4inch display driver
I have designed a digital clock, which constructed with 89c51 and DS1307, and uses four 7segment 0.5" display. It is working well. Now i am looking to use big display of 4" size. kindly help me to design a driving circuit for 4" display which need 12v segment voltage.
    Guru:
  • 377 Answers
Hi dear
here
http://web.jfet.org/inGrid/
http://www.mcamafia.de/nixie/ncp_en/ncp.htm
oke
Posted on Mar 22, 2008
How to set clock on frigidaire fpbm3077rfb
To access the clock controls, press the "Stop clear" button, press "User pref," and then press "5." Use the number keys to enter the time as a four-digit number. For example, press the "1," "2," "3," and "0" buttons to set the clock to display 12:30. Press "Start enter +30 sec" to complete the process.
Oct 09, 2017 | Frigidaire Ovens
Can you fix the clock on a 97 jaguar xj6 radio clock at home?
1: press and hold the MODE button until TA VOLUME is displayed. 2: Press and release the Mode button until CLOCK SET is displayed.
3: While the display is flashing use the SEEK UP/SEEK DOWN keys to select 12hr or 24hr style display
4: Press and release the MODE button again If 12hr format has been selected use the # key to select AM or PM Using the Numeric Keypad enter the correct time using four digits i.e 1045 for 10:45. Press and hold the MODE button to return to the normal audio mode.
May 18, 2016 | Jaguar Cars & Trucks
I have a 2000 saturn ls and my code is 8870. Does anyone know what it is to unlock my radio
Do you want the instructions of how to enter your code?
  1. Turn the ignition ON.
  2. Press the power button on the radio. The display will show "- - - -".
  3. Enter the four digit code by using the and rocker buttons. The numbers will start at 0 0 0 0 and will increase on the display each time the corresponding side of the rocker button is pushed.
    1. Press the down arrow side of rocker button to change left digit.
    2. Press the up arrow side of rocker button to change second to left digit.
    3. Press the down arrow side of rocker button to change third digit.
    4. Press the up arrow side of rocker button to change last digit.
  1. Push the AM/FM button once the four-digit code has been entered correctly.
  2. If the proper code has been entered, the radio will return to the armed mode and normal operation shall return. If the wrong code is entered, the display will momentarily show an error message and then return to display "- - - -" indicating that another try at the correct code can be attempted.
Oct 19, 2014 | Cars & Trucks
Operation manual is lost, how do I set the clock?
The manual for the Magic Chef MCD1311ST Microwave can be downloaded in pdf format from the following site (follow the link then click the "Manuals" tab):
http://www.mcappliance.com/mwodetailpage.aspx?ModelName=MCD1311ST
If you don't have time to download, here's what the instructions state:
SETTING THE CLOCK
When the oven is first plugged in, the display will flash ":0" and a tone will sound. If the AC power ever goes off, the display shows ":0" when the power comes back on.
1. Touch CLOCK pad.
This is a 12 hour clock system.
2. Touch CLOCK pad once more.
This is a 24hour clock system.
NOTE: This oven has multiple clock system. If you want 12 hour clock system, omit this step.
3. Enter the correct time of day by touching the numbers in sequence.
4. Touch CLOCK pad.
The display stops blinking, and the colon start blinking. If you selected 12 hour clock system, this digital clock allows you to set from 1:00 to 12:59. If you selected 24 hour clock system, this digital clock allows you to set from 0:00 to 23:59.
5. Touch STOP/CLEAR pad.
NOTE: If you attempt to enter an incorrect time, the time will not be set and a error signal tone will sound. Touch the CLOCK pad and re-enter the time.
Jun 28, 2010 | Magic Chef MCD1311ST Microwave Oven
Set the clock on a clarion cd player?
Setting the Clock
1) Press and hold in the BAND button [4] then press the DISP button [9] to toggle the display to the clock mode.
2) Press and hold in the BAND button [4] then press and hold in the DISP button [9] for at least 2 seconds.
3) Select left or right to adjust the time using the a-selector
~Adjusting minutes
Each time you select right >> using the a-selector [3], the minutes increment up by one digit (0 to 59).
~Adjusting hours
Each time you select left << using the a-selector [3], the hours increment up by one digit (1 to 12).
*The clock only displays time in a 12-hour format.
There is no way to toggle the clock to a 24-hour format.
4) Press the BAND button [4] to set the clock into memory. This also resets the seconds counter to zero.
Note:
*The clock can only be set by turning power on to the unit and switching to the clock display mode. You cannot set the clock when it is displayed with only the igntion on. If you drain or remove the car's battery, the clock must be reset. While setting the clock, if another button or operation is selected, the clock set mode is canceled.
Dec 08, 2009 | Alpine Car Audio & Video
TRANSFER DATA FROM 89C51 TO ANOTHER 89C51
Please try bluetooth of cable connection through LAN.
Jul 10, 2009 | Gateway MT3705 Notebook
Flowchart constructing problem
Hi
I can solve this........but what is it worth ?
John.
Feb 03, 2009 | 1998 Jaguar XJ8L
Changint time on digitalclock
If the vehicle is not fitted with a
touch-screen, adjust the clock using the
audio system controls as follows:
1. Press and hold MODE until TA
VOLUME
is displayed.
2. Repeatedly press MODE until
3. To select 12 or 24 hour format, press
the seek up/down keys.
4. Press MODE to continue
5. If 12 hour is selected, use # to denote
AM or PM.
6. Use the key pad to enter the time in
four digit format.
7. To exit, press and hold MODE until
the display reverts to audio mode.
Nov 04, 2008 | 2003 Jaguar S-Type
HOW TO SET A CLOCK AND CALENDAR ON SHARP EL-1750P CALCULATOR
GT •RATE SET GRAND TOTAL / RATE SETTING MODE SELECTOR:
“GT”: Grand Total
“•”: Neutral
“RATE SET”: To set the date, time, and tax rate, set this switch at the “RATE SET” position.
Date:
• Enter in the order of month, day and year, then press to complete the entry.
• Use to separate month, day, and year.
• When is pressed, the number entered is evaluated and displayed as “date” if the
value is within the following range; “Error” is displayed otherwise, and the previously set
date is restored.
Month: 1 - 12; day: 1 - 31; Year: 2000 - 2099 (in 4 digits) or 00 - 99 (in 2 digits)
Time:
• Enter in the order of hour, minutes, then press to complete the entry.
(There is no entry available for the seconds value. The clock starts at zero second.)
• If the hour/minute digit is less than 10, it is not necessary to enter the first digit “0”.
• Use to separate hour and minute values.
• When is pressed, the number entered is evaluated and displayed as “time” if the
time is restored.
Hour: 0 - 23 (24-hour system for the hour entry), Minute: 0 - 59
Aug 22, 2008 | Sharp EL-1750PIII Calculator
TELRAD AVANTI 3020 & 3015
Avanti Model 3020F or 3020H Display telephones
1) Leave the handset on-hook.
2) Press the FEATURE button.
3) Press the PROGRAM soft key.
4) Press TIME soft key.
5) Enter the time in the 24 hour clock format of HHMM. Use a leading 0 for single digit numbers.
6) Enter the date in the format DDMMYY using a leading 0 for single digit numbers.
7) Press SAVE soft key to save the settings.
Note: All 10 digits for the time and date must be entered. You can not skip any steps. To abort the time and date setting process press SPKR at any point before pressing SPD/PROG.
Avanti Model 3015DF or 3015DH Display telephones 1) Leave the handset on-hook.
3) Press the PROG soft key.
Mar 17, 2008 | NEC Electra Elite 32D-1 Corded Phone
Computers & Internet Logo
65 people viewed this question
David Payne
David Payne
