I have a Philips WAC700/5 which, when switched on, will not progress past the booting up stage. I have tried a couple of fixes already (checking the robbon connectors and a firmware recovery) but no joy. Just prion to this problem the unit stopped in the middlt of a track after about 1`0 minutes play and on both occaisions could only be resolved by switching off and re booting. On the third re-start it would not go past the booting up stage. Any ideas?
  • 19,396 Answers
I know you tried firmware recovery already. But if it breaks in middle of boot up, then is the firmware.
Posted on Mar 22, 2008
  • Ginko
    Ginko Mar 22, 2008
    You re-load the firmware backup and restore the system in the following way:
    Hold pressed SOURCE and STOP buttons while plugging into the mains supply.
    This will recall recovery option, follow instructions.
    If you this the above several times and it did not work, this means that the recovery backup firmware had been damaged. In this case you will need to contact a service centre to have your backup recovery restored.
    regards
Hp color laserjet cm1312 won't boot up. It tries to, there is a menu bar that tries to progress on the screen, but then stops. Help!!
Hi
Have you tried reinstalling the firmware for the printer. If it is already loaded on your computer then you should be able to reinstall the firmware in order to get it booted.
hope this helps (ie if you haven't gotten it fixed already)
May 16, 2011 | HP Laserjet CM 1312NFI Color Printer
I have the ps3.60.After switching on and putting in dvd(blue ray) the tv screen shows ps3 on the right of tv screen then the ribbon across screen but does not progress any further, almost as though frozen...
it may be that your ps3 automaticly loads the disc and has already started to play it and it might be trying to change the resolution(happens to me all the time) try un pluging your lead then plug it back in
hope this helps
Oct 27, 2009 | Sony Playstation 3 (PS3) Console
Ipod nano not detected by windows and itunes
There are a couple of things you can try:
Make sure you have updated to the latest version of iTunes.
To reset your iPod:
  • 1. Toggle the Hold switch on and off. (Slide it to Hold, then turn it off again.)
  • 2. Press and hold the Menu and Center (Select) buttons simultaneously until the Apple logo appears, about 6 to 10 seconds. You may need to repeat this step.
  • After resetting, try again to connect to the computer
How to restore your iPod: For Windows:
THIS WILL ERASE ALL SONGS, VIDEOS, PODCASTS FROM THE IPOD AND SET IT BACK TO THE FACTORY SETTINGS
  • 1. Make sure you've reinstalled the latest version of iTunes.
  • 2. Open iTunes, and then connect your iPod to your computer.
  • 3. After a few moments, it will appear in the source list in iTunes. If the iPod's display doesn't show "Connected" or "Do not disconnect" you may need to put the iPod into disk mode to proceed.
  • 4. Select your iPod in the source list and you will see information about it appear in the Summary tab of the main iTunes windows.
  • 5. Click the Restore button. You will be prompted with one or more restore options that may prompt iTunes to automatically download of the latest iPod Software. The 4 possible restore options are:
    • Restore Option 1: Restore - Restores with same iPod Software version already on iPod.
    • Restore Option 2: Use Same Version - Restores with same iPod Software version already on iPod even though a newer version is available.
    • Restore Option 3: Use Newest Version - Restores with the latest iPod Software on your computer.
    • Restore Option 4: Restore and Update - Restores with the latest iPod Software on your computer.
  • 6. A progress bar will appear on the computer screen indicating that the first stage of the restore process has started. When this stage is completed, iTunes will instruct you to leave iPod connected to your computer to complete restore.
  • 7. During the stage 2 of the restore process, the iPod will show an Apple logo as well as a progress bar at the bottom of the display. It is critical that the iPod remains connected to the computer or iPod Power adapter during this stage. Note: The progress bar may be difficult to see since the backlight on the iPod display may be off.
  • 8. After stage 2 of the restore process is complete and the iPod is connected to the computer, the iTunes Setup Assistant window will appear asking you to name your iPod and choose your syncing preferences similar to when you connected your iPod for the first time.
These steps usually will fix the issue...I hope that helps!
Jul 21, 2009 | Apple iPod nano
Ipod nano
Try this out
  1. Ensure that you have an active Internet connection as new versions of iTunes and iPod Software may need to be downloaded to your computer.
  2. Download and install the latest version of iTunes if you do not already have it installed.
  3. Open iTunes, and then connect your iPod to your computer using the USB or FireWire cable that came with your iPod.
  4. After a few moments, your iPod will appear in the Source panel in iTunes.
  5. Select your iPod in the Source panel and you will see information about your iPod appear in the Summary tab of the main iTunes windows.
  6. Click the Restore button. You will be prompted with one or more restore options that may prompt iTunes to automatically download the latest iPod Software. The 4 possible restore options are:
    • Restore Option 3: Use Newest Version - Restores with the latest iPod Software available.
    • Restore Option 4: Restore and Update - Restores with the latest iPod Software available.
  7. If you are using a Mac, a message will appear prompting you to enter an administrator’s name and password.
  8. A progress bar will appear on the computer screen indicating that the first stage of the restore process has started. When this stage is completed, iTunes will present one of two messages on screen with instructions specific to the iPod model you are restoring.
    • Restore Instruction 1: Disconnect iPod and connect it to iPod Power Adapter (typically applies to older iPod models).
    • Restore Instruction 2: Leave iPod connected to computer to complete restore (typically applies newer iPod models).
  9. During the stage 2 of the restore process, the iPod will show an Apple logo as well as a progress bar at the bottom of the display. It is critical that the iPod remains connected to the computer or iPod Power adapter during this stage. Note: The progress bar may be difficult to see since the backlight on the iPod display may be off.
  10. After stage 2 of the restore process is complete and the iPod is connected to the computer, the iTunes Setup Assistant window will appear asking you to name your iPod and choose your syncing preferences similar to when you connected your iPod for the first time.
Feb 02, 2009 | Apple iPod nano
Gateway GT5228 booting problem
"Also after I try to turn it on after a couple of unsuccessful tries, it actually boots and the machine works fine". This maybe cause by the hardware problem. And it usually caused by the motherboard. Changing the motherboard unit may solve the problem. But make sure you've already done the basic test on all of your hardware before changing it with a new one.
Sep 21, 2008 | Gateway (4000531) Motherboard
Switches istelf off half way through boot up
Open the Philips Device Manager - try update, and then repair
Aug 13, 2008 | Philips GOGEAR SA6045 MP3 Player
Fiji finepix s7000
Hi. From past experience I would say that these symptoms suggest the early stages of CCD failure. It usually starts with lines etc as you describe and progresses into wavy, blurry pictures or partial pictures and eventually the ccd just goes black. If it is CCD failure, the camera will usually still work when viewing pics that are already on the card.
Jul 02, 2008 | Fuji FinePix S7000 Digital Camera
My ipod is making a clicking sound
Drain the power.Fully charge the battery, check.
If the problem persists follow this.
You can try to reset :
http://support.apple.com/kb/TS1382?viewlocale=en_US
http://support.apple.com/kb/HT1320?viewlocale=en_US
If you still have the problem you can try restore :
Note: Because Restore erases all of the songs and files on iPod, make sure to back up any files you've saved on the iPod disk. All of your songs, videos, podcasts, audiobooks, and games can be loaded back to your iPod provided that you have them stored in your iTunes Library.
Retry your iPod with a different USB port on your computer, not a USB port on your keyboard or hub.
For Windows:
For Mac:
Restore Option 2: Use Same Version - Restores with same iPod Software version already on iPod, even though a newer version is available.
Restore Option 3: Use Newest Version - Restores with latest iPod Software version on your computer.
Restore Option 4: Restore and Update - Restores with latest iPod Software version on your computer.
6. A message will appear prompting you to enter an administrator's name and password.
7. A progress bar will appear on the computer screen indicating that the first stage of the restore process has started. When this stage is completed, iTunes will instruct you to leave iPod connected to your computer to complete restore.
8. During the stage 2 of the restore process, the iPod will show an Apple logo as well as a progress bar at the bottom of the display. It is critical that the iPod remains connected to the computer or iPod Power adapter during this stage.
9. After stage 2 of the restore process is complete and the iPod is connected to the computer, the iTunes Setup Assistant window will appear asking you to name your iPod and choose your syncing preferences similar to when you connected your iPod for the first time.
Or
Try to reinstall
To update and reinstall your iPod software, first download the latest version of iTunes.
http://www.apple.com/itunes/download/
Next, open the new version of iTunes and connect your iPod to your computer.
Select your iPod in the source list and click "Check for Update" under the Summary tab. iTunes will check to see if your iPod needs to be updated and perform the update for you.
Good Luck.
Live, Love, Laugh.
May 11, 2008 | Audio Players & Recorders
Ipod 2gb nano
If none of the buttons work, your hold switch might be on. It's on the top of the ipod, make sure it's switched to off.
If that doesn't work, try a restore:
How to restore iPod
Feb 10, 2008 | Apple iPod nano
285 people viewed this question
 Grubhead
Grubhead
