I bought a new ceiling fan like this and put it in the kitchen and the chain switch won't work, so I turned off the power, opened the fan, and connected the wire to the high speed wire because kitchen gets hot, and turned the power back on and the fan turned on high. I needed to turn off the fan for cooking so the flame won't blow away so I did it by moving the reverse switch in the middle. It's annoying and it's easier to just pull a chain 3 times. I need a chain switch for free.
To get a free switch you will have to take it out and take it back to where you bought it and they will replace it or just take the whole thing back and get a brand new one because of the switch. thats the only way you will get a free switch.
You bought the wrong switch. Just because it looks the same on the outside doesn't mean it's the same on the inside(switch). I don't know if you have a bad motor but it is a cheap low-end fan only made for Home Depot!
if the ceiling fan work regularly ,it only have one wire .but it has 3 wires . so you should cut two off .which should be cutted of ..you should switch the wire one by one . ceiling light
You will need to replace the pull cord switch. It is inexpensive. You will need to open up the fixture and reemove the old one. Usually it is held on with a nut. If you are not sure of what switch to buy, take out the old one and bring it to a hardware store. Make sure the power is off. Cut the two line to the old switch and splice in the new switch with wire nuts, also use some electrical tape to insulate the connection. Reinstall the nut and close up the fixture. Good luck.
The pull chain for fan and the pull chain for lights are wired separately. If you are talking about a wall switch, add a comment with clear description of old switch and new switch, screw colors on each switch, and color of each wire for possible help.
To replace chain switch with a new one (available at a hardware store), first turn off power to the fan. Unscrew the nut on the bottom of the fan which holds the coverplate in place. Find two wires going to the switch, pull them out of the enclosure, take the wire nuts off. Now you can take the old switch out by unscrewing the locking nuts that hold it in place. Put the new switch in by reversing the instructions for removal.
Good Luck.
There is a pull chain switch inside the fan termination housing. you will have to take the little cover off and remove the switch. it has 2 small screws with wire landed under them. Turn off the power at the breaker before working on the switch. take this little ****** out and put in a new one. you can get them at the Home Depot or equivelant. it don't matter if the new switch is a little bigger but it still has to fit. use some judgement here. wire it in the place of the old one, turn the power back on at the breaker and it should be ready to go. Presto.
either one all it does is complete the circuit. only one wire is broken to open the circuit when you cut it on and off you just open and close the circuit with one wire.
I saved this text I found when I was researching this a while ago.
Let us know how you do.
Wiring a three speed fan switch
My daughter called me the other day and said Dad the ceiling fan in the kitchen is not working only the light works. I went over and removed the three screws that hold the light and pull chain for the fan down and found that the fan control switch had snapped open and all 4 wires had popped out. The snap clips on each side of the switch had broken off. I went down to Home Depot in the ceiling department and found the switch I was looking for. It said for a four wire ceiling fan. OK, know lets put it back together. First of all if you look at the new switch you should see four holds were the wires will be pushed into. The black wire in the fan is the hot or load wire, this wire is hot whenever the wall switch to the fan is turned on. Put this wire in the hole that is marked “L” this stands for load. Now with this switch in the off position the fan will not work until you pull the chain. The other three holes are marked #1, #2 and #3. On most fans #1 is usually high speed. # 2 medium and #3 low speed. What you now have to determine is what wires are high medium and low. The easiest way to do this is before you put any of the wires back into the new switch is to FIRST MAKE SURE NO POWER IS GOING TO THE FAN. Then simply take one of the colored wires at a time and twist it together with the black hot wire. Turn the power back on to the fan and knot the fans speed. Do this with all three wires one at a time until you can determine which wire is high speed. Note the color of the wire and mark it down on paper.(Example; blue wire high speed.) Do this with the other two wires to determine there speed. Once you have the speed of each wire you can reassemble the new switch.
Black wire (Load) goes in hole marked L. High speed wire goes in hole marked # 1. Medium speed goes in hole marked #2 and low speed goes in hole # 3. MAKE SURE THE POWER TO THE FAN IS TURNED OFF WHILE YOU ASSEMBLE THE NEW SWITCH.
For those of you that have all these wired hooked up right and still the fan won't work I would then look for an open neutral wire. It should be a white wire. Check to see if all the wires are securly attached.
Good luck. One more word of advice. If you're not sure on what you are doing when it comes to electrical wiring then please do not attempt to do this or any other electrial work yourself. Call a licensed electrian. Any mistakes on your part could void your home owners insurance in case of a fire.
I traded the lemon switch with the new one. It finally worked!
