Question about LG CU500 Cellular Phone
LG CU-500 Poor Reception
Recently bought a CU-500 unlocked off Ebay. Phone seems to work fine except that reception is not nearly as good as my previous LG 4011. I get 4 bars in the house on the 4011 and almost nothing on the CU-500. The CU-500 works fine when there is a strong signal. Anything I can do to improve the reception (short of getting an amplifier for the house).
  • Chibiche Oct 31, 2008
    My original cu500 worked wonderfully, then I had to send it in cause I managed to lock it up, so they sent me a refurbished one, and my reception stinks now! If I want to have a decent conversation, I have to have it on speakerphone and hold it up in some magical hot spots in my house.
  • Anonymous Mar 16, 2014
    My phone was working fine then all of a sudden it started tellin me that my password was wrong and wont let me open up my phone to do anything
Try updating your roaming profile. This helps reception on a Verizon phone.
Posted on Sep 17, 2008
  • 92 Answers
Please clean your motherboard with accitone
and give a little bit of heat on motherboard
hope it works
for more information
you can mail me
[email protected]
thanks
Posted on Apr 03, 2008
SOURCE:
I get great sound on my lg dare calls but the reception is poor. Sometimes caller on other end cuts out. Is the a way to get better reception. Current carrier is Verizon.
Your problem isn't your service provider-its your phone! I have a different LG phone than you, but from my own experience and what i have heard from many people who have LG phones, they all have reception problems. LG phones have terrible antennas in their phones. I'm trying to work on a solution to that now, if its possible. Contact me(True Love in DC) in a week to see if i discovered any solutions. In the meantime, a good thing to know about reception with ANY phone is this: the antenna is always at the top of your phone. Avoid holding or placing your hand and fingers near the top of your phone. And NEVER bend over while talking on the phone as u will be pointing your phone towards the ground. This almost ALWAYS cuts off your reception or even disconnects your call in progress. Learn the best reception spots in and around your home and other places you may be at too. Avoid walking around while talking on the phone. Certain buildings or parts of buildings play a part in your reception as well as certain lighting in the building. And finally, atmospheric conditions(storms, cloud cover, etc) are a big contributer in reception problems!
Jul 20, 2011 | Lands Phones
Reception is very poor. Grounding issues? Please
Reception has little to do with grounding. The ground plan is for transmitting. As long as the coax is connected and is in good standing, it should receive fine regardless of grounding.
There are a few reasons you may have bad reception.
  1. Turn the RF GAIN all the way up. This is your receive sensitivity.
  2. Squelch is too high. It should only be turned up enough to cut out the background noise.
  3. Poor antenna. If the antenna is cheap, and not made well, this could be the problem.
  4. Not enough of the antenna above the vehicle. It needs to be at least 60% of the antenna above the vehicle.
Hope this helps!
Oct 21, 2009 | Cobra 29 LTD CB Radio
Poor cell reception and short battery life
UNLOCK YOUR IPHONE FOR ONLY $19 WE CAN UNLOCK IPHONE 3G 3GS 2G, EASY STEP BY STEP TUTORIAL VISIT US AT WWW.UNLOCK-IPHONE.ORG
Sep 29, 2009 | Pantech Matrix Cell Phone
No reception on phone anywhere all of a sudden
contact your cell phone provider (att, sprint, verizon). your service may be shut off.
Jul 11, 2009 | LG KF700 Triband 3G HSDPA 3MP A2DP Phone...
LG Vu CU915, poor reception
Press 277634#*# - then Modem Setting - then Network Mode - then Network Mode - then select 2G Only. This will turn off 3G and you will now be using 2G or Extended Network. Either or, I used to have the same problem, but after making that simple change I have an extra "bar" on my phone.
Dec 17, 2008 | LG Vu CU920 Cellular Phone
LG viewty phone
I bought this same phone off ebay but they will not work properly in North America.I have talked to different sources and the most important Network band here is(gsm850) which this phone does not have, so in North America you get a very weak signal strength.
Oct 24, 2008 | LG KU990 Viewty
LG Shine KE970 reception problems
The problem was that the phone is 2G only so will not work on the three network
Mar 26, 2008 | Lands Phones
In London, Uk. I have poor reception of channel 5. have got recently a one for all powered aerial. how do I set it up? Model sv-9140-00-002
Your reception would be much improved by using a free to air digital set top box - only about £20. If you are in east London especially near docklands channel 5 reception with a conventional aerial gives a lot of problems. sv-9140-00-002 is an interior aerial booster - I doubt whether this will improve things much. Best solution is a good outside aerial - if you live in flats is there no communal aerial available?
Mar 17, 2008 | Televison & Video
Lg kg800 will not connect to ATT
you first need to know the network coming with the first before buying it...and what network AT&T works on.
for example
LG KG800 works on these networks
850/1800/1900 or 900/1800/1900...you need to look at the box to see which network your phone comes with.
Dec 13, 2007 | LG KG800 Cellular Phone
LG TU550 phone handsfree volume
VERY poor reception and battery goes flat in about 10 hours as looking for a signal. My wifes Nokia lasts a LOT longer and has much better reception
Dec 05, 2007 | LG CU500 Cellular Phone
LG CU500 Cellular Phone Logo
113 people viewed this question
Top LG Cell Phones Experts
William Norris
William Norris
George Etukudo
George Etukudo
Sheldon Dedek
Are you a LG Cell Phone Expert? Answer questions, earn points and help others
