Question about Nespresso Essenza C100 Espresso Machine/Coffee Maker
Too little coffee
Hi there! My 3 month old Nespresso Essenza C100 is not working properly!The short espresso option stops half way....what could be the problem!
thanks,
Tom
  • 5 more comments
  • VBlaser Jun 15, 2008
    We have the same problem...with a different nespresso version. It suddenly started putting out half to a quarter of what it did on each setting.
    Virginia
  • Aileen Alvira
    Aileen Alvira Nov 27, 2008
    I had the same problem.  The solution offered by 1080p60 worked like a charm.  Thanks 1080p60!!
  • Anonymous Mar 12, 2014
    Nespresso Essenza stopped turning on after trying to clean.
    Nespresso essenza won't turnnppp
  • Anonymous Mar 31, 2014
    sound and burning smell
    sound and smell
    motor
1080p60 is a genius!
he is correct. the owner's manual gives you the impression that it is a three step process: 1) turn machine off. 2) push large coffee cup icon. 3) turn machine back on. BUT it does not make it clear that after turning the machine off, you must hold the coffee cup icon down WHILE turning the machine on. solved the problem perfectly. thank you 1080p60!
Posted on Dec 27, 2008
Reset to factory default...
1. Power switch off
2. Press & hold coffee cup button while powering back ON
Posted on Jun 21, 2008
Where to buy replacement water tank for Nespresso Essenza C100
I need to find a replacement water tank for my nespresso essenza C100 coffee machine. Mine broke, any ideas where I might be able to find one?
Jan 12, 2013 | Nespresso Essenza C100 Espresso...
Nespresso essenza lever stuck
My Nespresso lever won't push back and it won't produce any coffee from capsule that is stuck in machine.
Jun 13, 2012 | Nespresso Essenza C100 Espresso...
How do I get replacement parts for my Nespresso C100 Essenza?
you can find them by searching on amazon. click here Amazon com nespresso replacement parts. Hope this was helpful. cheers
Jun 09, 2012 | Nespresso Essenza C100 Espresso...
WHEN SWITCHED OFF, WATER LEAKS AT THE BASE OF NESPRESSO C100 MACHINE
I opened mine when this did this - it also happened to my second Magimix Nespresso Manual machine. A short pipe carrying pressurized water had burst. I called Nespresso . parts were not available and they offered me a new half-price machine. We are talking a 4 inch piece of plastic tubing here. Shame on you Nespresso for encouraging me to throw what is otherwise a fine machine....
Nov 14, 2010 | Nespresso Essenza C100 Espresso...
Nespresso Essenza - water is not coming out of the spout
Try...Hit the start button then Lift the lever and push back as far as possible and hold for 3 seconds. hit stop button, then close lever. this should restart machine.
Apr 29, 2010 | Nespresso Essenza C100 Espresso...
When you press the button for a large cup of espresso (Nespresso Essenza) only small amount comes out
You can adjust the fill of coffee by holding the large coffee cup down for as long as you want to fill it. Try holding the button down for 20secs., next cup of coffee should automatically fill for 20 seconds. The small cup that you are currently getting was probably set at the factory. Good luck
Nov 19, 2009 | Nespresso Essenza C100 Espresso...
Nespresso Krups essenza manual XN2001- Switch broken
The machine is not switching on-I am in India-Tamilnadu-can i get it serviced any where here?
Jul 29, 2009 | Nespresso Essenza C100 Espresso...
Our Nespresso Essenza C100 machine doesn't let the water out, but it pours it inside itself. What could be the problem?
When you make several servings of espresso consecutively, the pressure develops inside the brew basket. , be sure to relieve the build-up pressure before you remove the brew basket by turning the unit to "Froth" mode and allowing the steam to exit.
Jul 08, 2009 | Nespresso Essenza C100 Espresso...
Light don't stop blinking .... Nespresso Essenza C100
My guess is that the Essenza is in 'Descaling' state. See section 7 of the essenza manual. To get out of it, hold both the buttons down for 3 secs. The lights will then blink at normal rate for a bit and then turn solid.
Jun 21, 2009 | Nespresso Essenza C100 Espresso...
Nespresso Essenza C100 Espresso Machine/Coffee Maker Logo
4,513 people viewed this question
Top Nespresso Coffee Makers & Espresso Machines Experts
Joseph Hoffmann
Kolbrun...
Jay Finke
Jay Finke
Are you a Nespresso Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
