Question about Philips Magnavox 9P6034C 60" Rear Projection Television
Philips rear projection color and pic problems
Hi, ok i have a philips magnavox model #9p5511c01. when i first turn it on the picture gets smaller and back to full size till set warms up. also color has a green tint to it. it also has a red line on right side, green line on left. have read bout coolant changes to fix color prob. any help would be apreciated
  • Philips Master
  • 3,459 Answers
I had the exact same problem with my Magnavox TV. The screen would shrink then expand. After thrity minutes it would correct itself. Then one day it just broke - no sound and no video. I searched these forums but did not find clear instructions or kits on how to fix it. I gave up and called in a repair tech. He fixed my TV in less than 30 minutes.
To help others I documented the fix and created a repair kit and step by step quide on how to fix the problem. You can find it here. http://www.magnavoxhelp.com
Posted on Jun 20, 2008
  • 4 Answers
Hi.
the picture size changing on startup is normal so dont be to worried about that mine does it all the tome.
coolant changes only fix dull and blury pictures assuming that your mechanical focus and convergance is correct.
i would try using the convergance function to see if that is your problem.. otherwise it would be easier to take it to a tech as once you start adjusting all the settings with the back of the tv off it can get a little tricky..
i took 5 hrs to converge and old sony crt once...
hope that helps
Posted on Apr 10, 2008
SOURCE:
Picture shrinks , pulseates, color off until warms up
This is a very common problems with this model. Goto www.TvRepairKits.com and get there shrinking and expanding kit for your philip magnavox model.
Apr 05, 2010 | Philips Magnavox 9P6034C 60" Rear...
Magnavox rear proj (model# 8p6044 c102) pic is cloudy/green tint
Yes the coolant gets crud buildup in it over time which will cause the color and clarity to get very poor with obects that will glow around certain bright ojects. You can get the Phillips CRT coolant replacement kit from www.tvrepairworld.com which has the CRT coolant for all 3 CRTs and also includes the Cd with instructions on how to do the replacement.
Mar 27, 2010 | Televison & Video
Picture is small then gets large then gets small again.
Probably a voltage regulator problem. It's not something you can fix yourself unfortunately
Aug 28, 2009 | Philips Magnavox 9P6034C 60" Rear...
No picture
Hi, common problem, have a tech replace IC7412, gl, video-tek
Jul 03, 2009 | Philips 9P5034C 50" Rear Projection...
MAGNAVOX PROJECTION TV- GOOD PICTURE , BUT NO COLOR
you need the ssm panel. You can get a replacement panel for your model at the following link.Which is the correct board for your model it controls color, convergence and etc.
http://servicemanuals.vstore.ca/product_info.php/pName/phillips-ptv900-series-ssm/cName/sale-items
Apr 21, 2009 | Philips Magnavox 9P6034C 60" Rear...
Picuture shrinking color fading
I have the same Tv.. Repair tech said it was the deflection board. Cost $395.00 to repair.
Feb 28, 2009 | Philips Magnavox 9P6034C 60" Rear...
No picture
CK for poor solder connection around the video ic.Resolder around ic.
Dec 14, 2008 | Philips Magnavox 51MP392H Rear Projection...
Philips Magnavox 51MP392H Rear Projection Television
are you getting sound, was it moved laterly, did you just get it from somone, did it get wet, does it make clicking noises, was the picture color/ convergence blurring before this, were the colors slowly seperating such as red/blue/green?, did the picture bow on top and bottom or sides prior to tihs, was there anything note worthy prior to the blank screen.
generally its IC convergence problem with the larger philips projection TV's however I need more info on your TV, also size make model # anything you can provide gets us a more narrowed solution.
hope this helps....
Aug 17, 2008 | Philips Magnavox 51MP392H Rear Projection...
Philips Magnavox(model 9P6034C102 )
This is any easy fix. Goto www.magnavoxhelp.com to get a repair kit. Its a common problem on some of the older Magnavox projection TV sets.
Jul 30, 2008 | Philips Magnavox 9P6034C 60" Rear...
PHILLIPS MAGNAVOX 60 BIG SCREEN 9P6040C101
can you post a picture of your screen or send it to my email [email protected] as it sounds like its just the convergence Ics and the 6.8 ohm resistors, but a pic would help me do a accurate diagfnosis.
Jun 28, 2008 | Philips 55PP9363 55" Rear Projection...
Philips Magnavox 9P6034C 60" Rear Projection Television Logo
152 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Steve Allison
Steve Allison
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
