The actuator inside the sterring column that the lock cylinder turns is boken, this is a very complex job and is not for the home tech without a factory service manual.
The ignition switch has the detents and spring inside of it. The lock cylinder where the key goes in, just allows you to turn the cylinder which then turns the ingnition switch. The ign switch has the electrical connector going to it.
You have to remove the lock cylinder and the upper and lower plastic shrouds to access the ign siwtch.
Section 11-05: Steering Column Switches
1996 Taurus, Sable Workshop Manual
REMOVAL AND INSTALLATION
Ignition Switch
Removal
Installation
Adjust the ignition switch by sliding the carrier to the ignition switch RUN position.
Lock Cylinder Functional
Removal
Disconnect battery ground cable (14301). Refer to Section 14-01 .
Installation
Although you will need to take out the lock cylinder to get at the actuator, you MOST likely will NOT need a new lock. You will need to pull off the upper shroud and where the separation between the top and lower sections of the column are you should be able to see the top half of the actuator by turning the key. take a hooked peice of metal and try to pull up the bottom half from the lower section of the column, hopefully you will be able to find the pin that fell out (99% of the time that's the problem) the pin goes through both peices horizontally using needle nose pliers put it or a replacement back in, now make sure the actual switch (under the dash) is in the run position by moving the actuator from inside the lock cylinder housing with a screw driver and replace the lock put it all back together, dishes are done.
