There is only one lamp in this model set. You can tell when its worn when the unit intermittently shuts down while watching or the picture is not as bright as it used to be. The lamp compartment is usually located on the right side of the unit, there you will see a small compartment door access. Remove the screws and the Lamp will be visible, you might see two screws on both sides of the lamp or a handle to just gently pull the lamp out.
XL-5100 XL-5200 XL-5300
This page shows Lamps and bulbs for all Sony LCD Projection TVs
Sony Lamp Gallery
Look at Optical Engine Faults before buying a lamp or bulb. Replacement bulb will not repair these problems.
