Question about Lexmark X5150 All-In-One InkJet Printer
Lexmark 6150 printing problem.
I recently reinstalled the printer on a different computer. When I print an alignment page only i black bar and 3 cyan bars print and i get a problem with the cartridge. When I print a test page only the windows flage is printed. When I print a balck test document, it goes through the motions, but nothein is printed on the paper. It comes out completely blank. Any ideas?
Reset
Posted on Jan 28, 2009
    Scholar:
  • 141 Answers
Have you try replacing your cartridge ???
Posted on Mar 31, 2008
X2250 won't print form pc
A technique to improve print quality is to try and clean the cartridge nozzles. You may clean the cartridge by following the steps given below:
1. Go to the "Lexmark solution center." This can be done by clicking on "Start," go to "Programs" and Lexmark printer group. Click on the "Lexmark Solution center." Next click on the "Maintenance" Tab.
2. Select "Clean and Fix Horizontal streaks." Click on "Print". This will produce a printed page.
The colors that you should see here are black, yellow, magenta (a reddish purple) and cyan (a dark sky blue). You should notice the diagonal lines above and below the solid horizontal lines. These diagonal lines should be solid from left to right with no gaps.
If there are gaps in the lines or the print diminishes across the page, you should run the "Clean Print Nozzle" page a couple more times to try and clear it up. If you still have gaps at the top and bottom, you should "wick" the cartridges by following the steps given below:
1. Please open the "Solution center" again and go to the "Maintenance" Tab.
2. Select "Install color/black cartridge" and remove the cartridge or cartridges from the printer.
3. Get a damp paper towel.
4. Set the ink cartridge right side up on the damp paper towel so that the ink nozzles are against the towel and hold the cartridge in this position for about 15 seconds.
5. Now wipe the print head (on the bottom where the ink comes out) across in one direction only (left to right) until it looks clean.
6. Next dab the cartridge on the towel to make sure that the ink is flowing.
7. Snap the cartridges back into the printer.
8. On your computer, select "Old Cartridge install."
9. Repeat the "Clean Nozzle Page" one more time. If this fails to address the problem the entire procedure may need repeating.
Good Luck!!!!
May 01, 2013 | Lexmark X2250 All-In-One InkJet Printer
Horizontal lines. Xerox 6505DN
clean the print heads and align them
Sep 10, 2012 | Xerox 6505N AllInOne Printer
My cyan colour won't print : tried aligning page, everything, can you help?
Try to do the Deep Clean Printhead function on your printer to force ink through the nozzles and clean possible clogs and dirt.
Feb 11, 2012 | Lexmark Office Equipment & Supplies
Lexmark p4350
Try to align the cartridges using the Lexmark software installed on your computer to fix the problem. Please follow the steps below:1. On your computer, go to Start menu.2. Go to Programs.3. Go to Lexmark P4300 Series folder.4. Select Lexmark Solution Center.5. Select Align to fix blurry edges. Your printer will then print a page that will align your cartridges.
Try to print your document again to verify that the problem is fixed.
Dec 27, 2011 | Lexmark P4350 All-In-One InkJet Printer
I have a Lexmark x6170 all in one printer. I have never had any problems until recently. I bought a Toshiba laptop and installed my Lexmark. I purchased new cartridges from Staples Office Supply and...
Run the printer software to do an "alignment" -- basically, it prints one page,
and then you scan the page, and the printer reads the printed page, to measure the "offset"
from where the BLACK versus the COLOUR ink prints. It will then electronically adjust the printer.
May 14, 2011 | Office Equipment & Supplies
Hi. I cant get my printer to allign. I've just replaced the black ink cartridge and when i put the allignment page inside the scanner it wont scan
Did you try to align the unit manually or with the computer?
Alignment page does not print
1 Make sure you remove the sticker and transparent tape from both print
cartridges.
2 Make sure the color print cartridge is secure in the left carrier and the black
print cartridge is secure in the right carrier.
3 Make sure you loaded the paper correctly and did not force the paper into
the printer.
Aligning your print cartridges without a computer
Make sure you follow the steps on the Setup sheet to complete hardware
installation. Continue with the following steps to optimize print quality.
1 Make sure you have loaded paper into the paper support, and then press
and hold Scan for three seconds. For help, see "Using the control panel"
on page 4.
An alignment page prints.
2 Place the printed alignment page onto the scanner glass.
3 Press Scan. For help, see "Using the control panel" on page 4.
Once scanning is complete, your print cartridges are aligned for optimal
print quality.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it and give a testimonial for my response.
Thanks, Joe
Nov 15, 2010 | Lexmark X2550 All-In-One Printer
After refilling my black cartridge, my lexmark X7170 AIO (on printer copy setting) prints out a blank page even after printing an alignment page showing black bars & blue dashes (no other colors?) I...
Try to print some more pages. The ink will take time to go down as it is not free flowing. This is due to the air beetween the new ink and the old ink, after some printing the air is push out and then you can have a clear print.
Sep 11, 2010 | Lexmark Office Equipment & Supplies
Replaced lexmark carttridge for printer problem
here you go the instructions out of the user guide this should help
Aligning the print cartridges
Load plain paper.
2 Open the Solution Center.
3 From the Maintenance tab, click Align to fix blurry edges.
Maintaining the printer
52
Click Print.
The alignment page prints.
5 Open the top cover of the printer.
6 Place the printed alignment page facedown on the scanner glass in the lower right corner, and then close the
top cover.
1 2
7
Press .
After a few seconds, an Alignment Success dialog appears on your computer screen.
8 Click Close.
9 Click Exit.
If you aligned the cartridges to improve print quality, print y
Oct 23, 2009 | Lexmark X2500 All-In-One Printer
Lexmark x2650 after scanning computer will not save photos
Mohammed Mohiuddin
Bangladesh
+8801818788171
Lexmark X2650 Print problem…………
Fast time Print comment come Print the Alignment page
click print to pritn a page that will help you align and achieve the best quality.
I click print next come resend the print job
the recent print acrtidge chage modifed the forme of your print job.
evry time i print same problem. please solution & solve this problem.
my email : systemengineer_08@yahoo.com
Nov 08, 2008 | Lexmark Office Equipment & Supplies
Won't Print!!
Hi again,
For some reason our chat session has ended. Pls accept my apologies for any inconvenience. I will post here should you have further questions. Again, my apologies.
Apr 20, 2008 | Lexmark X6150 All-In-One InkJet Printer
Lexmark X5150 All-In-One InkJet Printer Logo
88 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
