Question about Epson Stylus C86 InkJet Printer
2 flashing red lights
Printer starts up OK doesusual back and forth prep then stops with both ink and clogged paper lights flashing and won't move at all. 4 cartridges of ink are in and NO paper jam
The printer jams each time I try to print, and although I think it's clear, it still jams.
Posted on Mar 27, 2008
The ink and paper lights are blinking and the power light is not lit
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} I had the flashing lights (Epson R1800) too. Both the ink and paper flashed rapidly at the same time.
After intense searching on the net, I tried just about everything. SSC service utility did
Nothing. Turning printer off and on also didn’t help.
Turning printer off then pressing the paper and ink buttons, then turning power on, then waiting for both lights to flash, releasing them and pressing the ink button for 10 seconds also didn’t help.
After days of this I got frustrated, packed the POS back into the box and put it up for sale
On Craigslist. No takers… I was about to put it out to the curb ($540 printer sat in the box for almost a year) but decided to do one last google and found someone talking about the print head moving along the rail.
Suggestion was to turn printer off and see if print head traveled freely back and forth. Ok I thought, Pulled the printer back out of the box and set it up again. Reinstalled software and turned it on. Red lights flashing again! Ok, press the ink button to move head to home, then turn printer off. Then I tried to move head along rail. It moved freely a couple of inches to the left then stopped like something was blocking it.
Took my flashlight out and could not see anything in the way so pushed down on the cartridge cover and heard a “click”….. Duh! The freakin’ cover was not closed! Now the head would move left and right all the way so I turned the printer on and to my amazement NO more flashing red lights! I was both thrilled and depressed (at my stupidity) for not seeing this earlier.
I will post this everywhere I can to remind people that the cartridge cover is the FIRST thing you should check upon seeing both red lights flashing rapidly!!!!!
Apr 29, 2010 | Epson Stylus Photo R1800 InkJet Printer
Printer stopped working. I just added new ink supply. Alarm light flashes. Printer status says "service error 6A00"--"check printer" "cancel printing and press the ok button." None of this works. And I...
Error 6A00
The 6A00 is a Canon generic code for paper path jam.
Solution 1:
Move the printhead carriage back and forth a few times.
Solution 2:
Check the purge unit: Moving the print head assembly will not clear a purge unit if its jammed with paper, paper clips, push pins, screws, cookie crisp, flower bud pods or the like.
Solution 3:
Press the ink pads down in the purge unit.
Apr 05, 2010 | Canon PIXMA MP780 All-In-One InkJet...
Doesn't want to print
Try unplugging from the wall for 5 minutes / plug in and retry, cancels / resets printer memory.
Feb 17, 2010 | Canon BJC 3000 InkJet Printer
Red light stays on and printer won't print
My C60 Epson Stylus printer is not printing. First of all the paper jammed, I pull the paper from the front and since then the catridge holder is not going to the middle to print. also the green light keepon flashing and the red light stays on. I need your help.
Jan 16, 2010 | Epson Stylus C60 InkJet Printer
Blinking both the ink botton ligths and the botton paper
I just today threw away my R220. If your 2 red lights are going and the power light is off, then your printer has died. It just happened to me. It sucks, but there is no way to fix it.
May 04, 2008 | Epson Stylus Photo R220 InkJet Printer
Epson Stylus C86 printer flashing lights
then you , like the printer are stuck? well, then open it up, inspect it closely, and find the little paper that is inside and making it flash red..
Mar 22, 2008 | Epson Stylus C86 InkJet Printer
Epson Stylus C68
Turn the printer off. Open the cover and check for any foreign objects that can cause your print head not to move. Check if you have put the ink cartridges correctly and make sure that the cover for the ink tray is closed. Turn the printer on, if your going to see the same status of the lights, it will be a hardware issue.
Contact Epson Technical Support.
United States
Phone Number: (562)276-7525
Hours: Mon.- Fri. 6AM-8PM (PT)
Sat. 7AM-4PM (PT)
Phone Number: (905)709-2567
Hours: Mon.- Fri. 6AM-6PM (PT)
Feb 02, 2008 | Epson Stylus C68 InkJet Photo Printer
I have a epson stylus c65 printer. My printer is keep flashing the two red light. The out of paper and the out of ink. what do I have to do to stop the problem. The two red light is keep on flashing alternately
Jan 19, 2008 | Epson Stylus Photo R200 InkJet Printer
Epson Stylus C86 InkJet Printer Logo
295 people viewed this question
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
