Question about iRobot 4150 Roomba Vacuum
Irobot 415 cleaning brushes don't turn
  • dshinkle Nov 25, 2008
    The brushes stopped turning, they are installed correctly, the robot runs yet nothing gets picked up.
  • 3 Answers
Gears may be stripped in the brush drive line. right off the motor is a gearbox, held on with two screws. getting to it is fairly complicated, fix is easy. parts can be found at Protech Robotics Parts and Service
Posted on Aug 10, 2009
    Sniper:
  • 61 Answers
Run the Roomba without the dustbin. Do the brushes turn at all? If not, call customer support at 1-877-855-8593. Be sure to have the Roomba with you.
Posted on Jun 04, 2009
Discover irobot brushs womt turn
Are they wrapped up with hair, thread, dental floss? If so clean them. Were the brush and beater bar replaced incorrectly in the past? The square end has to fit on the square side, etc.
May 13, 2014 | iRobot Roomba 560 Robotic Vacuum
IRobot rumba 4000 seems to run ok and then starts making a kinda hi pitched growling noise and slows way down. it is very clean(blown clean with air compressor)sensors are clear ,newly installed well...
It sounds like your Roomba's brush gears are not working. Run the robot without the dust bin to see if the brushes are turning. If they are not, the robot will need to be replaced. Contact iRobot CS for support at (877) 855-8593.
Dec 05, 2010 | iRobot Roomba 4000 Bagless Robotic Vacuum
Irobot stops after a few minutes and says plaes
soooo, what is not understood here ?
turn it over, open brushes cage, take each brush out and clean it.
In addition, also clean the sides from any dirt/hair that may stuck in its pivots.
good luck
Avi
Apr 07, 2010 | iRobot Roomba 560 Robotic Vacuum
My Irobot Roomba keeps saying that I need to clean Roombas brushes. I have cleaned the brushes...they are spotless. Still the Roomba will go for 2 minutes and shut itself off stating once again to clean...
Perform the troubleshooting found at the iRobot website: http://tinyurl.com/nh5c8a (I promise that really does go to the right site.) That troubleshooting will enable you to determine exactly what's causing this problem. (The Easy Way: Run the Roomba minus the dustbin and look in the back. Is the brush turning? If not, there's the problem. Give support a call at 1-877-855-8593 and they'll let you know how to replace the necessary part.)
Aug 24, 2009 | iRobot Roomba 510 Bagless Vacuum
My irobot roomba 415 vacuum starts turning then alarms and the red status light comes on.
You need to listen to the alarm so that you can determine what Roomba's trying to tell you. The troubleshooting codes can be found here, at iRobot's website: http://tinyurl.com/md2u9p
Jul 23, 2009 | iRobot Roomba 410 Robotic Vacuum
Bin isn't filling, won't pickup and brushes won't spin for the second time. Last time iRobot had to replace both wheel modules. Any suggestions? I clean it every time I use it!
Wheel modules? It's more likely to be the cleaning head module. Clean your brushes exactly as the manual describes-- particularly the yellow bearings. Run the Roomba on a hard floor without the dustbin. Does the brush turn? If not, call support again and they'll help you out.
Jul 15, 2009 | iRobot 560 Roomba Vacuuming Robot, Black...
Irobot 4100 brushes do not turn & bin is empty but filter is full. does the roomba need a new cleaning head module?
Yes, it probably needs a new cleaning head module, if your bearings are clean and the brushes still don't turn.
Mar 28, 2009 | iRobot Roomba Red 4100 Bagless Robotic...
ROOMBA 415
It could be the power button itself. If you have a Roomba remote, try using that to power on the robot.
Sep 28, 2008 | iRobot 4150 Roomba Vacuum
Irobot moving slowly
Try running th roomba with the dust bin removed to see if the main brush is turning, if not it could be an issue with the gears being stripped in the brush motor assembly or inside the brush compartment holder. If the gears are fine the brush motor itself may be blown. A new one is about $30.00.
May 01, 2008 | iRobot Roomba Discovery SE Bagless Robotic...
iRobot 4150 Roomba Vacuum Logo
367 people viewed this question
Top iRobot Vacuums Experts
Shehu Pro
Shehu Pro
Are you an iRobot Vacuum Expert? Answer questions, earn points and help others
