BYTECC BT-300 how do use the BYTECC BT-300. where can i find a manual or instruction on how to use this device.
  • srizvi1 May 11, 2010
    I'm a mac user. If I connect a hard drive (no enclosure) directly to the Bytecc BT-300 through the SATA Drive port and I don't see anything show up on the screen/// Or when I go into Disk Utility, I don't see my hard drive, does that mean that my hard drive is dead? I had this hard drive installed in my MacBook Pro and it was working fine but on its most recent visit to Applecare, my computer was returned with this hard drive taken out and a new one put in. I am not quite sure why. I took the my BYTECC BT-300 directly to the WD3200BEVT and I can hear the hard drive making noise, but nothing is happening on screen
    Guru:
  • 377 Answers
Hi dear
Make sure you plug in the power for the drive first, let it boot up for a second, THEN attach the adapter and the USB
oke
Posted on Mar 22, 2008
Does the BT-350 work with Windows 10. I can feel the drive spin up but no drive designation.
Windows 10 Drivers - HP Support Forum - 5207043
h30434.www3.hp.com > Laptop & Notebook > Notebook OS
Aug 17, 2015 - 8 posts
So.....is HP going to provide updated drivers for Windows 10? .... sensor andbluetooth (depending on the BT hardware installed). It is the ... I can get W10 to workin an old nc6400 from 2006, and not on a 350 G1 from 2014.
Bytecc BT-350 Drivers Download - Update Bytecc Software
www.solvusoft.com/en/update/drivers/hard-drive/.../bt-350/sub-models/
Manufacturer: Bytecc. Hardware Type: Hard Drive. Model: BT-350. Compatibility:Windows XP, Vista, 7, 8, 10. Downloads: 35,089,716. Download Size: 3.4 MB.
Dec 15, 2015 | Computers & Internet
I have windows 7 and the Bytecc bt-144 will not work. the drive is not recognized and when i attempt to update it with the driver from the Bytecc web page the computer say the driver isup to date and will...
you might be installing the driver through the right process
click start right click on computer select properties device manager scroll through all of your devices if you see a yellow question or exclamation mark ? ! or a red X you will need to update the drivers for this device right click select update driver/reinstall driver
if you can see your usb device but its not working scroll to Ports(Com&Ltd) right click to update driver
hope this helps you
Jul 25, 2011 | BYTECC (BT144) External Floppy Drive
I have a BYTECC BT-PCI-SATA 150 I/O controller card but it does not work with windows 7. Is there a driver available for this model?
I can't seem to find a product with the model number "BT-PCI-SATA" that you provided, on the Bytecc web site. You should shut off and open the computer and read the model info directly from the the I/O card to determine the exact model card you've got.
Once you which card you have, you can download drivers directly from Bytecc. There appears to be very limited support listed for both Vista & Windows 7 OSes however. If nothing else, you'll be able to download the latest version of the driver - that may support Windows 7 - without specifically stating that it does.
If you're trying to install Win 7 to boot from a hard drive connected to this controller, it may work if you supply the expanded driver on USB, floppy, etc. when prompted for a SATA driver. Bytecc only offers an email address for tech support, so you might want to send them a detailed note about the problem at: info@byteccusa.com
Hopefully, this helped - good luck!
Nov 18, 2010 | Pc Ware PC CHIPS: PC-Chip M957G...
Bytecc BT-300 USB 2.0 drive mate problem : I am a PC user with WinXP O/S. My BT-300 worked fine when used along with 2.5 in laptop hard disk (power cable connected to drive mate). On the other hand, I am...
First is the "Drive" formatted? It will not work, if it is a new drive, until it is formatted. And/Or "Initialized"? If it has data on it already then it may be faulty? the only way to check that is to try it on another machine... also are you 100% sure you have it connected right way around, I have made exactly that mistake, before, I learnt whats what. Also try another USB port, this sometimes works. Try the setup on another PC to check it is actually OK.
Feb 22, 2010 | BYTECC USB2.0 to IDE Adapter Kit...
I lost my manual and need three codes i have an eCircuit 6 in1 universal remote plz help , thanks Gage
hai the below manual should help
http://www.megaupload.com/?d=YXFWOK8I
happy to help
Nov 29, 2009 | BYTECC BT-ECU2FW Expansion Module
Is there a prob;em using the Bytec BT-144 External
If you installed a program with the drive, th edrive is functioning properly. If the program will not run, you need to check the program compatibility with vista or investigate any errors you are recieving.
Sep 02, 2009 | BYTECC (BT144) External Floppy Drive
Cannot copy files using BYTECC Bt-300
check the jumpers on the old drive and see if its powering on or spining up! some of these usb adapters just dont work on old drives if all else faisl open your system and connect it to your pata bus if you have one! if not then use another computer to extract your data and put it on another storage media e.g. flash drives ext hardddisk memory card or dvd or cd disk!
Aug 29, 2009 | Dell Computers & Internet
Computers & Internet Logo
2,399 people viewed this question
David Payne
David Payne
