Question about GPS
TOMTOM 510 locks up
My TOMTOM GO 510 keeps locking up. Only the backlight in the LCD is illuminated. You cannot reset the device until all the battery power is exhausted. Once is has totally discharged you can then reset the device and it will continue to work for an indefinite amount of time. Then it will lock up again.
Try to upload new maps on the unit
Posted on Jul 09, 2008
SOURCE:
Is there a reset button on a go 510 live
Yes, the reset button is actually a small hole at the base/bottom of the unit. You'll want to use a straightened-out paper clip or something similar to put into the hole and press it for a few seconds (until the unit powers off) .... after you've fully charged your battery.
Jan 04, 2013 | Tomtom GO 510 GPS Receiver
MY TOMTOM GPS NEED TO BE TO RESET
I will advice you reset the unit, this might help fix the abnormality with the white screen problem. follow these procedure to reset your tom tom gps.
Make sure your battery is charged before you begin. TomTom suggested allowing your device to charge for at least 2 hours before resetting it. Remove your device's SD card from the card slot.
Find the "Reset" pinhole button on the bottom of the device.
Hold the "Reset" button down for 10 to 15 seconds or until your device resets itself. You will need a flattened paperclip or another small metal object to reach inside the pinhole.
Power the TomTom back on and insert your SD Card. You have now reset your TomTom gps and this should fix the white screen problem.
Take care.
Jun 28, 2010 | Tomtom GO 510 GPS Receiver
Tomtom 510 doesn't reset
Before you keep resetting your tomtom I would intall a new battery. Call your closest "batteries plus store" or "radioshack store" and then try to reset it, it might be only the battery and nothing to do with the reseting.....
Mar 24, 2009 | Tomtom GO 510 GPS Receiver
Safety lock
Yes, I too have experienced a problem with locking up when I take my TomTom 910 out of the dock after being connected to my computer. I also took my TomTom back to shop and was shown how to do a Hard Re-set on it. Firstly, you have to locate the reset button (which I see you have. Why it is hidden away in such an awkward position I don't know. I carry a pin/paperclip around with me for this purpose!) Press the reset button once until the TomTom screen switches off. Then with the TomTom off press AND HOLD DOWN the On button on top of your TomTom. Keep holding as white computer script appears on the screen. Carry on holding down until the remainder of the script appears to almost fill up the screen with script info and then this stops. Then release the On button and the TomTom icon will appear. After 2 to 3 minutes the TomTom should switch to show the current location map and look for satellites. Locking on to satellites can then take up to 15 minutes by the way.
Hope this helps.
Good Luck!!!
neo
Feb 27, 2009 | Tomtom GO 910 GPS Receiver
GO 510 WON'T COME ON . CONNECTED TO COMPUTER STILL WON'T COME ON
Have you tried?...
My TomTom device won’t turn on. How can I reset my device? = www.tomtom.com/7134
Jan 10, 2009 | Tomtom GO 510 GPS Receiver
Frozen tomtom
You can get your original splash scren from here. You can also download free splash screens created by user through TomTom HOME.
To correct your device, try:
1. Hit the reset button on the back of the device - inside the serial connector.
2. Make sure the device is off and connect it to your computer via USB dock and connect the charging cable (green light should be on)
3. Hold down the power button until the device restarts.
4. The device should automatically connect to your computer.
5. Run TomTom HOME and check for any updates.
6. If there is no new application, try: www.tomtom.com/9091 <-- that will show you how to remove and then reinstall the application.
Dec 22, 2008 | Tomtom GO 510 GPS Receiver
My 510 locks up will not turn on or off
look for a small hole which should be a reset switch, get something thin, like a pin or stiff bit of wire and put in the hole, you should feet it click. this should reset the unit, but will keep all stored data, favourites, etc
Oct 07, 2008 | Tomtom GPS
How to updste the software of tomtom go 510
The TomTom go 510 won't turn on even reset the unit. in this case, it still can update the software? I need help.
Aug 14, 2008 | Tomtom GO 510 GPS Receiver
My tomtom go510 will not turn on
I did get it going again ,i hit the reset buttton and it started working again thank you for getting back with me rtrailbuster''
Jun 28, 2008 | Tomtom GO 510 GPS Receiver
Is there sonething wrong with my tomtom go 510?
Usually resetting the unit (pressing the reset button) is supposed to fix this
Oct 22, 2007 | Tomtom GO 510 GPS Receiver
GPS Logo
102 people viewed this question
Top GPS Experts
Marvin
Marvin
Andrew Taylor
Andrew Taylor
Are you a GPS Expert? Answer questions, earn points and help others
