There's more information there than you need since the article is about garmin nuvi satnavs that display a message "No detailed maps found that support routing" but part of the article deals with locked maps. The principle is the same for the garmin Edge but you'll need to skip to the part that deals with unlocking maps.
Question: What should I do if my Garmin nuvi or zumo displays the message "No Detailed Maps Found That Support Routing" or "No Map Data Available?"
Answer:
The "No Detailed Maps Found That Support Routing" or "No Map Data Available" message may appear on your device for the following reasons:
The GPS device is missing it's unlock code
The maps on the GPS device have been disabled
To determine the cause of the message, touch the screen until the message "No Detailed Maps Found That Support Routing" disappears.
If you see a "Can't Unlock Maps" message following this error, remove any microSD / SD cards in the device and follow the instructions below for Retrieving your unlock codes followed by the instructions for Creating an unlock file
If you do not get the Can't Unlock Maps message then skip to the instructions for Enabling maps on the GPS device
The Garmin Maps require a map unlock code in order for the GPS to be able to open/access it. Since the maps are copyright protected by Garmin you should of recieved the unlock code from Garmin when you purchased the new map update.
Normal
0
false
false
false
MicrosoftInternetExplorer4
/* Style Definitions */
table.MsoNormalTable
{mso-style-name:"Table Normal";
mso-tstyle-rowband-size:0;
mso-tstyle-colband-size:0;
mso-style-noshow:yes;
mso-style-parent:"";
mso-padding-alt:0in 5.4pt 0in 5.4pt;
mso-para-margin:0in;
mso-para-margin-bottom:.0001pt;
mso-pagination:widow-orphan;
font-size:10.0pt;
font-family:"Times New Roman";
mso-ansi-language:#0400;
mso-fareast-language:#0400;
mso-bidi-language:#0400;}
Routing" message may appear on your device for the following reasons:
The GPS device is
The maps on the GPS
If you see a "Can't
on the GPS device
Normal
0
false
false
false
font-size:10.0pt;
Routing" message may appear for the following reasons: The GPS device is
missing it's unlock code The maps on the GPS
device have been disabled To determine the cause of the message, touch the
If you see a "Can't
on the GPS device
I finally downloaded the jetmouse v1.3 key generator and the key it provided worked perfectly. I installed the map on my GPS and now I can drive around Taiwan like a local; always knowing where I am going. Sweeeeeeeeeeeeeeeeeeeeeeetness.
Unlocking garmin software and maps is very simple - you only need Unical ID you device and SD-card where is you locked maps. Install in keygen and unlock you maps.
If you need help or professional GPS-consultation or unlock you PNA, update navigation maps - please ask http://www.goodslowprice.com/en/unlock.htm
i BOUGHT A QUEST ON E-BAY, WHEN I TURN IT ON AT THE BOTTOM OF THE SCREEN, " CAN NOT UNLOCK MAPS" HOW CAN i UNLOCK THIS UNIT SO I CAN PROGRAM IN CITIES AND STATES.......
