SOURCE: SHOW ME HOW TO PAIR N70 nokia phone
first go to bluetooth option then select search device then select that device then pair then enter the password 0000 or 12345 and then done
SOURCE: my nokia n70 bluetooth is
hello,it could be as a result of two things,
1.you are not setting your bluetooth device properly,visit the settings part of your phone then you go to bluetooth settings to make sure it is put on and also has its visibility to other dvice kept on so as for it to function as supposed,if not done properly it will not connect with other devices
2.a corrupted bluetooth device,if this happens you will have to flash the phone with the use of internet and cables and this could only be done by an authorized mobile phone repair man.if he does the flashing i guess the phone can work but it's on a 50-50 basis.
wish you good luck,
take care.
my new n70's back camera is not working .I slide down the lens cover of the back camera to activate it but it is is not working properly .sometimes it is activated after several minutes , but sopped authomatically.my blouthooth is not also working properly.what can i do?
camera always comes on standby mode& while using bluetooth it always comes as operation failed
