Question about RCA RT2280 System
RCA RT2280 Fuzzin' Out
I bought an RCA RT2280 surround system off of some kid on kijiji, but the damn thing stopped working after about 30 minutes of use, it seemed like it lost all signal and it went fuzzy. If i turn the system off for a while and try it again it will work, but only for about 30 minutes again. It seems like its over heating but it doesn't feel hot... Help me!
  • Bossdogg Mar 24, 2008
    I have the RT2280 system and the left front speaker is fuzzing out, but it has sound sometimes. any suggestions?????
    President:
  • 624 Answers
These receivers are know for having some bad solder connections on the main board around the heat sinks that the amp IC and the voltage regulators are attached to.
The symptoms you describe would point to that as a very likely source of your problems. That is for both of your problems.
With broken solder joints on certain components, the unit may play normal for a while and as the solder heats up it will expand and loose it's conductivity and bingo, problems with any number of things.
With heat stressed solder connections, not broken ones, the solder will conduct ok for a little while sometimes and as it heats up it gets less conductive. Many times heat stressed solder is less conductive than normal without heating up.
You can identify the heat stressed solder visually. It will be very dull, not shiny and silver like normal solder. It even gets a grainy texture to it.
Broken solder is recognized by the rings around the components lead that it is solder to.
If you have some decent soldering skills or know somebody who does, ask them to reflow the solder on the main board that looks like it could be bad. Just make sure the unit has been unplugged a while before you try it.
The bottom panel comes off of this unit if I remember correctly, or there is an access panel right under the problem area. I don't remember ever needing to take the board out of the unit.
If this information was helpful to you a good rating would be really appreciated.
One other thing you need to know is that if you need to get parts for this unit, you are out of luck. RCA no longer sells parts for the audio equipment they sell. They do have a shrinking supply of some of their parts, but once it runs out thats it for RCA audio parts.
I know this because I work at an authorized RCA repair center.
Posted on Jun 22, 2008
Hoooking up surround sounds with optical cable surround system is RT2280 AHHH please help my husband is driving me crazy to get it fixed and he cannot figure it out. Superbowl must be in surround sou
Make sure the digital setting (optical/coaxialor analog)is correct.
If youre connection is differet from default setting
1.select the source
2.press function
3.rotate multi jog to toggle among optical/coaxil/analog to match
yuor connection.
your selection will be stored automatically.
every time you press the source button the input setting(dvd/opti)
will be show on display.
heres a link to the manual go tto page 21 advanced settings.
http://www.google.co.uk/url?sa=t&rct=j&q=surround+sound+RT2280+AHHH&source=web&cd=4&cad=rja&ved=0CEMQFjAD&url=http%3A%2F%2Fsupport.radioshack.com%2Fsupport_audio%2Fdoc66%2F66651.pdf&ei=G2QMUbKqMOOY0QWJlYBw&usg=AFQjCNG2gc-bExNRynH2JEV22sR-L_ggDg&bvm=bv.41867550,d.d2k
Feb 02, 2013 | RCA RT2280 System
No sound from tv, dvd, cable. Speaker test does work. Sound stopped suddenly when channel was changed.
What does this mean: "when channel was changed"? TV channel?? Would that mean a remote command was issued? How about FM (no external cabling)?
Page 23...
http://www.retrevo.com/support/RCA-RT2280-Home-Theater-Systems-manual/id/402ag600/t/2/
Sep 02, 2011 | RCA RT2280 System
I have an lg lcd mod#lc427d hdtv how do i hook up an rca rt2280 system to it. i have a dvd player hooked up to tv now using hdmi cables, rca av reciever does not have them...
You can check your dvd player for a coaxial or an optical sound output, then you can plug it directly to your receiver. Those two are the best options after HDMI. Another option is A/V RCA type cable, you´ll need 3 stereo A/V wires, in order to connect the 6 channels. Remember to uncheck the HDMI sound output option on the DVD menu.
Nov 14, 2009 | RCA RT2280 System
I have RT2280. Audio levels used to be 1-50, now
Sounds to me as if someone may have gotten into the menu to adjust the individual levels of each loudspeaker and cranked some of them way up. As to why the "main" volume level goes from1-20 now as apposed to 1-50, you got me there...
Is there a reset button or equivalent on the remote or the unit? Try that. Try unplugging the unit for 15 minutes...
Here's the owner's manual:
http://support.radioshack.com/support_audio/doc66/66651.pdf
See page 21 for advanced volume control functions...
Mar 04, 2009 | RCA RT2280 System
RCA 2280 Optical Input w/PS3
The only optical option is through the satalite function. After I hooked up my xbox 360 with optical audio, I pushed the SAT button on the front of the RCA receiver then turned the multi jog wheel until it read "optical" out came surround sound. I hope this helps you.
Dec 07, 2008 | RCA RT2280 System
Mt rt2280
I think I answered the previous problem for 8 Mar.
Mar 13, 2008 | RCA RT2250 System
RCA RT2280 surround sound mode button wont select 5.1 dolby digital mode.
I had the same problem and this is what I did to fix it. Assuming that all of your equipment is powered on, (tv, blu-ray/dvd, rca receiver) you'll need to go into your dvd players audio menu and select the dolby digital audio.
Once you do this, the digital signal is sent to your receiver from the dvd. The receiver should automatically set itself to the dolby digital preset. If it doesn't, press the surround button until you reach it. I found part of this information here. And the rest was personal experience.
Also, it depends on if the disc format is in dolby 5.1. I hope this helps you.
Dec 18, 2007 | RCA RT2280 System
Surround cuts out???
Are you useing a digital audio cable when its cutting on & off? How long between the on & off? I have the same problem when I use a digital audio cable or a coaxial audio cable from my DVD player. To use the surround (6 CH) feature you need to use the 6 channel RCA jacks and if what ever your hooking up dosent have the RCA outputs your out of luck. My DVD player does have the 6 channel outputs and they work but the digital cables won't work. What are you connecting to it? I think something is wrong with the digital circuit board in mine, I would like to replace it and see. Reading your manual will help understand the 6 channel RCA and fiber optic digital cables. I hope any of this helped.
Mar 05, 2007 | RCA RT2280 System
RCA RT2280 System Logo
180 people viewed this question
Top RCA Audio Players & Recorders Experts
Gyula Lacz
Are you a RCA Audio Player and Recorder Expert? Answer questions, earn points and help others
