Question about Sharper Image Ionic Breeze GP SI730 Air Purifier
Blinking blue light on ionic breeze s1871
I have the ionic breeze s1871 air purifier and the blue light on top blinks  continuously and the air purifier doesn't seem to work. Is this thing broken?
Thanks,
Jim
  • 11 more comments
  • bigredd Mar 23, 2008
    If light blinks constantly the unit is broken and needs to be returned for credit or replacement...
  • Anonymous May 08, 2008
    Blue light flashing even when unit is turned off.
    It is unplugged until we can get an answer. Ron
  • TerryRedCad Jun 14, 2008
    blinking blue light, unit not working
  • cavagility Jun 17, 2008
    I got my ionic breeze two christmas' ago, and my light is also blinking blue. I clean this unit every week and fully take apart once a month to clean it thoroughly. The owner's manual gave me no info on what the blinking blue light meant. What a waste of $300! I emailed Sharper Image and received an email stating that they went bankrupt and I was S.O.L!
  • jwilks Jun 24, 2008
    This is unbelievable, everyones are dying at the same time just as Sharper Image is Bankrupt. No wonder, probably to many returned Ionic Breeze's. I wonder if there is a reset or a fuse or something?
  • zeuszeus Jul 03, 2008
    Yeah, my light started blinking also. I got it from the outlet center, it was used but okay for about two years, now it blinks....what to do? Is it working or what? Should I turn it off now? I clean it all the time but it still blinks. I got one from the outlet for my mom also but hers is not blinking.....
  • Anonymous Jul 16, 2008
    Same problem- 1.5 years old. Blue blinking light of death!!!!!
  • toolmacon Aug 17, 2008
    blinking light fix, we need one!
  • puzzledone Aug 24, 2008
    Blue light for room size blinks when plugged in. Nothing else works. Have cleaned as usual, nothing different was done. Is my extended warranty with Sharper Image worth anything now or was that money down the drain?
  • bethmcdowell Nov 05, 2008
    I have the same problem. Mine is only 3 months old.
    Does anyone know what it is???
  • Senaguzy Nov 06, 2008
    I have the same problem on one of my two S1871 GP Silent air purifier from Sharper Image.  Mine does seem to still be working, but the blinking is annoying.
  • havocwreaker
    havocwreaker Dec 16, 2008
    Unbelievable, I have the same flashing blue light. I have two units in my home and only 1 is doing this. I pulled out the manual which is pretty useless, and the customer service number 1-800-344-4444 is not working. Worse yet, their site is under construction so I can't access it. Luckily I found my paperwork for it and I bought and extended warranty w/no hassle replacement.
    I bought my two units back in Jan 2008 if that helps anyone determine MTBB.
  • missy2105 Dec 26, 2008
    Mine is also blinking blue. Mine is still under warranty and I can't find anyone who is honoring The Sharper Image's warranty policy. Does anyone know who I can take it to or how I can fix the problem myself?
Wher can you return it? Does anyone have and address? My Dads unit has a blinking blue light and the folks at sharper image say to bad so sad only after 2 months out of warrenty. Is there any one out there that can help? I am done buying things from Sharper Image with their attitude! [email protected]
Posted on Mar 25, 2008
  • Lynn Kent Dec 04, 2013
    The new Sharper Image is a different company than the one that made most of the air cleaners.
    New Friend:
The blue light keeps blinking
Posted on Nov 30, 2009
SOURCE:
The blue light blinks
I believe that a blue blinking light indicates that the stainless steel collection blades need to be wiped clean. The unit uses these blades instead of a replaceable filter. Simply wipe them clean with a damp cloth and you should be ready to go!
Jun 24, 2010 | Sharper Image Ionic Breeze 3.0 Air...
WHAT ARE THE GREEN AND BLUE LIGHTS FOR
To let you know when the ionic breeze is working properly (Green Light) and when it needs to be cleaned (Blue light). Hope this helps.
Apr 19, 2010 | Sharper Image Professional Plus Ionic...
There is a red blinking light and it is not cleaning.
My Ionic Breeze would work for a short time after cleaning and the blue light would start flashing and the unit would stop working. I checked the wall cube power adapter with a volt meter. It was putting out only 10 volts instead of the needed 12 volts. It seems The Ionic Breeze needs a full 12-13 volts to work. So I went to Radio Shack and bought a universal 12 volt 800ma power adapter. I checked the voltage in the new adapter, it was 13 volts. This fixed the flashing blue light problem. However the Ionic Breeze produces harmful Ozone gas, so I don't use it anymore.
Aug 09, 2009 | Sharper Image Professional Plus Ionic...
Ionic breeze quadra s1857 Red light continues to blink needs cleaning even after cleaning. not filtering. help
Mine is a Pro-series Quadra. It needed better cleaning.
The front and rear plastic grill scome off (release catch at the bottom of each), allowing access to the central core. I cleaned it with a damp rag (let it dry before you turn it back on). Be very careful of the two wires running the length of the unit -- if you break these it will not work. I did, however, gently clean them.
When I restarted it there was an unusual smell for a few minutes, but all is working well again.
Apr 13, 2009 | Sharper Image Ionic Breeze® Quadra® Air...
Ionic Breeze Table Top Purifier
Sharper Image has recalled the product line. They lost a lawsuit with Consumer Reports after they couldn't prove that they did clean the air. They were ordered to pay all legal fees forcing the company into chapter 11.
Consumer Products Safety Commission is going to issue a report on all ionizers by the end of the year. It's expected their decision will stop sales of all ionizers in the U.S. EPA data has already proven their use not only to be ineffective but harmful to use as well.
Sep 18, 2008 | Sharper Image Professional Plus Ionic...
The blue light on my ionic breeze is blinking.
The ionizers were recalled by Sharper Image due to a lawsuit that they lost forcing the company into chapter 11.
There is a thread on this website with further details.
Sep 13, 2008 | Sharper Image Professional Plus Ionic...
SHARPER IMAGE AIR CLEANER HAS STOPPED WORKING, NO BREEZE COMING FROM UNIT AND BLADES ARE NEVER DIRTY. THE "ON" LIGHT IS ON.
Sharper Image no longer supports Ionic Breeze machines. They recalled them a few months back since Consumer Reports and the EPA has determined that they weren't working and can even cause health hazards during usage. Sharper Image sued an lost forcing the company in bankruptcy.
The Consumer Products Safety Commission is going to make a decision on sales of all ionizers in the U.S. by the end of the year. It's looking like you won't be seeing these around much longer.
Jul 06, 2008 | Sharper Image Ionic Breeze Air Freshener...
Ionic Breeze Silent Air Purifier GP
Ionic Breeze products are no longer being supported because Sharper Image has gone into bankruptcy because the units were proven to be ineffective for cleaning the air by Consumer Reports magazine and by EPA studies. In face they have proven that ionizers can be harmful to use if you have breathing problems.
Here is an article about Sharper Image
Here is the EPA article
Jun 30, 2008 | Sharper Image Professional Plus Ionic...
Sharper Image Ionic Breeze GP SI730 Air Purifier Logo
2,346 people viewed this question
Top Sharper Image Air Purifiers Experts
Ekse
Marvin
Marvin
Jason
Are you a Sharper Image Air Purifier Expert? Answer questions, earn points and help others
