Meter lights How do I replace the meter lights on my power amplifier
  • Graeme Ross
    Graeme Ross May 11, 2010
    depends on what type of meters are used. What sort of amp is it?
  • 1,512 Answers
There are lots of ways to light up a meter. Sometimes the lamp in accessible from the front of the meter, sometimes the back. Sometimes you have to remove the face off the meter itself. You can get most any replacement lamps to replace the blown one, Some solder in place, some screw in, some just clip in. If you can give me the make and model, I can give you more accurate advice.
Posted on Apr 01, 2008
  • 236 Answers
Old type amps or meters uses sort of back lighting only. it's either peanut type bulb or fuse like bulb. dpending on the voltagew requirement too, you may check one of the meters still lites working and see the specs of the bulb. it should no te hard to replace. it also runs on AC supply so no worry of wrong connection.
Posted on Mar 25, 2008
Ok, i interested in the technics se a900s amplifier, just for vu meter use, not amplifier,and...
Pre-amp only needed for phono. Otherwise, line in is just fine.
10 to 20 ohm load resisters to substitute for speakers. get 50 watt rated ones at least, they can get hot....
May 12, 2016 | RCA Car Audio & Video
Sansui A-909 LED indicator(peak power meter)
Check you have 14 volts on pin 3 of the driver chip for the meter.
Apr 05, 2017 | Audio Players & Recorders
My SI-1230 was not working on channels 5-6 and 11-12. I opened the amp and replaced the fuses on those channels. Now the fuses blow immediately on channels 5-6 and the red protection light is on...
Chances are the main transistors or whatever powers channel 5 and 6 have shorted out. Fuses blow like this when there is an overload and these power types do that a lot. If it uses transistors, then a ohm meter will show them up quick. Because it will be just like you have touched the test probes together when you put them on the terminals, with the meter on the 1K setting. For the reason these parts are just acting like pieces of wire instead of doing their job.
Mar 12, 2011 | Niles SI-1230 12-Channel Amplifier
Lights up no sound
Disconnect your subwoofer wiring from the Amplifier, and use a multi-meter to check for resistance, or an open line. The subwoofer should have resistance. If not, check the wiring inside your box. If the wiring checks out, replace the subwoofer. Also, check your RCA connection from the Head unit to the Amp.
Jan 17, 2011 | Rockford Fosgate Power 1000BD Car Audio...
Pilot light on unit is flashing rapidly, no apparent output
disconnnect speaker wires , if amps light is steady then its one of the speakers or wireing . if not check ground ,or use a meter to check rca barrel to amp for ground set meter @ rx1 ,see amps ground is solid and clean
Nov 07, 2009 | Pioneer GM-X334 Car Audio Amplifier
I have a jl audio 500/1 going to 2 sony xplods
verify that the rca's are getting a signal with a volt meter! volt meter are $5 dollars and easy to use!
Feb 26, 2009 | Jl Audio 500/1 Car Audio Amplifier
Protect light
check speaker wire is not grounded and/or the proper impedence is followed. Those amplifiers are 2 ohm stereo stable. Know the difference.
Remove speaker wires and try amplifier.
Add 1 speaker at a time until the problem recreates itself, or test them with an ohm meter.
Dec 20, 2008 | Volfenhag ZX-8200 Car Audio Amplifier
I have a Peavy "Classic 30 BT" guitar amplifier that stopped working. When the power switch is ON, the pilot light glows but the vacuum tubes don't even glow. Using a volt meter, I found that 120 Vac is at...
Hi and welcome to FixYa,
I have to agree with you that that component is a thermal fuse. In my country, they are readily available in most electronics/hobbyist parts store. These components are also used for small motors and therefore would also be available in some (but not all) kitchen appliances parts stores. A temporary workaround is to install an ordinary fast blow fuse.
Just a start, do postback how things turned up or should you need additional information. Good luck and Thank you for using FixYa.
Nov 28, 2008 | Audio Players & Recorders
NAD C350
Take a ohm meter and measure resistance from emiter to collector should have a few kilo ohm on output transistor.
If no ohm meter available , remove output transistors from circuit.
note position of transistor . you have a NPN and a PNP for each channel.
Replace fuse and power up. If fuse blows check bridge in the power supply.
80% of the time output transistor burn and blow the fuse.
before replacing output transistors check driver transistors they probably burnt also
Apr 29, 2008 | NAD C350 2-Channel Amplifier
It jus turns off an i can't figure out y?
Disconnect the speaker wires and signal cables from the amp and measure the voltage across the power and ground terminals with a multimeter.
With the black meter lead on the ground terminal of the amp and the red meter lead on the B+ terminal of the amp, the voltage should remain at or above 11 volts.
With the black lead again on the ground terminal of the amplifier and the red lead on the remote terminal of the amp, the voltage should again remain at or above 11 volts.
Oct 29, 2007 | Kenwood KAC-5203 Car Audio Amplifier
153 people viewed this question
