Question about Impact 820 Tripod
Impact 820 I have lost the small plate that attached to the camera and then snaps onto my 820. Where might I get a replacement? Thanks CHRIS
  • 24 Answers
What do I do to attach the camera after attaching it to the mount piece?
the quick release plate, that you are calling the "mount piece" will just snap onto the head of the tripod - if you aren't sure, a good way is to take off the QR plate from the camera, and then, with the screw threads face up, see how it fits into the head - many times, you have to engage the spring lever, so when you set the plate inside the head, it will snap locked into place. Then, re-mount it on your camera, and do the same thing, and there ya go.
Jul 01, 2014 | Manfrotto Camera Supports 3405BN JR. BLK...
Is it difficult to replace the headlight switch on my 87 Chrysler 5th Ave.? When I turn-on the headlights, they don't turn-on real good...I have to pull the switch out, fully, several times for them to...
Pretty simple actually....here is the directions on how to do it:
  1. Remove the headlamp switch bezel from the instrument panel by unsnapping the attaching tangs.
  2. Remove the 3 screws securing the switch mounting plate to the instrument panel, then pull the switch and mounting plate rearward and out of the instrument panel opening.
  3. Disengage the electrical connector at the switch. Press the release button on the bottom of the switch and then pull the knob and shaft out of the switch.
  4. Detach the headlamp switch escutcheon from the mounting plate by unsnapping the attaching tangs and removing it, then unscrew the switch-to-mounting plate retaining nut and pull the switch off the mounting plate.
To install:
  1. Position the switch onto the mounting plate and install the retaining nut, then snap the headlamp switch escutcheon back into position.
  2. Slide the knob shaft into the switch until it locks. Reattach the switch electrical connector.
  3. Install the mounting plate onto the instrument panel. Install the 3 attaching screws.
  4. Snap the headlamp switch bezel back into position.
Nov 01, 2010 | 1987 Chrysler Fifth Avenue
The Primary Control button broke off.
Keyboards for the Toshiba P205 series cost approx. 25 dollars on ebay. Individual keys if you can find them run about 4-5 bucks. The key attaches to the keyboard plate by two apparatus, the first being a scissor jack looking platform that snaps onto the metal plate over the key button. It will hook on one side and then snap into the other. I have to use glasses in order to pull off this repair. Once the platform is attached, the "cap" where the letter is stamped, should be placed directly on the support and using your thumb, roll pressure from one side to the other and you will hear the cap snap back on in place.
Oct 06, 2009 | Toshiba P205D-S7429 Satellite 17.0 Inch...
My knob has fallen off
sounds like the lockset has come apart in a way that it was not intended... normally you need to push a small spring loaded pin on the knob shaft in to remobe the knob, then a finished trim plate snaps off revealing the plate that gets tightened down to the face of the door... after tightening you snap the trim plate back on then the knob snaps on while pushing the pin in...
if it's a standard bedroom unkeyed lock then the plate and knob are one piece and the screws are exposed thru 2 holes on the inside knob...
Sep 02, 2009 | Kwikset Professional Door Lock...
2003 GMC sierra side view mirror glass replacement
That dependso on if the housing itself is broken then yes. If the face plate that is attached to the mirror itself is flapping around then maybe. If it is just the mirror, just go to your neighborhood auto glass shop and but a "Ready-Cut" mirror for a small amount of money. they come already cut to fit perfectly. As for removing the old glass, take a very small flat screw driver and pry the glass away from the face plate. Once completely cleaned out use the adhesive from the ready cut and place them on the face plate. Next press the new mirror onto the flace pate, being careful not to press to hard or it will snap it in half.
Jun 03, 2009 | 2003 GMC Sierra 1500
Instructions for replacing Olympus Stylus 820 battery door
Give a call to 305-653-7355 they can help
Ask for Zack
Apr 15, 2009 | Olympus Stylus 820 Digital Camera
Lost piece to charger that plugs into wall
Go to this sight .http://www.ylmart.com/kodak-easyshare-z730-charger.html
Mar 20, 2009 | Kodak EasyShare Z730 Digital Camera
Nikon N60 SLR camera
It is more likely that the tab has separated from the plate it slides on. The spring is attached to the plate with the tab sticking out from it. I have repaired these in the past by boring a small hole in the backside of the tab and use a screw to re-attach it.
Jan 12, 2008 | Nikon F60 35mm SLR Camera
Impact 820 Tripod Logo
60 people viewed this question
Top Impact Photography Experts
pontelemon
pontelemon
Tony
Are you an Impact Photography Expert? Answer questions, earn points and help others
