Question about Philips Magnavox 9P6034C 60" Rear Projection Television
Can't make it work
We have dvd and tv set up , and we think that all is well with this , however when we load a disc it says that it is loading , and after a small while the message comes up that there is no disc. Everytime we repeat this the same thing happens. The message that there is no disc when in fact there is.
Can anyone please help. I know it will be a simple problem , but we can't figure it out.
Thanks Ken
    Master:
  • 518 Answers
If the DVD doesn't recognise a DVD disc, then if can only be one of the following:
1. Not a compatible disc... Try a store bought disc.
2. Defective disc... same as above.
3. DVD player is defective and needs repaired or cleaned.
When a DVD player says "No Disc" it also means " Can't read Disc".
Hope that helps,
Geno
Posted on Mar 22, 2008
SOURCE:
Skyworth 12v tv/dvd combo won't play
I would think the laser reader light is burned out.
Jul 27, 2018 | DVD's Televison & Video
The DVD player built into the unit has suddenly stopped working. We can load and eject as normal, but it doesn't play the disc. Pressing PLAY displays the "No disk loaded" message.
Disc do not loads into it properly. Is a loading mechanism fault. Contact any service technician. The disc loading mechanism should take out from the set for repair. If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Sep 03, 2015 | Televison & Video
No picture, no sound
see the troubleshooting index:God bless you
No sound
1. Check if the TV and Amplifier (if connected) is turned on and set correctly.
2. Check if the TV, DVD player and Amplifier are connected properly.
3. Make sure the TV, DVD player and Amplifier volume are not set to Mute.
4. There will be no sound output during Reverse Play / Pause / Step / Slow / Search.
5. If the DTS soundtrack is enabled in the DVD Disc Menu, but you are using Stereo Analog audio, the sound will not work. Try switching the soundtrack to Dolby 5.1 or PCM mode in the Disc Menu.
Does not play disc
  1. No disc. - Load a disc into the tray.
  2. Disc has been loaded upside down. Place the disc with the label side up.
  3. Disc region code does not match region code of the player.
  4. Disc type is not the correct type to play.
  5. Disc is damaged or dirty. Clean the disc or try another.
  6. Moisture may be condensed inside the unit. Remove the disc and the leave the power on for one or two hours.
Sep 23, 2013 | LG 32cs460 32" Inch Widescreen 720p 60hz...
Technika tv
It sounds that the problem to your TV is with its DVD loading tray. A pure mechanical fault indeed. Not loads the disc properly to its seating. A motor fault, or a gear wheel fault, or a leaf switch fault could be. Anyway, you have to take the DVD mechanism out from the TV, to get the actual problem could be resolved. Really this is a semi skilled work. It will be best to contact any service technician in this case.
Sep 19, 2013 | Televison & Video
My Allure TV is working well unfortunately the DVD isnt. I put the DVD in and it starts loading then says no disc. It sounds scratchy when loading. The TV works well but I use the DVD every day can yo
The only solution is buy a DVD disc cleaning kit and follow the instructions, this will clean the plastic lens and maybe get it back in working order. Second option is to buy a cheap DVD player in hopes the back of the set has the proper audio and video input jacks.
Mar 05, 2012 | Televison & Video
DVD won't load
needs dvd mechanisam probably not available
Jun 08, 2009 | Polaroid TDX-01930B 19 in. LCD HDTV
Dvd player wont load disc
try cleaning the lens first.then load a disk.try a different disc like VCD, CD etc.if only the DVD's are not read, the lens and the mainboard itself is faulty.but, if after cleaning it, it goes ok ,then its just dirty.
May 28, 2009 | Sony RDR-VX530 DVD Recorder/VCR
Cannot play dvd on my phillips hts 6510.
what happens when you try to play?
Aug 03, 2008 | Televison & Video
Hook up and programming
have you try to check the the video cable connections from the dvd to the tv..?
Jun 19, 2008 | Sanyo DVW-5000 DVD Player/VCR
Philips Magnavox 9P6034C 60" Rear Projection Television Logo
67 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Steve Allison
Steve Allison
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
