Question about Dewalt DC920KA Heavy Duty Xrp 18V Cordless Drill/Driver
18 volt xrp hammer drill driver
I am having trouble changing speed settings. It gets progressively harder to turn as I go to higher settings. Getting to hammer mode requires a pair of channel locks.
I have had this same problem and fixed by backing off the tamper proof screws that hold the front off the drill on, there is four of them. Hope this helps.
Posted on Jun 29, 2008
    Champion:
  • 313 Answers
Transmission is needed
Posted on May 30, 2008
Run the drill slow while changing the speed of the drill
Posted on May 24, 2008
Dewalt xrp stuck in hammer mode cant move selector to drill or number selections
I am assuming you are talking about not being able to move the "Mode Control Collar" and unless you can get it out of hammer mode, you will not be able to change the torque collar either.
If you feel comfortable taking it apart AND its no longer under warranty, my best guess without seeing the tool will be part# N026313 Gear Case Assembly. It costs about $80.00 US
Hopefully its under warranty, if so you can go to
http://servicenet.dewalt.com/ServiceCenter/Search
to locate nearest service center.
Good luck
Sorry I wasn
Apr 29, 2011 | Dewalt 18 Volt Xrp Heavy Duty Hammer Drill...
The chuck on my Dewalt 18v hammer drill will not stay tight. it loosens whether I am in forward or reverse
the chuck on my dewalt 18 volts hammer drill will not stay tight it loosenss whether i am in forward or reverse
Oct 14, 2010 | Dewalt DC920KA Heavy Duty Xrp 18V Cordless...
Hammer-mode engagement
there should be a slider type switch on top of the drill. and there will be a picture of a hammer, and a picture of a drill. slide accross to the drill picture for drill, and hammer for the hammer drill
Apr 07, 2010 | Dewalt 18 Volt Compact Drill Kit
I have a dc925 xrp hammer drill which i got second hand and the clutch does not work at any of lower torque settings needed for screwing is this likely to be an easy fix?
Go to Dewaltservicenet.com and download a breakdown for this tool, most of the parts are component parts that you replace as an assembly.
Oct 11, 2009 | Dewalt 18 Volt Compact Drill Kit
Dewalt 18V XRP Hammer drill, stops on torque in drillpositio
The brushes might need to be replaced. You can find them on Ebay and are easily to replace.
Aug 01, 2009 | Dewalt DC927KL Heavy Duty 18 Volt Cordless...
Dewalt xrp 18 volt hammerdrill. Need gear schematics.
Go to Dewaltservicenet.com and in the middle of the page towards the bottom type in your model number and it will take you to a page where the schematics are.
May 24, 2009 | Dewalt DC927KL Heavy Duty 18 Volt Cordless...
The motor turns but the clutch will not engage
Take the drill out of the hammer drill setting when in reverse.  Using the drill setting with the speed on 1 will give the power to free the bit.  If the clutch will not engage, GENTLY but firmly switch between forward and reverse.  This should work just fine.   I hope this solution brings you success!  Best Regards,  Michael Mittelsdorf
Dec 26, 2008 | Drills
Dc926 xrp hammer drill
ya its a chuck problem wont hold in reverse
Aug 10, 2008 | Dewalt DC920KA Heavy Duty Xrp 18V Cordless...
Cannot engage hammer action
the problem is the metal part of the clutch that meets the pin from the transmission. remove the 4 screw from the clutch & check if the the inside of the clutch & the trans pin meets. all you can do is to push back the metal parts of the clutch setting.
Jun 07, 2008 | Dewalt 18 Volt Compact Drill Kit
Dewalt DC920KA Heavy Duty Xrp 18V Cordless Drill/Driver Logo
395 people viewed this question
Top Dewalt Drills Experts
Jim Thurston
Are you a Dewalt Drill Expert? Answer questions, earn points and help others
