NO is the default setting.
2. Press the 1 number key or press the MESSAGES/CID (or) button
on the base to scroll to 1YES.
3. Press flash/program to confirm handset is linked to the base. WAITING
HANDSET REGISTRATION shows in the display.
4. Press the flash/program button on the handset until LINK BASE? shows
5. Press 1 on the handset keypad or cid/vol (or) button on the
handset to scroll to 1YES.confirmation tone when the handset is successfully linked to the base.
6. Press flash/program on the handset again to confirm. You will hear a long
please leave rating if you find this usefull hope this helps thanx for using fixya!!
Jan 26, 2009 | GE 27958GE1 Cordless Phone
Need help registering the GE additional cordless model 27911.
I had the same problem but I fixed it by:
1. Disconnect the battery on the handset.
2. Wait 1 minute and reconnect.
3. Register handset.
Jan 10, 2009 | Uniden Cordless Phone
Tesco ARC200 Cordless DECT Phone
[ARC20x User Guide p20: 11 Handset Registration]
To register a new handset:
  1. Press and hold the HANDSET LOCATOR on the base unit until you hear Registration tone (repeated 'beeps')
  2. On the handset, press the PROG then the UP or DOWN button to display "REGISTER"
  3. Press the PHONE/OK
    -> The display shows "BS 1234". If any of these numbers is steady (not flashing), then the handset is already registered to that base unit.
  4. Press 1 to select base unit number 1
    -> The display shows "BASE PIN _ _ _ _"
  5. Key in the system PIN (default 0000) and press the PHONE/OK
    -> The display shows "WAIT _ _ _ _" for a few moments, while the handset searches for a base. Then it shows a list of handset numbers which are still free on the base unit.
    (For example, "1 34 6" indicates that numbers 1, 3, 4 and 6 are free; 2 and 5 are already assigned to other handsets.)
  6. Key in a free handset number
    -> After a moment, the display should show the handset's name and number.
If registration fails...
  • Try again, making sure you begin step 2 as soon ans Registration tone starts.
Nov 08, 2008 | Uniden Cordless Phone
Dect 6.0
Hi :I have the same problem and the dealer couldn't help me .I replaced the battery but that wasn't the solution.Glad to see i'm not the only one with this problem
Mar 22, 2008 | Uniden Cordless Phone
Uniden Cordless Phone Logo
41 people viewed this question
Top Uniden Lands Phones Experts
Are you an Uniden Lands Phone Expert? Answer questions, earn points and help others
