Question about Vacuums
Hoover Upright Part # Help
What is the right hose holder for Hoover Upright
U5465-900, S/N 089700021337, 36433111 or 36433137?
Thanks
    President:
  • 1,673 Answers
The difference is that the late model was has extra support on it then the earier one. Most likely either would work, but the late one is better. The 36433111 is the earlier version.
Posted on Mar 22, 2008
SOURCE:
Please advise how I access the motor assembly on a Hoover upright U6317-930? Thank you.
turn the light assembly on the front one half turn to the right to release the belt then remove the brush holder it tilts out then remove the hidden screws on the front and the bottom of the case
Mar 15, 2018 | Hoover Vacuums
I just purchased this Hoover Steam Vac and am putting it together. The screws that attach the top piece to the bottom piece have washers that are stuck part way on the screws. Now I can't attach the...
I have assembled many of these machines, and have never seen any washers. There should be a small plastic bag containing two long bolts, two nuts, and a small self tapping screw. The bolts go through the handle assembly from the front, and the nuts fit into the upper hose holder from the rear ( you will see two hexagonal holes for them). The small screw holds the lower hose holder to the lower rear of the machine.
Jul 06, 2011 | Hoover SteamVac F5914-900 SpinScrub...
This will be the dumbest question you ever got, but where does the hose attach on the Hoover PowerDrive Supreme self-propelled vacuum cleaner? Thanks.
Hello. The hose attaches on backside of cleaner right in the middle. (it twists in the opening) If you are talking about the other end, it attaches at the lower right side(if standing behind cleaner) of cleaner. I hope this helps! let me know
Aug 06, 2009 | Hoover U6441-940 WindTunnel Bagged Upright...
Hoover Mach 3 (Fusion): Dirt Will not enter dirt cup
The dirt in my vacuum keeps getting stuck into the hose and dosent reach the chamber, its a constant problem even if i clean out the clog!!
Jul 31, 2009 | Hoover Elite Rewind Bagless Upright...
Hoover Savvy wand holder upper how to replace it
if you look at the bottom of the holder on the inside you will see a tab just take a small pocket screwdriver and pull out on the tab it should come off.the new one will just snap in
Jan 26, 2009 | Hoover U8171-900 / U8172-900 / U8173-900 /...
Installing belt on hoover self propelled upright vacuum
http://geeksquad.fixya.com/ThreadView.aspx?prdid=40544&thid=641399
Installing belt on Hoover self propelled upright...
Posted by Fryeburger on Jun 02, 2008
Need help installing belt on Hoover self propelled upright vacuum
I would advise you to ALWAYS to FIRST UNPLUG YOUR VACUUM before beginning any service procedure. Hoover Ultra U6430-900 Wind Tunnel Bagged Upright. The best way to install the belt on a Hoover to replace one or both of the belts @ the same time for the best cleaning. The average belt change is every 4 to 6 months for best results. There is a tool that looks like a screwdriver that has a right or left angle on the end that serves as a belt puller and to hook the belt(s) onto the brushroll 1st and then take your puller and then pull or stretch the belt onto the motor pulley. So if you need further assistance, please feel free to contact your local vacuum cleaner dealer in your area or in the yellow pages, or contact the factory phone number or website to further assist you with your questions.
http://www.hoover.com Telephone
Contact our Customer Service Department at 1.330.499.9499
Monday through Friday
8 a.m. - 7 p.m. EST
http://www.a-1vacuum.com/ 1-800-657-1874 Customer Service
Thanks, Don the Vac Man
Go Ahead. Use Us.
Jun 02, 2008 | Hoover Ultra U6430-900 WindTunnel Bagged...
How to install front wheel assembly on Hoover Bagless windtunnel vaccuum
There is a spot that sticks up on the holder for the wheels, the hole in the spring goes there, then it fits between the holder and the base asm.04f5295.jpg
Feb 24, 2008 | Hoover U5753-900 WindTunnel Bagless...
Vacuums Logo
Top Vacuums Experts
AskDyson
AskDyson
D. Floyd Kolb
D. Floyd Kolb
Are you a Vacuum Expert? Answer questions, earn points and help others
