Question about Kenmore Elite HE4 Electric Dryer
Kenmore HE2 Dryer makes three beeps but wont start
I have a HE2 dryer by kenmore, there is power to the unit it lights up. the other night I did a ton of laundry, when i took the last load out I noticed that the light burnt out. Today I went to put a load of laundry in and turned it on then it wouldnt start, it only beeps three times, powers up and all. I tried unplugging it and repluging it in and flipped and checked the breaker. Could it not work because of the light? that sounds like it wouldnt be that but ive seen some crazeier things. any help would be appreciated we dont have the money to call a repair man and were out of warrently of course. Had I known other people had problems with his dryer I would have never bought it...
  • 3 more comments
  • gmv380 Mar 22, 2008
    Hi all - I have a similar problem, however, my Kenmore Elite dryer will turn on a run for various times before it beeps three times shuts off. I can push the start button and the dryer will resume running - only to shut off again several (or maybe even 10 to 15 minutes later) before repeating the same scenario. It's confusing because there is no set pattern. I just finished cleaning the ducts so I'm sure their not the problem. Also cleaned out the front duct by the lint basket. Positive I'm getting good airflow. In addition, I scrubbed the moisture sensor located on the inside surface of the tub. Any ideas?????
  • Anonymous Mar 27, 2008
    My dryer also makes three beeps, and the light inside is also burned out. Can this really be the problem?
  • fuzzbunny Jul 05, 2008
    My problem is the same as Larisa98277's. The dryer light blinked off and on for a few days. Then went completely out yesterday. This morning the dyrer won't come on. The power light comes on, but it beeps and won't start when I press the start button. The lint filter light doesn't come on either. When we checked the dryer light it had shattered. We replaced the light and now it stays on constantly.
  • KellyMP Aug 02, 2008
    I have the same problem. I purchased my HE2 in July 2006 in Ontario, Canada. Today when I tried to start it I got three quick beeps and no action. I tried every setting, I unplugged the dryer for both 1 minute and then over an hour. As with other people who posted, the light inside the dryer was burned out. I replaced the 10W bulb with a 7W bulb and still no luck.
    At this point I believe it is a micro-switch that indicates whether the dryer door is closed or open. If open, it prevents the dryer from starting. Since the light stays on, even when the door is closed, it is probably the switch.
    I've called Sears and arranged for a service appointment for next Thursday (5 days away). Cost of the service call: $77.00 plus taxes, plus the price of parts. I'll let you know how I make out.
  • Anonymous Aug 23, 2008
    Same problem - light burns out, and then a few days later, the unit powers up and then makes three beeps when trying to dry. I'll try a new lightbulb. Thanks,
What happens is that the door switch gets turned inside. I just took mine apart because of the same problems listed. The switch has a tab inside that has to make contact with the internal switch. I pulled mine apart and turned it so it made contact...put it back together and it works fine now. After doing all that it seems like you could turn the swith from the outside a quarter turn with a pair of pliers and accomplish the same thing.
Posted on Jan 05, 2009
  • Michael Frias
    Michael Frias Jul 25, 2014
    Just to update. found above info helpful. Changed the light bulb, once that was done the light wouldn't go out when the door was shut. door switch problem. popped the ruberized light boot and switch out of the front of thefront opening, reset until light went off, and tested. The dryer came on, and it is working fine. The switch just pops out with a screwdriver.
My Kenmore He2 gas dryer has the same problem. It makes 3 beeps and wont start. The check lint screen light also doesn't come on. However, the door switch seems to function normally to turn on and off the inside appliance light when the door is opened and closed. Is it likely that this is still a problem with the door switch?? I may just end up buying a new switch to see if it solves the problem. Peter
Posted on Aug 21, 2010
After reading other problems on this board, it seems that the door closure switch is a common failure point.  The common theme is the dryer interior light burning out.  The door switch fails, so the light stays on, and burns out.  Then you try to do a load and the dryer will not start due to the switch not making contact.
Ours just started doing the same thing, and I am betting this is the culprit...
It could be an intermittent problem too.
Posted on Jul 12, 2008
    New Friend:
  • 23 Answers
Three beeps from the Kenmore Elite electric dryer may be caused by a failed thermister which sends the heated air temperature signal to the control box. The thermister inserts into on the air duct under the drum near the front of the machine. (two screws and two wires)It is easily removed and tested using an ohmmeter and hair dryer. The resistance of the device changes as it is heated and cools. With my dryer the the dryer would run for awhile and than stop and signal three beeps.
Posted on Sep 27, 2014
    Problem Solver:
  • 4 Answers
You can also see if the door is not completly closing. Make sure to push it in hard around the clasp areas. If yours has a light, the light should turn off and on as you open and close the door.
Posted on Mar 20, 2009
I fixed this problem by doing just what stimpee suggested  . Picked up the door switch and a light bulb at Marcone ,Total cost---$20 Thanks
Posted on Aug 08, 2008
2 Suggested Answers
SOURCE:
SOURCE: Kenmore HE2 Dryer makes three beeps but wont start
Check your door closer switch. Mine was doing the same and it turned out to be as easy as changing the switch.
Posted on Mar 27, 2008
Sears Electric Dryer is flashing F01 What is wrong?
The F01 indicates a failed electronic machine control board. This error code can sometimes be caused by a glitch or power surge through the electrical lines. You may be able to clear this code by unplugging the washer for 5 minutes. If the code returns after plugging the washer back in, then the electronic machine control board will need to be replaced.
You can order a new control board from the Sears PartsDirect website.
http://www.searspartsdirect.com/partsdir...
Here's how to do it: http://media.fotki.com/1_p,wkwdftgtbkdgf...
Error code on dryer F01 - Kenmore Elite HE3 Dryer - iFixit
https://www.ifixit.com/.../Error+code+on+dryer+F01 Traduire cette page The F01 indicates a failed electronic machine control board. This error code can ... The Kenmore Elite HE3 is 7.2 cu. ft. capacity electric dryer by Kenmore.
Dryer Sears / Kenmore HE3 - F01 Error Code Main Circuit ...
2q==? 7:35 https://www.youtube.com/watch?v=eWqrn5klxm0 20 avr. 2015 - Ajout? par Jim Dandy Sears Kenmore Dryer Model HE3 - F01 Error Code. Main Circuit Board Repair - Electronic Control Board ...
Error code F1 on Kenmore HE2 electric dryer appeared ...
www.shopyourway.com > ... > Questions Traduire cette page Sears Kenmore HE2 electric dryer; model #11087571601. F1 error message appeared ... Power it back up and see if you still get the F01 error code. If not, then I ...
What does the error code F-01 mean on my Kenmore front ...
www.shopyourway.com > ... > Questions Traduire cette page By unplugging and plugging in the electrical cord, I got the dryer to work again. ... What does the error code F-01 mean on my Kenmore front loaded HE2 dryer? ... My kenmore washing machine 110.46462500 is flashing an error code F.01 ...
Feb 04, 2016 | Sears Kenmore Elite Electric Dryer 69278
I have a kenmore he2 gas dryer,it wont turn on all as it does is beep and also when the door is closed the light still stays on,im thinking it is the door switch ,but want to confirm this first
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor going bad...
Here are a couple of tips that I wrote will help you to figure out why your dryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
May 02, 2011 | Dryers
Kenmore HE2 dryer will not start
the relay for the motor is probable stuck recommend service
Jun 03, 2010 | Kenmore 82822 Electric Dryer
Kenmore he2 electric dryer error code f-01
always unplug for 10 minutes and retry first.
Jun 12, 2009 | Kenmore 82822 Electric Dryer
It appears your thermal fuse has failed in this instance. After the machine begins to warm up - the fail thermally expands, and no longer makes contact.
For replacement parts - head on over to PartSelect.com or RepairClinic.com and enter in your full model number for a full parts listing.
I recommend both sites because ...
FixYa has no affiliation with either site - I have been using and recommending them for years - trouble free.
PartSelect has a great schematic database for locating the part on your unit and great "testimonials" for each part that often times includes HOW-TO information.
RepairClinic has pictures of each part they sell and also a great how-to and troubleshooting for basic repairs.
If your unit has never been serviced - there should still be an original service manual enclosed in plastic taped to the inside of the shell.
In the service manual are Error codes, maintenance procedures, and troubleshooting steps you can follow.
Anything too complicated or beyond your scope should be handled by a professional.
If you think you want to tackle the repair - and have gotten stuck on a step - reply to your question and I will be glad to help you out.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
May 22, 2009 | Whirlpool Duet 7.0 Cu. Ft. Super Capacity...
I HAVE A NEW (3 MONTHS) KENMORE HE2 ELECTRIC DRYER MODEL # 110.8756, IT APPEARS THAT I CAN TURN THE POWER ON, SET THE PARAMETERS BUT WHEN I PRESS START I JUST GET A BEEPING SOUND. THE LIGHT ON THE...
because is a 3 month old dryer is better for a technician to give you a diagnostic because can be a manufactory issue.
If you have any question please let me know.
Was this helpful?
Feb 17, 2009 | Kenmore 62602 Electric Dryer
Mar 23, 2008 | Kenmore 62602 Electric Dryer
The Kenmore HE2 model numbers 8757 and 8758 are the beepers. Everything comes on as normal. You press the start button and it beeps several times and then beeps again, again, and again. It will not start or turn at all. I did notice the drum light was blown. I have not replaced it yet, but could something so simple be the problem?
Ed G
Mar 23, 2008 | Dryers
Kenmore Elite HE4 Electric Dryer Logo
5,711 people viewed this question
Top Kenmore Dryers Experts
Marvin
Marvin
jimorris77
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
