Question about Frigidaire ATF6000ES Front Load Washer
Frigidaire FTF2140EOS won't start
I have the front lower panel off and the alarm code list that is in the envelope taped inside. but how do I get these error codes? There is no display on the washer, just led's.
It finished its last cycle fine, but when next loaded it just beeps three times and the lights all flash. Only 3 yrs old.
Call Frigidaire.They are great!
Posted on Mar 24, 2008
Location serial number
I have usually found the s/n inside the topt door. Open the lid and look for a sticker around the rim, often front left. Next favorite hiding place: On the back of the rear panel, somewhere near power cord or water hose inlet. Another location: On the fame under the lower front panel if you have one. Try the easiest place first. If you are desperate, find you original sales slip from the dealer - it might be on the paperwork. I keep all of mine in a plastic envelope and tape it to the side of the machine. Try this also: The Samurai Appliance Repair Academy
Jul 16, 2014 | Washing Machines
Show me wiring on the control panel
It's located on a sheet in a plastic envelope taped to the inside of the lower cabinet
Apr 01, 2014 | Whirlpool Cabrio WTW6600SBT Top Load...
Do you have an instruction manual for a micromark mm 23062
No,I don,t have one,but untill you find one unplug the alarm horn,maybe in front of radiator,simple to do,or cut wire and use elect tape on ends so they won,t short out,Now buy a led blinking fake alarm,e-bay ? 8 bucks ?tape it up inside under dash,now start looking for the company that makes your alarm..
May 10, 2012 | Cars & Trucks
When i press the start button it gives me an f 70 error?
F70--Central control unit heartbeat failure
Tip unit back nd remove the lower panel, there is a tech sheet either n that panel or inside on lower right... will list all codes and what to check
Jan 06, 2011 | Whirlpool Duet GHW9150P Front Load Washer
Washer spins while washing, it will also drain with no issue but will not do the final spin? help!
Any error codes? Try putting it in diagnostic mode. You can test different cycles and retrieve error codes. Instructions should be taped in an envelope to the inside of machine. You may have to remove the bottom front cover to find them.
Most likely cause - Faulty door switch.
Oct 08, 2009 | Frigidaire GLTF2940ES Front Load Washer
GLTF2940 My washer goes through all cycles but won't spin
I had the same problem with my washer. Frigidaire model GLTF2940ES1. It's a front load. Now I'm not the type to stare at it and then call the repair man, I hate spending more money on something when it already costs an arm and a leg just to buy one. So I started digging around, I pulled the thing apart and looked at this and that. It would go through the cycles just fine, except it wouldn't do the fast spin. So, while pulling panels off, I noticed an envelope taped to the inside of the washer. It was the "Washer Tech Data Sheet" and in it, it will tell you how to get the error code from your washer and then basically tell you whats wrong with it. On models with an LCD display, you push any button to "wake" your machine up,then you push START and PAUSE/CANCEL simultaneously, and after a few seconds an error code will display. Mine was E47. With E47, your board thinks the door PTC circuit is open during spin. It then says to Remove door lock assembly and measure the resistance of the PTO. This I don't know how to do, and I don't know (yet) what PTO stands for. But, this all boils down to your door lock assembly. For the "corrections" part it says to do the following...first, replace the door lock assembly, you can do this yourself, but you have to take off the top panel of the washer. Then, look down and you can see it, it has 3 wires, disconnect them and pull it out. Buy a new one, and put it in. really easy. BUT, if this doesn't fix your problem them chances are its a defective control board. And that, I don't know how to fix. (yet).
Feb 05, 2009 | Frigidaire GLTF2940ES Front Load Washer
Is there a place online that lists the error codes for Frigidaire
There are several websites with error codes listed. I have not seen any codes listed for frigidaire dryers. So I checked at Frigidaire.com had no luck there either. 800-374-4432 is their customer service number. I found codes for Frigidaire cooking products but nothing for dryers. Good luck.
Jan 05, 2009 | Frigidaire GLGQ2152ES Gas Dryer
Duet whirlpool
I don't remember what an f-du code stands for, but I will give you the next best thing. There is a list of the error codes and steps to correct the problem right inside your machine.
Remove the lower front panel. (there are 3 #20 torx screws on the bottom of it holding it on). Once you remove the panel, turn it over. There in a sealed plastic envelope will be your technical manual and trouble shooting steps to correct them.
Good luck and drop me a note if there's anything else you need.
Jul 14, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Error code E10
tech sheet located inside behind lower panel on left.
Apr 03, 2008 | Frigidaire GLTF2940ES Front Load Washer
Frigidaire affinity dryer problem
message "ad" showing on my affinity frigidaire, anything wrong with this?
Apr 01, 2008 | Dryers
Frigidaire ATF6000ES Front Load Washer Logo
315 people viewed this question
Top Frigidaire Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
