Question about GE WSXH208A Front Load Washer
MY WASHER ISNT WORKING PROPERLY
My washer wont spin smoothly, it shakes the whole kitchen.. and i think trying to charge me $25.98 to solve the problem, after all i spent on the purchase in the first place, is really lousy business practice.. i really wish someone would get back to me.. i would like to give GE a good reference if anyone asks me.. my washer model # is...WCVH6600HBB
  • 1 more comment
  • iowagal Apr 04, 2008
    Mine shakes the entire house as well on the spin cycle. PLEASE notify me if you come up with a solution. Another post said something about tightening the large bolt at the back of the washer after you take off the outer casing?
  • washershakes Apr 12, 2008
    on spin cycle shakes house and walks in place, terrible noise, first time used model wsxh208fww front load washer
  • Anonymous Aug 27, 2008
    Not only does it shake excessively, it does not go thru any cycles other than just filling then draining... and the door leaks!!!
  • 487 Answers
Ok here can be some problems of all different issues.
Did you take out the transport bolts? they are located in the back and if left in the will prevent the drum from using the dampeners. Please check this because it will wreck the machine.
If these are out most likely one of the dampeners is lose. open machine and check all four of them.
Please come back if this did not work
Posted on Apr 15, 2008
SOURCE:
The tub continues to go off balance in spin cycle. Starts out smooth then starts to wobble terribly til the UL shows and shuts down. Support rods are good
There is a little device inside the washer that allows the agitator to spin independent of the drum. If this gets stuck, the washer will try to spin the whole drum instead of just the agitator. This will cause the washer to think the load is too large or out of balance, causing the error code. On some Whirlpools this device is just a washer.
Jan 07, 2015 | Whirlpool WTW8800YC 4.6 cu. ft. Cabrio...
Washer was making a very loud shaking sound in the spin cycle, the noise stopped the spinning stopped and I smelled burning.washer will not spin
I had a shakey washer that I bought open box from "circuit city", it was a return.
I was to lazy to learn why the washer would shake and a technician told me to manually balance the wash load in the drum.
Later, I got into the washer and lubed up the rotating shafts and rockers. The washer lost all its shakes with the mechanics properly lubed. From the factory the mechanics were never properly lubed.
Tight mechanics that are supposed balance the spin cycle by moving could be part of what is getting warm. The belt spinning the washer also takes a beating when the drum shakes.
Get a good discount on your washer first, and then lube the mechanics. Everything about the washer is meant to work. If the mechanics are too tight you'll have shaking.
Jan 27, 2010 | Frigidaire Washing Machines
My Kenmore Elite Front Loading Washer is shaking very bad when it's on the spin cycle. When i level it, it's ok for a while but slowly goes back to skaking again. Any Ideas?
there are struts on the bottom of the drum and springs on top. may try replacing these but I think if you level it well and make sure the feet are tightened down well it should stay quiet. it the feet are not tightened well they will vibrate and come out of adjustment
Jan 25, 2010 | Kenmore Elite 45986 Front Load Washer
SHAKING WASHER
Jan 25, 2010 | Whirlpool Gold Duet GHW9400P 3.8 Cu. Ft....
Spin cycle problem
I had the same problem you need to pull out your washer and observe which leg is uneven this should be the source of your shaking and if you use the proper tools you can solve this.
Dec 31, 2009 | Kenmore 3.8 cu. ft. HE4t Front Load Washer
Washer is not washing the clothes properly. Skipping cylcles
If it's new - check if it's under warranty. Let them solve it. Save you money. You've already paid for it once.
Mar 21, 2009 | Whirlpool Washing Machines
Washer shaking
first make sure the shipping bolts were removed from the machine, then make sure it is level, then if it still shakes, take your fist and hit it on your head... jk, if you have it on a wood floor, or your floor isnt 100% sturdy, you cant do anything about it besides using anti vibration pads. they wont do that much tho.
Feb 12, 2009 | LG WM-2077C Front Load Washer
Front loading lg washer
if you have the spin sense option, try enbaling that on the washer
Oct 25, 2008 | LG WM-2277HW Front Load Washer
Hot point WD440 wash/dry :How to put tumble spin off.
i know this may sound stupid but did you follow the instructions on removing the Transit Braket? with tht un removed it will cause the machine to "Dance" around the room
Jan 09, 2008 | Hotpoint Aquarius WD640 Front Load...
WMA62 aborts all programs after 2 initial spins
if this washer is trying to spin when you put it on a wash cycle at the beginning and it trys a fast spin then you have a timer fault m8 if on the other hand its working fine through the wash cycle and not doing the spin properly then it has to be your belt isnt tight enough if your cab=rbon brushs are fine m8
Dec 09, 2006 | Hotpoint WMA64 Front Load Washer
GE WSXH208A Front Load Washer Logo
287 people viewed this question
Top GE Washing Machines Experts
Marvin
Marvin
geapptech
jimorris77
Are you a GE Washing Machine Expert? Answer questions, earn points and help others
