1999 Ford Escort Logo
Posted on Feb 28, 2018
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Tape deck and cd changer will not work (1999 Ford Escort ZX2)
I have a 1999 Ford Escort ZX2 coupe and the tape deck will not accept any tape at all, does not take it, does not register its there i put it in and it gets spat right back out and i cannot for the life of me get the CD changer in the trunk to open or play or do anything...
HELP
toddgilbert
Level 3:
Top Expert:
  • Ford Master 6,360 Answers
  • Posted on Mar 14, 2018
toddgilbert
Ford Master
Level 3:
Top Expert:
Answers
6360
Questions
5
Helped
1523178
Points
27737
Wiring, schematic, electrical diagrams, fuse diag, error codes,
torque settings etc are basic contents of these online books they have here on this website www.reliable-store.com I have attached. Must check it out
1 Related Answer
Anonymous
  • 1297 Answers
  • Posted on Mar 25, 2010
SOURCE: looking for 1999 ford escort zx2 trunk mounted cd
hope this is what you wanted...
Testimonial: "Fast and spot on."
2000 Ford Escort ZX2. I have a tape adapter, every time I put it in the tape player is spits it out. It will go in and out three times. I'd rather get this fixed than go buy a whole new stereo installation...
On the tape adapter you have to switch the side the wire comes from. The zx2 reads the cassette in the opposite direction than how the tape is normally played. Had the same problem and ended up breaking my radio try to force the tape to stay in :(
I have a 99 ford escort zx2 that I just bought used. I went to go play a tape and i put the tape in but it just pushed it back out. One of my friends said it might be stuck in eject but i couldnt figure...
Hi Athletic, The problem would seem to be that the gears inside the tape player have gone out of syncronisation. The player needs to be removed and then opened to re sync the gears (which may be broken). It would be better to have someone repair it, who knows what they're doing. I know the problem but I'm not very competent to be able to advise you on the repair procedure! Regards Johngee10
I have a tape jammed in my 99 ford escort tape player, how can i get it out? & if i can get it out, will it work again after?
Some tape players have a very tiny hole near the opening. You can push a paper clip int this hole for about 2 inches...the tape should pop out.
Do this with power off.
Hope this helps you
Since this help is free...Pleas find time to rate me
Good Luck
When i turn on the a c in my ford escort zx2 coupe the cool air comes out of the top vents for the defrost but not the front vents
There is a a vacuum problem under the hood I assume,look for it going to the firewall,it maybe sucked together or broken,or disconnected,If this was helpful,please rate,thank you.
1helpful
1helpful
Blower will not work on 1999 ford escort zx2
Check the connector at the resistor. Tips linked here.
1helpful
2answers
2000 escort - tuner does not work but CD and TAPE are fine
most likely is the radio itself- typical ford radio... best bet is look in a junkyard for a new radio- there are no fusible links- there usually is just one 10amp fuse in the inside fusebox. but if the cd& tape players work it is in the stereo itself. hope this helps and good luck
2002 ford escort zx2 camshaft sensor fit a 99 zx2?
Yes, All the years of the ZX2 utilize the same engine. 1998-2003 are all the same except for ECU programing and the MAF wiring. You should not have a problem.
Top Ford Experts
ZJ Limited
ZJ Limited
Ronny Bennett Sr.
Ronny Bennett Sr.
Thomas Perkins
Thomas Perkins
Are you a Ford Expert? Answer questions, earn points and help others
