Network connection Integrated 10/100 network card on Acer AM1610 motherboard stops working for no apparent reason. If computer is unplugged from power for a few hours and plugged back in, network card works again. Also optical mouse is live even when computer is shut off using windows shutdown.
  • Patrick Michaels
    Patrick Michaels May 11, 2010
    well..you can start by tryin to reinstall the utilities and drivers(on disk, perhaps) or you may have a memory flash issue...none of those are appetizing...but..
    Scholar:
  • 101 Answers
It probably stops working due to the heat. The solder connection to the motherboard may not be up to par. To get round it I would purchase a PCI network card and use that instead. If the mouse bothers you, you can always unplug it, but it is something that you dont need to worry about.
Posted on Mar 22, 2008
SOURCE:
Acer America AM1610-UD2180A does not boot up.it powers up but screen is blank like no power
#24 acer am1610 manual - PDF Library Connecting
66.11.115.127/acer-am1610-manual.html
50+ items - pdf download about #24 acer am1610 manual download and ... Books Title
File Code
ACER AM1610 ED2180A MANUAL Pdf Download
d6dd3 c44e6
Acer AM1610 UD2180A Manuals
b5197 d91d1
Aug 04, 2015 | Acer Computers & Internet
My dell GX620 desktop does not power when ever I plug in the network (RJ 45) cable. Also if the system has boots to desktop, and I plug in the network cable it automatically goes off.
1) Does it have a separate Ethernet Card, or is it integrated?
(Part of the motherboard)
Reasoning?
The Dell Optiplex GX620 comes with Integrated networking.
The chipset is a Broadcom 572.
It's part of the motherboard, and you plug the Ethernet Cable into the back of the computer.
However, you could have a separate Ethernet Card, plugged into the white PCI expansion slot on the motherboard.
http://www.ebay.com/itm/Dell-Optiplex-GX620-SFF-Motherboard-F8101-KH290-PY423-20-Available-/370743464509?pt=Motherboards&hash=item565208523d
A) If you are using a separate Ethernet Card, replace it.
B) If you are using the Intergrated networking of the motherboard, (Plug Ethernet cable into back of computer), use an Ethernet Card instead.
White PCI slot.
You have a short circuit when you plug the Ethernet Cable into the motherboard. Don't use the motherboard networking, use an Ethernet Card.
2) Plugging an Ethernet Cable into a computer that is on, = No.
It is not a Plug N' Play item.
(Not stating this is what you are doing.
Just posting in case you are. Burns out the Ethernet chipset on the motherboard)
For additional questions please post in a Comment.
Regards,
joecoolvette
Mar 20, 2013 | Dell OptiPlex GX620 PC Desktop
I need to know whether the ethernet card for the Optiplex GX 240 is integrated in the motherboard or it is a card in itself. Thank you.
Pretty much every computer built within the last 5 years has built on network interface. However, to answer your question completely - look at the back of the computer where the network cable plugs in? Is it clustered around the video/sound, power, printer, usb, etc (integrated in); or is it located elsewhere (perhaps in the series of long narrow rectangular openings openings where the expansion cards go - separate).
Hope this helps.
Jun 02, 2011 | Dell Ethernet Card Network Adapter
My computer has been working fine. I powered it on today and I had no signal on my Sceptre monitor and the tower was runnning. I unpluged all cables on the monitor for 30 sec. Plugged them back and...
shut your computer down for 1 minutes with the power unplugged, and try it again.
depending on if your savvy with computers or not depends on how indepth you want to be.
You need to determine if your video card has gone bad or not. try to remove everything attached to your motherboard, memory, hard drives, any cables, and see if your screen turns on. Take out any network cards, video cards, modems etc, that is inside your comptuer. So you need to have your motherboard, cpu and fan+ power supply connected, and try to turn it on. If the screen comes up,l something you removed is bad. If it does not, and your computer is running, bad video card.
Most computers today come with an integrated video card, meaning everything is 1 piece. You might be able to bypass your motherboards video card port, by installing a separate card. You can get these at any computer store.
Hope this helps!
May 02, 2011 | Computers & Internet
I have a acer m 1620. when i power it up the screen comes on and say no signal and then goes black. the fan comes on and continues to run but thats it. does anyone have any ideas?
It sounds like the video cable is loose, try unplugging it and plugging it back in. Also check if the screws on the video cable are tightened. If this does not work the graphics card has likely failed.
Mar 05, 2011 | Computers & Internet
I have a Acer PC. My Pc won't load past the Windows Blue Splash Screen. When I try to go in via Safe Mode, it stops at the same place. I been trying everything ... through the recovery console. With no...
remove all dervices, pci cards, modem card, usb devices ect... except for the hard drive, the cd/dvd drive and video card, if applicable. go into bios (by holding down f1, f2, f10, or delete before windows starts to load. try each, for different computers use different buttons) and disable the sould card, modem/network card, if integrated, and any integrated components which are not absolutely necessary to boot.
try to boot. if that does not work, try using 1 stick of ram at a time, and try each stick,1 at a time until it boots.
if your computer boots when stripped down, then try reinstalling/reenablind each device, 1 at a time, until you find the device that is keeping it from booting.
if your computer will not boot when stripped down, you need a new motherboard.
Nov 06, 2010 | Acer Aspire™ T180 PC Desktop
My acer am1610-U1201A won't connect to the internet. I have the modem and router hooked up, ethernet cable and all other cables hooked up appropriately, and my computer says it's connected to a "local...
right click "MY NETWORK PLACES " desktop icon.
click "PROPERTIES"
click the Local Area Connection.. "Properties"
click "INTERNET Protocol (tcp/ip)
at the lower part,, click "properties"
thru the "General" tab
click the OBTAIN an IP Address automatically
click the Obtain DNS Server Automatically
then OK..
see to it that the name of the WORKGROUP same in the name of the server computer..
right click the "My COmputer"
"PROPERTIES"
"COmputer NAme"
...if they the same , you can access the net now.. Thanks for sharing your problem in fixya.com
Sep 14, 2010 | Acer Aspire AM1610-U1201A PC Desktop
My hp a805n powers on like normal but my monitor is not coming on? i checked my monitor on another computer and it works perfect? whats the reason that my output to the monitor isnt working? i dont think...
This could be an issue with the integrated graphics card( This computer has integrated graphics card) or faulty motherboard.
In order to check he motherboard follow the the steps below:
1)open the computer tower by removing the side panel.
2)Remove all the memory chips(RAM) from the computer.
3)Try to turn the computer on.
4)If it is beeping then the motherboard is fine.
5)If you don't hear any beep motherboard is failed.
****Even if the motherboard is working as there is an issue with the integrated graphics you need to replace the motherboard.
Thanks.
Aug 21, 2010 | HP Pavilion a805n (PS519AA) PC Desktop
Cooler master extreme duo psu + Acer Nvidia MCP73 mobo
No it will not. The motherboard has voltage regulators which correctly distributes voltage through the integrated circuits to the chips/capacitors/etc. that need power. The only reason you would need a stronger PSU with more output wattage would be if you had lots of internal parts that drew a lot of power (such as 4-way SLi cards with power adapters plugged in, sound card, 4 hard drives, 4 optical drives, TV tuner, lots of fans, etc.). A setup like the one I just described would probably need at least a 750 watt PSU. But in any case, you could have a 2000000 watt PSU and it would not fry the board due to the reasons above.
Jan 14, 2010 | Gateway GT5685E Desktop Computer - Intel...
Error code 31 4 to 6 network adapter
Check these things:
  1. Is you Ethernet adapter Active
  2. Is your Cable the correct one (NOT a cross over)
  3. Refresh your IP Address for your Ethernet Card
  4. Reboot your computer and power down your modem, then power the modem up AFTER your windows is logged on
  5. Verify your modem "really" can connect, use another computer.
  6. Verify the are no network issues with your ISP
Apr 16, 2009 | Acer AM1610-UD2180A DT E2180 2.0G 2GB...
Open Questions:
WEBROOT tEch SuPporT Phone /v\[18OO8O3/v\1O69] NuMbEr .U.S.A suppo This WEBROOT USA phone number is ranked #2 out of 2 because 7,728 WEBROOT USA customers tried our tools and information and gave us feedback after they called. The reason customers call # I:8OO:,:8O31069 is to reach the WEBROOT USA Tech Support department for problems like Where to buy, Complaint, Tech support, Repairs, Returns. As far as we can tell, WEBROOT USA has call center locations in New Mexico and you can call during their open hours Mon-Fri 9am-8pm EST. WEBROOT USA has 2 phone numbers and 4 different ways to get customer help. We've compiled information about I8OO8O31O69 and ways to call or contact WEBROOT USA with help from customers like yourself. Please help us continue to grow and improve this information and these tools by sharing with people you know who might find it useful. Calling WEBROOT USA Calling WEBROOT USA at this number should be pretty straightforward. Also important is what you do once you call, or what your other phone number options are. First of all, we strongly recommend using our free call-you-back tool. Essentially, we navigate their phone menu for you, wait on hold, and then call you when a representative from WEBROOT USA Tech Support can talk. Generally, it saves you at least 27% of your wait time. So it's faster and you don't need to listen to bad hold music. Once on the phone with WEBROOT USA's Tech Support department, you may need to provide them with information that identifies you as a customer, like your full name or name on the account, email address, phone number, or an account number. It's usually worthwhile to gather this information before you call. Click here if you want to compare WEBROOT USA's phone numbers against each other. Contacting WEBROOT USA in General While I8OO8O31O69 is WEBROOT USA's #2 most popular phone number, it's not the only way to get a hold of their customer care team. You already know from reading above that I8OO8O31O69 is their best customer phone number overall, and we have put together a comparison of their 4 total ways to contact support for you to look at as well. One thing to keep in mind as you try to reach WEBROOT USA help by calling them, is that other customers give their customer support at this number a 84% score for their communication skills and a 94% score for the overall help they received. That could be indicative of their abilities to help you resolve your problem overall, regardless of whether or not you call this number. Click here to see a comparison of all the phone numbers, social media and other avenues to contact WEBROOT USA.
Oct 16, 2019 | Webroot Computers & Internet
MCAFEE tEch SuPporT Phone /v\[18OO8O3/v\1O69] NuMbEr .U.S.A suppo This MCAFEE USA phone number is ranked #2 out of 2 because 7,728 MCAFEE USA customers tried our tools and information and gave us feedback after they called. The reason customers call # I:8OO:,:8O31069 is to reach the MCAFEE USA Tech Support department for problems like Where to buy, Complaint, Tech support, Repairs, Returns. As far as we can tell, MCAFEE USA has call center locations in New Mexico and you can call during their open hours Mon-Fri 9am-8pm EST. MCAFEE USA has 2 phone numbers and 4 different ways to get customer help. We've compiled information about I8OO8O31O69 and ways to call or contact MCAFEE USA with help from customers like yourself. Please help us continue to grow and improve this information and these tools by sharing with people you know who might find it useful. Calling MCAFEE USA Calling MCAFEE USA at this number should be pretty straightforward. Also important is what you do once you call, or what your other phone number options are. First of all, we strongly recommend using our free call-you-back tool. Essentially, we navigate their phone menu for you, wait on hold, and then call you when a representative from MCAFEE USA Tech Support can talk. Generally, it saves you at least 27% of your wait time. So it's faster and you don't need to listen to bad hold music. Once on the phone with MCAFEE USA's Tech Support department, you may need to provide them with information that identifies you as a customer, like your full name or name on the account, email address, phone number, or an account number. It's usually worthwhile to gather this information before you call. Click here if you want to compare MCAFEE USA's phone numbers against each other. Contacting MCAFEE USA in General While I8OO8O31O69 is MCAFEE USA's #2 most popular phone number, it's not the only way to get a hold of their customer care team. You already know from reading above that I8OO8O31O69 is their best customer phone number overall, and we have put together a comparison of their 4 total ways to contact support for you to look at as well. One thing to keep in mind as you try to reach MCAFEE USA help by calling them, is that other customers give their customer support at this number a 84% score for their communication skills and a 94% score for the overall help they received. That could be indicative of their abilities to help you resolve your problem overall, regardless of whether or not you call this number. Click here to see a comparison of all the phone numbers, social media and other avenues to contact MCAFEE USA.
Oct 16, 2019 | Mcafee Computers & Internet
Computers & Internet Logo
Ekse
Alun Cox
