Question about Kenmore 20.3 cu. ft. / 575 liter Upright Freezer 23024
Kenmore Upright Freezer Model 253.9239780 Temp alarm, Temp rising slowly
Been getting the temp alarm for about 2 weeks now. Temp has risen from -5 to currently 20 even though compressor is running. No new food added, door has been closed. Freezer located in garage, temp in garage is 45. Checked lower back of Freezer for obstructions, etc. but none found. If I push the temp alarm button, alarm goes silent, red light continues to flash. Several hours later, alarm sounds again. Nothing inside freezer is blicking the door from closing properly. Freezer is 16 years old approximately. Turned temp setting down several times but temp doesn't seem to drop even though compressor is running... I've fixed several other appliances with minor problems but have very limited diagnostic tools to fix a freezer.
  • 1 more comment
  • Anonymous Jun 10, 2008
    model # 253 . 9239716 serial # s511394019 manufactuers date 11-1995 theres no temp control knob to turn freezer temp down any where in side of freezer.. there is a quick freeze button on out side of the door with freezer alarm and power button but no where in side or out side for temp control knob to be found..got schematics and freezer owners guide for freezer schematics show parts and order #s for temp control knob . where is it located on/in freezer. who would design something like that..
  • djmott2000 Aug 16, 2008
    The alarm on my freezer goes off every 12 hours. I reset the alarm, it goes off again 12 hours later. I reset the temperature, it still goes off 12 hours later.
  • Anonymous Mar 31, 2014
    Need to reset temp control away from 888
    Scholar:
  • 150 Answers
You have a refrigeration issue partner let her go 16 yrs. is good service you can replace it for 3 to 5 hundred the repair will be that IF you can find someone with the r-12. don't go for a top it off and go deal the food you lose is to expensive for that to be economical.
Posted on Apr 23, 2008
SOURCE:
I can't turn my Kenmore upright freezer on.
Try disconnecting power for about 30 seconds, and then restore power. This will reboot the control and maybe restart.
Jul 09, 2017 | Kenmore Freezers
Sears Ken Elite upright freezer model no 25329082991 temp alarm
alarm should go off when freezer reaches minus 18c or lower.
Feb 05, 2010 | Freezers
New upright kenmore freezer temp varies +/- 10 degrees
Over what period of time did this variation occur?
The freezer should have an automatic defrost cycle. The temperature will rise while it is going through this cycle.
Oct 18, 2009 | Freezers
Won't freeze
Is the compressor running the whole time? If so may have a problem with a refridgerant leak....check the compressor in the rear of unit, feel if its hot....may be as simple as a relay.
Jun 17, 2009 | Kenmore Freezer 20.3 cu. ft. Frost Free...
Temp alarm on freezer alarming.
that's the same problem i incurred, i replaced the thermostat and the fan. seems to be working fine.
Dec 03, 2008 | Kenmore Freezer 14.1 cu. ft. Upright...
FREEZER ALARM WILL NOT SHUT OFF
Use a freezer thermometer and tell me the actual temperature. Or at least store some ice cream and see if it stays brick hard. Unless I have some idea of the actual temp I can't tell if defective freezer or alarm
May 11, 2008 | Kenmore 16.7 cu. ft. / 473 liter Upright...
Kenmore 20.3 cu. ft. / 575 liter Upright Freezer 23024 Logo
1,112 people viewed this question
Top Kenmore Freezers Experts
John Tripp
John Tripp
Felizardo Erilla
Felizardo Erilla
PNiss
Are you a Kenmore Freezer Expert? Answer questions, earn points and help others
