Question about Epson Stylus C86 InkJet Printer
Epson Stylus C86 printer flashing lights
Printer turns on, does the usual back and forth; then both ink and paper jam lights flash red and printer will not do another thing.... stuck???
  • 4 more comments
  • Anonymous Mar 25, 2008
    the two red lights are flashing from side to side. My wife was printing the other day and wanted to stop printing so she turned the printer off, now when i turn the machine on, notheing happens apart from the flashing lights going side to side. I dont know what else to do as it appears to be stuck somehow, the cartridges dont movee although there is power to the machine
  • plangdale Jul 03, 2008
    I'm having the flashing red light problem on my Epson C86 too. It started when I had a paper jam the other day. I pulled the paper out manually (I know now I shouldn't have done that) and the red lights started flashing. The flashing lights are not alternating they flash at the same time and the green power light is not on. My printer utility software is communicating with the printer and it's telling me there's is a small piece of paper still jammed somewhere in the machine. I can't find any traces of paper anywhere and the jammed sheet of paper I pulled out of the printer has no tears at all on it. Does anyone have any idea how to fix this problem??
  • Anonymous Jul 06, 2008
    I had a paper jam and pull the paper from top and looked for any pieces of paper. I found one and pull it out. I cleaned the rollers but now it is not printing one line clearly. What should I do.
  • Anonymous Sep 28, 2008
    I have the same problem except mine is a C46 model
  • Anonymous Oct 11, 2008
  • Anonymous Oct 28, 2008
    My printer fed through too much paper - no jam, but now wont do anything except flash the lights!
  • 3,587 Answers
Then you , like the printer are stuck? well, then open it up, inspect it closely, and find the little paper that is inside and making it flash red..
Posted on Mar 22, 2008
Epson Stylus PHOTO R220 red lights keep flashing
I hope this will help you :)
* Green Power light flashes- The printer is receiving a print job, replacing an ink cartridge, charging ink, or cleaning the print head.
* RED paper light is On- If the CD/DVD try guide is open, close the CD/DVD tray guide, load paper, then press the paper button. Your paper ran out or multiple sheets loaded at the same time . Load paper and press the paper butoon to resume printing.
* RED paper light flashes- Paper is jammed in the printer. Press the paper button to eject the jammed paper. If the light is still flashing , open the cover and remove all paper, including any jammed or torn pieces. Then reload paper and press the paper button to continue printing.
* RED Ink Light Flashes - One or more cartridges are low on ink. Check the message that appears on your screen to determine which cartridge is low, or follow the instructions in " Checking the Ink Supply". Make sure you have a replacement cartridge.
* RED Ink Light is ON- One or more cartridges are out of ink or not installed. If you have just installed a new cartridge, it may be incomaptible with the printer or incorrectly installed. Reinstall it or replace it with the correct cartridge
* RED Ink and RED paper lights flash alternately- The CD/DVD tray guide was left open when you turned on the printer or when printing on paper. Just simply close it/
* Green Power Light is Off; RED paperand RED Ink Lights flashing- Paper may be blocking movement of the print head. Turn off the printer, then open the cover and remove any jammed paper or other foreign objects. Turn the printer back on again. Or it may have an internal error. Turn off the printer, wait a few seconds, then turn it on again.
Jul 06, 2011 | Epson Stylus Photo R220 InkJet Printer
Red light is blinking, What is the the meaning?
Hi, Here is the meaning of the flashing red light. Red probsolv.6.3.4.jpg paper light flashes Paper is jammed in the printer. Press the probsolv.6.3.5.jpg paper button to eject the paper. If that doesn't work, turn off the printer, open the cover, and pull the paper out from the front, including any torn pieces. Then turn on the printer, reload paper, and press the probsolv.6.3.6.jpg paper button. You can download the user's guide for this product from here. Good luck!
Mar 05, 2011 | Epson Stylus C86 InkJet Printer
Two red lights flashing, but i can't figure out what's wrong
According to the documentation for your printer.
Red probsolv.6.3.11.jpg paper and probsolv.6.3.12.jpg ink lights flash alternately Paper may be blocking movement of the print head. Turn off the printer, then open the cover and remove any jammed paper or other foreign objects. Turn the printer back on again. If the lights are still on, contact your dealer or Epson as described in Where To Get Help.
Dec 16, 2010 | Epson Stylus C86 InkJet Printer
Both ink and rubbish light is flashing and wont go off
Rubbish light?? Do you mean the paper light is flashing?
When both the ink and paper lights are flashing together and the power light is off, the printer has an internal failure. Turn the printer off, wait a little while and turn it back on. If the error persists, decide if the printer is worth servicing. Since it is no longer sold by Epson, I assume it is out of warranty.
If the ink and paper lights are flashing in an alternating pattern, something may be blocking the print head from moving. Check for jams and clear them. If the error persists, it's service time (if you want to spend a minimum of ~$50 for diagnosis).
I wish that I could be of more help.
Apr 16, 2010 | Epson Stylus C86 InkJet Printer
C86 Epson printer will not print.
Please see your user manual for the meaning of the various light combinations, or if you don't have one, see:
and look at "Diagnosing Printer Problems".
BOBDOYLE - can you confirm which red light is flashing? If it is the ink light, see the instructions for changing ink cartridges. If it is the paper jam light, check for a paper jam. If you still cannot fix it, come back with a new comment giving any further information.
If this advice was helpful, please rate it.
GUESTS - you both have quite different problems to bobdoyle. If you require specific further help, please register and post a separate request for help.
Feb 05, 2009 | Epson Stylus C86 InkJet Printer
My epson stylus c86 is locked flashing paper and ink red lights. The down load from epson to reset the counter for the ink foam,says the printer is no on or have a problem,
Have a look at:
If it's a paper jam, look for and remove paper in feed system. If no paper, is the print head properly parked under the right-hand end of the cover? If not, you may have stuck or detached parking mechanism. Come back to me if this is the case for further help.
If it's "internal error", it usually means the waste ink pads need changing. You can overcome this problem temporarily by using the SSC utility - download from
and reset the Protection Counter. This will stop the lights flashing and restore normal operation. However, remember that eventually ink will overflow from the waste ink area and make a dreadful mess, so you must change the waste ink pads before this happens. This requires the disassembly of the printer. A copy of the service manual is available from a number of sellers - just Google "Epson C86 Service Manual". You will often find them
for sale very cheaply on E-Bay.
If you decide to have a go at replacing the ink pads yourself, report back and I will provide further help.
Please rate this advice.
Jan 13, 2009 | Epson Stylus C86 InkJet Printer
Blinking both the ink botton ligths and the botton paper
I just today threw away my R220. If your 2 red lights are going and the power light is off, then your printer has died. It just happened to me. It sucks, but there is no way to fix it.
May 04, 2008 | Epson Stylus Photo R220 InkJet Printer
2 flashing red lights
The printer jams each time I try to print, and although I think it's clear, it still jams.
Mar 22, 2008 | Epson Stylus C86 InkJet Printer
Epson stylus 880 printer
"Turn the printer on while holding down both the ink and paper buttons. When the paper light flashes release both buttons", then hold down the ink button for approx. half a minute until the printer lights flash again then release it. That resets the printer.”
Oct 08, 2007 | Epson Stylus 880 InkJet Color Printer
Red Paper light keeps flashing
Try to find thge combination of buttons that reset the printer. there are many possiblities due to the modles - but try pressing any 2 and whilst holding them down switch off and then on again. Also this utility could proce use full. When it is loaded -right click the task bar icon.
Oct 02, 2007 | Epson Stylus C86 InkJet Printer
Epson Stylus C86 InkJet Printer Logo
762 people viewed this question
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
