Question about Cameras
Module for Quantaray QTB-9500A for Canon EOS-40D
Do you have or are you going to furnish modules for digital cameras such Canon EOS D series
  • 1 more comment
  • cornsilk Jun 21, 2008
    I have a Quantaray flash, QTB-7500A, for a Minolta 7000i SLR. Is there a module available dedicated to the new Sony A700 DSLR? If so please provide the info.
    Paul J.
  • Anonymous Jul 21, 2008
    Same here. I have a 40D and would like to use this flash.
    What gives?
  • Anonymous Mar 04, 2009
    Same issue here. Have a QTB-7500A from my Minolta days, unfortunately, when I use it with the Sony Alpha 350, it only fires full power, no TTL whatsoever. Quantaray still hasn't come out with a compatible module for Sony. What gives?
  • 20 Answers
SOURCE: canon eos 40D error 99
Check this link: www.richardsnotes.org/archives/2005/04/29/50mm-lens-contact-points/
Posted on Nov 28, 2008
SOURCE: Canon 40D not firing
Try doing a reset in the camera tools somewhere, this fixed a similar problem I had.
Posted on Feb 06, 2009
aranhadesign
  • 54 Answers
SOURCE: my canon eos 40D says busy when trying to upload...
i often find with SLRs (and other proprietary cameras) its far safer to use a card reader.
Posted on May 06, 2009
  • 9 Answers
SOURCE: Autofocus has failed on the CAnon EOS 40D. I can
It's not the Autofocus, there's no 'non-engineer' fix. Lens and slider have failed, it's basically broken inside and I suspect it was the original fault. It's about £160-200 outside of warranty to fix via a canon authorised repair agent such as www.camera-repair.co.uk in Colchester. Send it back, get your money back.
Posted on Jul 07, 2009
maunderer
  • 5 Answers
SOURCE: Quantaray QDC-NK i TTL Digital Flash Module
The Quantaray Digital NK Module has a small tab on the side of the raised boss that the 8 pins sit on that prevents it from mounting on the QTB-9500A. It's intentional- the NK Digital Module is made for newer Quantaray flashes only. You'll need the older-style AF NK Module to attach to the QTB-9500A.
Posted on Aug 22, 2009
I bought Canon EOS d700. I have a Quantaray QTB-9500A with AF Module NK with my NIKON D90 . is this flash works with Canon EOS d700?
It will work, but not all functions will be availale. You can buy a Canon module for the flash.
Jul 11, 2017 | Canon Cameras
I have Quantaray QTB-9500A with AF Module NK, can i ask if this is compatble with a Canon EOS d700 ???
Does the manual give any indication ? If not, you may be able to google the compatibility or otherwise.
Jul 07, 2017 | Canon Cameras
How do i reset my canon rebel t3i back to default settings
Go into the Menu, Go to the ninth Submenu folder, Sec one from the end, Then Go to clear settings, Third one down, Hit set, Then Clear all Camera Settings. TC Camera Repair.
Jul 08, 2014 | Canon EOS 600D Rebel T3i Digital Camera
Lens mount fit
None directly. The T90 was the last Canon camera to use the older FD lenses. All newer Canon SLRs, film and digital, use the EF mount. However, by using an adapter such as http://www.rakuten.com/prod/adorama-canon-fd-lens-to-eos-body-adapter-with-correction-glass/216466533.html?listingId=120668308, you can use the old lenses on any Canon digital SLR.
Aug 12, 2013 | Canon T90 35mm SLR Camera
Promaster ftd 5700
Hello, You will need to get the correct interface module. You need the module that works with Canon digital cameras with E-TTL II which includes the Digital Rebel XT. I bought the flash and the interface module at Wolf Camera's going out of business sale and had to go through three interfaces to get the correct one for my XT.
Jan 10, 2012 | Quantaray QTB-9500A TTL Flash
I have a canon Zoom FD 70-210mm 1:4 lens off a SLR camera. Will it work with digital cameras?
No Canon FD lenses cannot be used on Canon EOS system cameras (all autofocus Canons except for the ancient and obsolete Canon T-series 35mm SLR's from the 1980's use the EOS mount).
There are very few cameras which can take them (35mm or digital) without some kind of expensive mounting converter which would include corrective optics.
If in good condition though it's a great lens and can be used on plenty of old Canon classic 35mm SLR models such as the AE1, AT-1 , AV-1 and Canon T-series, all of which are cheap//free and readily available.
Jul 13, 2011 | Canon Zoom Telephoto 70-210mm f.4 FD Lens
I just purchased a Canon EOS Rebel K2 35 MM film camera body. What lenses are compatible with this camera?
The Rebel K2 has the Canon EF mount. It is compatible with any EF lenses except the EF-S series. It will also work with third-party lenses that are compatible with the Canon EF series.
You can see the entire current line of Canon lenses (including the EF-S series) at
http://www.usa.canon.com/cusa/consumer/products/cameras/ef_lens_lineup
Jan 25, 2011 | Canon EOS Rebel K2 with 28-90 lens 35mm...
I have a quantaray qtb-7500a speedlight. It is for a Minolta camera. Is there any way to adapt it to fit Nikon equipment? jim
There are modules available to convert the camera into a Nikon lens. Right below your fill flash on the left hand side of the unit, there is a square button to release your current module and attach the new Nikon module.
May 20, 2010 | Quantaray QTB-7500 for Nikon TTL Flash
Doesn't work with canon d40 digital camera
You may have identified your own problem.
Your camera is either a Nikon d40 or a Canon EOS 40d (aka Digital Rebel), there's no such thing as a Canon d40.
If your Quantaray flash has the wrong brand dedication module on the bottom for your brand then it won't work properly (if at all).
If this is not the cause, then please be more descriptive: does the flash power up at all, will it work with other cameras, do other external flashes work on your camera? You may just need to go into the menu and enable the hotshoe.
Click here as well if you lack an operation manual: Quantaray products are always a pain to find manuals for as they're badge-engineered models supplied in the USA by Ritz/Wolf. The trick is always to find what the individual product is usually sold as. In your case, it's a ProMaster FTD5700. Page 2 of the manual will help you to identify which dedicated module you need for this flash to work with your camera.
I hope that I've helped, if not then please report back with additional details, or if I've helped you to solve your problem then please take a moment to rate my answer.
Feb 14, 2010 | Quantaray QTB-9500A TTL Flash
Cameras Logo
318 people viewed this question
Top Cameras Experts
Are you a Camera Expert? Answer questions, earn points and help others
