Question about Zenith DVB312 DVD Player
S-Video Problem. I hooked up my computer to the DVB312 Through the S-video port, and I can't get the picture to show up. I have a Dell laptop and I pressed the FN and F8 buttons, and the picture does not transfer to the television. I tried calling customer service, they didn't help
    Novelist:
  • 150 Answers
You need the isolate the problem:
1) Plug the DVD player into a TV
through the same S-Video cable
If the movie plays on the TV, then
the DVD player and cable are OK.
2) Plug another source of S-video signals
(if you have one) into the computer input.
If it works, than the computer hardware & software are OK
3) The third and most likely possibility is that the DISK is
copy protected, and the obedient DVD player is adding
MACROVISION analog copy protection into the S-video
output stream.
S-Video is an analog video format that has two separate
channels: 1 for composite B&W video (i.e. Y, or luminance)
and the other for the color (Chroma). Sound is separate.
Macrovision analog protection technology corrupts the
vertical synchronization and blanking pulses within the B&W
video stream,
which confuses the Automatic Gain Control (AGC) circuitry
of most VCRs. Bill Clinton passed a bill callsed the
"Digital Milenium Act", which makes such garbage VCRs
compulsory within the US.
Macrovision also adds digital pulses into the invisible
scan lines of the output video stream, which are recognized
by DVD recorders, and possibly your computer, such that
they will refuse to accept or record the movie.
Often a macrovision message comes up.
4) Finally, if the video is fine and you don't have
Macrovision problems, there is a strong chance
that your computer's device drivers are not installed
or configured properly, or there is a hardware problem
within the computer.
In either case, the computer manufacturer (tech support)
should be obligated to resolve this issue (4)
5) Inexpensive Macrovision remover boxes are
widely available by searching Google.
Hope this helps
Martin
Posted on Apr 23, 2008
Just go a dell precision 380 hook up for the monitor has 3 prongs and the computer has 2 what do I need to hook it up.
http://www.amazon.com/Dell-Workstation-Performance-Interlaced-Professional/dp/B008D3NKAS/ref=sr_1_1?ie=UTF8&qid=1366389036&sr=8-1&keywords=dell+precision+380
On the left side are different views. I am looking at the REAR view
At the Bottom, of the Rear of the computer, are 6 expansion slot openings.
Two of the expansion slot openings have an adapter card in them.
The other 4 are covered with an expansion slot cover. (Metal)
One of the adapter cards is a Graphics Card.
Looking at the Back of the computer, and from Left to Right;
there is a;
1) S-Video port
Black in color, round in shape
2) DVI port
White in color, parallelogram in shape
3) VGA port
Blue in color, parallelogram in shape
This article shows a graphics card with the same setup,
http://www.hardwaresecrets.com/fullimage.php?image=879
S-Video,
http://en.wikipedia.org/wiki/S-Video
http://www.hardwaresecrets.com/article/Video-Connectors-Tutorial/157/4
You can use the S-Video port, or the VGA port, or the DVI port; to connect a monitor.
However out of all three, the DVI port is the best.
VGA is Analog.
Your computer puts out a digital signal. (Digital video signal)
DVI is Digital Visual Interface. In otherwords - Digital.
Therefore DVI is the best.
http://en.wikipedia.org/wiki/VGA_connector
http://en.wikipedia.org/wiki/Digital_Visual_Interface
Armed with the above information, can you clarify more about your problem?
For example;
Monitor cable has three prongs........
Using the above information, can you tell me what monitor cable it is?
Computer has two...........
Can you tell me where on the computer, you are trying to plug the monitor into?
Please post back in a Comment.
Regards,
joecoolvette
Apr 18, 2013 | Dell Precision Computers & Internet
Laptop screen is black
Hook a monitor to the video output, if picture is okay the problem is in the inverter board located just below the screen, or the backlight is faulty. Now if both show the same symptom it is the video graphics chip.
Jun 27, 2012 | Dell Computers & Internet
Red and yellow line across the screen.
From the description the LCD screen will need to be replaced, first! hook a spare monitor to the video output on the back, if picture okay! the problem is the above mentioned, but if both screens show the same symptom it is the video graphics card.
Apr 19, 2012 | Dell XPS M1530 laptop, Crimson RED, 15.4"...
Trying to hook up a TV to my Dell inspiron 1420 PC using s-video to composite and there is no output on the TV. I borrowed an expensive converter which works perfectly so the computer IS set up properly...
that actually isnt a true svideo port. it does output video, but it needs a converter that dell sells for about 30 bucks (ebay is cheaper). it plugs directly into the "s-video" port on the computer and splits it off into both an svideo connection and an rca connection.
Jun 10, 2009 | Dell Computers & Internet
Hook up laptop to computer
Your computer may be running at a higher resolution than is supported by your TV. Lower your laptop's resolution to 800x600 and try again. If it works, you may be able to raise the resolution higher, perhaps 1024x768.
To change the laptop's resolution, go to the desktop and right click and select "Properties". Select the "settings" tab. You will see a box labeled "Screen Resolution", slide the slider to the left as far as possible. Then, plug in the laptop to the TV and select the appropriate input from the TV.
Hope this helps.
Jan 03, 2009 | Dell Latitude D600 Notebook
Connecting my laptop to my Samsung DNie 29' Tv
Are you connecting the S-Video directly into the video output port of your laptop? S-Video 7pin? Video output port 7 pin too?
Is there an adapter for the video output port, for your laptop?
Aug 14, 2008 | Dell Latitude D600 Notebook
S-Video no picture on TV
please right-click on my computer and click on the properties, there click on hardware to see hardware that are not properlly installed or driven. if all hardware are driven than get back for further directives. but it might that the s-video is not driven that is why it is not functioning or responding. good luck
May 23, 2008 | Dell Latitude D600 Notebook
C640 sVideo problem
you definitely need to get the drivedr for the svideo option. it wil actually not show you in the device manager the svideo, but the graphics card details only. to find out if you have a secondary display (svideo) you have to go to your display properties then and see if you have dual display. try to bott also your dell with the svideo-tv already connected and see if you get a post display on your tv. now... i need to know only if your svideo is active, drivers will still be need to get the windows work there.
May 03, 2008 | Dell Latitude C640 Notebook
Dell laptop c640 s-video port usage
Normally you have to use Fn(function key) on your keyboard + F4 key (F4 or maybe some other key you have to see and icon on your F4,F10 key..it should look like a a monitor icon) try it.
Press Fn first and hold it and press F4....
The first time it should output only to your S-video,second pressing it should output both s-video and your monitor.
goodluck,takecare.
Zenith DVB312 DVD Player Logo
100 people viewed this question
Top Zenith Televison & Video Experts
matt martin
matt martin
Computer Repairing
Computer Repairing
Are you a Zenith Televison and Video Expert? Answer questions, earn points and help others
