Question about Symantec WinFax Pro for PC
Opening .fxr and .fxd files moved from anther computer
Hello,  I have a bunch of WinFax Pro ver 9 send and received files (FXR and FXD) that I copied from another computer.  I can open individual files by simply double clicking them.  However, I can not figure out how to get them to appear within WinFax in the send and receive logs.  Can you please help?  Thank you.
You can't unless you have the original Send and Receive Logs to go with the FXR and FXD (and also CVR, IND, FXS files etc.)
http://www.getfaxing.com/support.htm
Posted on Apr 24, 2008
No brake lights where do i find fuse box on 1982 1340 fxr
Hi Anonymous, there are no fuses just a couple of circuit breakers behind the left side panel. Check your tailite bulb first, then grab a test lite and check for continuity at the front and rear brake lite switch, also check the wiring underneath the rear fender. Good luck
Apr 19, 2014 | 2003 Harley Davidson FXD Dyna Super Glide
Replace engine mounts are they the same mounts on 2010 front an rear
Hi Anonymous, there is only two motor mounts on rubber mounted engines, one in the bottom front of engine and one at the top. 99% of time is it's the front motor mount that goes bad. The front motor mount is not the same as the top. The rear shocks act as a rear motor mount. Please visit website below:
Harley Touring FXR The Glide Pro Front Motor Mount user objective review
Good luck
Mar 24, 2014 | Harley Davidson Motorcycles
Will fxr fender fit fxd
Hi Anonymous, 4 out of 5 Harley Gods give this one a thumbs up, but just to be on the safe side contact your local dealers service/parts department for confirmation. Good luck and have nice day.
Dec 17, 2012 | Harley Davidson Motorcycles
Where is the oil plug located on a 2005 Harley FXR?
I didn't think Harley made the FXR anymore. I thought they discontinued that bike in 1999 or so. But, just in case, the FXR's oil tank was under the seat. The drain was located at the bottom of the tank on the left side of the bike under the triangluar shaped frame insert.
Now if the bike is and FXD Dyna Super Glide, the oil tank is on the bottom of the transmission. Under the transmission, there are two drain plugs, one is located near the center of the oil pan and this is the transmission drain plug. The engine oil drain plug is located towards the left front of the oil pan. Drain the oil with the bike on the side stand.
To determine the exact model of your bike, search the Internet for the "Harley alphabet" You should be able to find a site that helps you decode your serial number (VIN#) to determine the exact model of your bike.
Good Luck
Steve
Apr 23, 2010 | 2005 Harley Davidson FXD - FXDI Dyna Super...
I lost all my logs and cannot get or send a fax when i try to do anything, i get the message"the following error occurred when attempting to open a folder, call failed one or more files for that phonebook...
This error indicates corruption of data, would I would suggest is to backup your data files immediately, the biggest mistake many do is by copying files while WinFax is open. Make sure WinFax is closed, and the WinFax Service is stopped when you copy or move data around. See Rebuilding phonebooks here: http://service1.symantec.com/SUPPORT/faxprod.nsf/docid/2000031014390704
and http://www.getfaxing.com/forums/
Jun 24, 2009 | Symantec WinFax Pro for PC
Restoring sent and received faxes to fax logs
That's not the way to backup your logs. You copied only the fax images, and not the logs to go with them. This is a common error that is made quite often. Unless you have the original log structure, your data (logs) that link to the actual fax images (fxds, fxrs, etc.) are lost.
Troubleshooting WinFax suggestion:
http://www.getfaxing.com/cgi-bin/ib315/ikonboard.cgi?act=ST;f=17;t=412
Jan 02, 2009 | Symantec WinFax Pro for PC
Windows Updates will not download...
Version 10.04 will not fix the problem with Windows Updates, and 10.04 will only update from a 10.03 version. Its not recommended unless you're using Fax Sharing and Windows XP.
Its possible you've overwrote some important system files in the process of copying files, but WinFax itself would not cause the problem.
Feb 07, 2008 | Symantec WinFax Pro for PC
How To Import Individual WinFAX files? .FXR and .FXD
Hi You can go to:: http://www.getafreelancer.com and post this request. I've seen it there before you wil need some third party app. Look for Project Number 138099 this will give you more info. Have a Great Day!!
Apr 12, 2007 | Symantec WinFax Pro for PC
Symantec WinFax Pro for PC Logo
169 people viewed this question
Top Symantec Computers & Internet Experts
Tony
Are you a Symantec Computer and Internet Expert? Answer questions, earn points and help others
